Go to Post FIRST should never come before school and anyone who thinks otherwise is irresponsible and should not be mentoring the kids - Koko Ed [more]
Unread 17-05-2015, 19:50
Bryce2471's Avatar
Bryce2471 Bryce2471 is offline
Alumnus
AKA: Bryce Croucher
FRC #2471 (Team Mean Machine)
Bryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud of
pic: Short coaxial swerve module
Unread 17-05-2015, 20:01
glennword's Avatar
glennword glennword is offline
Resident Solidworks Guru
AKA: Glenn
FRC #4146 (Sabercat Robotics)
Team Role: Student
glennword is a splendid one to beholdglennword is a splendid one to beholdglennword is a splendid one to beholdglennword is a splendid one to beholdglennword is a splendid one to beholdglennword is a splendid one to behold
Re: pic: Short coaxial swerve module
While I applaud your efforts, I have to ask, what benefits does having the CIM in a horizontal orientation get you? And are those benefits worth the extra complexity, part count, efficiency loss from the extra miter stage, and potentially weight? (not sure if the last one is a factor or not) The only benefit I can think of that might even be measurable is a lower CG, although I don't foresee that being much of a difference. I would suggest investigating worm gears in the future if you wish to bring this design into reality. You can get a nice, high, relatively efficient reduction in a single stage, and it sets you up nicely to go coaxial. Anyways, I love seeing your designs posted here fairly regularly, you have a tendency to think outside the box which is fantastic. Keep up the good work!
"Whether you think you can, or you think you can't--you're right."
-Henry Ford
Unread 17-05-2015, 20:24
Joey Milia's Avatar
Joey Milia Joey Milia is offline
FRC #0192 (GRT)
Joey Milia is a splendid one to beholdJoey Milia is a splendid one to beholdJoey Milia is a splendid one to beholdJoey Milia is a splendid one to beholdJoey Milia is a splendid one to beholdJoey Milia is a splendid one to behold
I won't dispute worm gears high reductions but i wouldn't describe them as relatively efficient. The highest efficiently you'll get is 86% with a four lead worm. At best this would be replacing the two stages before the co-axial, a miter stage and a timing belts stage, each around 95% or higher. I too am unsure of the benefits of a horizontal cim for a coaxial swerve but I don't think a worm gear would be beneficial on the Cim motor. However, using a worm gear for the steering motor is a different issue and has more merits in my opinion.
Unread 17-05-2015, 21:04
glennword's Avatar
AKA: Glenn
Team Role: Student
You are correct, sir. The miter gears I've had experience with are in all likelihood far below 95% efficiency, however upon further research I found that good quality miters in rigid and accurate housings can achieve those numbers. And of course belts are highly efficient, if properly tensioned.
-Henry Ford
Unread 17-05-2015, 21:05
Bryce2471's Avatar
Alumnus
AKA: Bryce Croucher
This was a design exercise for me to see how short I could make a coaxial swerve drive. In order to make the module shorter than a CIM motor is long, I had to put it sideways. I agree that there is likely not a huge benefit of doing it this way, but it was something I wanted to try out. I do think it is the lightest and most compact swerve I've ever designed, although that is likely for reasons other than the horizontal CIM.
There is also the fact that I'm only looking for a 1.5:1 gear ratio out of that section of the powertrain.
FLL Team Future imagineers
2010 Oregon State Championships: Winners
2011 International Invite: First place Robot design, Second Place Robot Performance
FRC Team Mean Machine
2012 Seattle: Winning alliance
2013 Portland: Winning alliance
2013 Spokane: Winning alliance
2014 Wilsonville: Winning alliance
2014 Worlds: Deans List Winner
Unread 17-05-2015, 23:46
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Amazing as usual. Thank you for sharing this on CD.
That weight is interestingly low. What is the thickness of the top plate? ARe you still using 1/4" diameter balls for the 16-style bearing?
EDIT: And which miter gears are those? They don't look like Vex ones.
Unread 18-05-2015, 19:13
Bryce2471's Avatar
Alumnus
AKA: Bryce Croucher
Thanks for the kind words.
The weight is a little lower than I expected as well, considering the added complexity. I attribute the lower weight to the caster portion being smaller. It now fits into a 72 tooth 20 dp gear from VEX instead of an 84 tooth.
The top plate is 0.25'' thick so that the plate that the CIM mounts to can be attached to the side of it with 6 32 bolts.
Yes, the steering gear and the bottom gearbox plate have grooves milled in them for 0.25" delrin balls.
The first set of miter gears are 1 module, 20 tooth because they have 8mm bore, and they're a little smaller. The later ones, in the caster, are 20 tooth 20 dp, because my team has had success with them in the past. They are both made of steel, and from SDP-SI.
Unread 20-05-2015, 19:02
Chinske4296 Chinske4296 is offline
FRC #4296
Chinske4296 is an unknown quantity at this point
That'd be awesome if it weighed that little. I don't really trust inventors weight estimates, I've gotten burned by that in the past. Not that I don't trust you or anything. Looks awesome!
