Go to Post There's no feeling quite like that one you get when you're behind the diamond plate controlling a metal beast that you've put your blood (literally), sweat (more literally), and tears (probably literally) into, and it working. Undescribable. - scali [more]
Unread 26-03-2015, 00:44
oramiawhale oramiawhale is offline
FRC #2068
oramiawhale is an unknown quantity at this point
C++ Deploy Will Not Show
I've been working with eclipse in linux and have had no problems with it up till a few days ago. Now, it no longer lets me deploy code in C++. Instead the options under run is Deploy Java which is not helpful. Does anybody know how to change it back to deploy C++?
Unread 26-03-2015, 15:37
SuperBK's Avatar
SuperBK SuperBK is offline
AKA: BrianK
FRC #1225 (Amperage Robotics)
Re: C++ Deploy Will Not Show
I assume you have restarted Eclipse, probably multiple times by now.
Try right clicking on the project and selecting "Close unrelated projects". That has worked some magic for us sometimes. If all else fails, you may have to make a new project and then paste or copy your code into the new project.
Brian K
Team 1225 Robotics Mentor
Unread 27-03-2015, 16:10
bob.wolff68's Avatar
bob.wolff68 bob.wolff68 is offline
Da' Mentor Man
FRC #1967
bob.wolff68 is just really nicebob.wolff68 is just really nicebob.wolff68 is just really nicebob.wolff68 is just really nicebob.wolff68 is just really nice
It certainly sounds like the plugin is no longer working. I would suggest that you re-install the plugin. Possibly it got corrupted for some odd reason.
Bob Wolff - Software from the old-school
Mentor / C / C++ guy
Team 1967 - The Janksters - San Jose, CA
Unread 27-03-2015, 19:44
JohnSmooth42 JohnSmooth42 is offline
Is writing code
FRC #0375 (The Robotic Plague)
JohnSmooth42 is an unknown quantity at this point
Could you possibly be in the wrong view/perspective/whatever it is they call it?
Unread 22-05-2015, 18:51
BenGuy's Avatar
BenGuy BenGuy is offline
Co-Driver - 3641 - Flying Toasters
AKA: Ben
FRC #3641 (The Flying Toasters)
Team Role: Operator
BenGuy is a glorious beacon of lightBenGuy is a glorious beacon of lightBenGuy is a glorious beacon of lightBenGuy is a glorious beacon of lightBenGuy is a glorious beacon of lightBenGuy is a glorious beacon of light
There's actually a way to wirelessly deploy C++ code from Eclipse, if you go into the settings (or maybe help menu) there should be a setting named "Add software" or something like that. If you add the software WPI made (I can't remember the exact URL, but if you do some searching in chief dephi it will be there - that's where we found it) then you can hit file and there's a button named RUN AS, and then you press WPILIB, the code will deploy wirelessly. If you can find that software, I suggest using it - WAY faster than tether deploying.
Ben Wolak
The Flying Toasters Website
Team YouTube
Team Twitter
The real problem with computers is that they do what you tell them to do, not what you want them to do.
