Go to Post Let gravity be your friend. - MrForbes [more]
Unread 22-05-2015, 20:17
AdamHeard's Avatar
Lead Mentor
Re: pic: GBX-123 chassis example
Originally Posted by PAR_WIG1350 View Post
Is there a story behind this?
Plywood Yo
Unread 22-05-2015, 20:33
TheOtherGuy's Avatar
TheOtherGuy TheOtherGuy is offline
Unregistered User
AKA: Kevin Forbes
FRC #4183 (Bit Buckets)
TheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond repute
Plywood Yo
I like your style
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Plywood Yo
What are the advantages over G10 though? Is it lighter?
Unread 22-05-2015, 22:23
asid61's Avatar
AKA: Anand Rajamani
FRC #0115 (MVRT)
Checked the weight in SW, plywood is only 0.3lbs heavier than a garolite bellypan. And it's cheaper and easier to work with, so we may well end up going that route.
Would 7/32 or 3/16" work instead? The last bit of extra weight is killing me.
Unread 22-05-2015, 23:20
Greg Woelki's Avatar
Greg Woelki Greg Woelki is offline
FRC Alumnus
FRC #1768
Greg Woelki is a glorious beacon of lightGreg Woelki is a glorious beacon of lightGreg Woelki is a glorious beacon of lightGreg Woelki is a glorious beacon of lightGreg Woelki is a glorious beacon of light
We used 5mm (~0.2") lauan plywood for Aerial Assault without any issues, so yes, if you insist.
Unread 22-05-2015, 23:31
cxcad cxcad is offline
FRC #1683 (Techno Titans)
cxcad will become famous soon enoughcxcad will become famous soon enough
That little bit of extra money though...
Unread 23-05-2015, 01:12
asid61's Avatar
AKA: Anand Rajamani
FRC #0115 (MVRT)
Can't argue with that. However, it's going to be tricky to convince the team that plywood makes for a good bellypan.
Usually our issue is with weight/design, not money.
Unread 23-05-2015, 01:21
AdamHeard's Avatar
Lead Mentor
Why? Analayze it from an engineering sense and explain the tradeoffs.
Most teams are several orders of magnitude away from being optimized enough for bellypan choice to even matter much anyway.
I posted in a bellypan thread the tradeoffs between several options but am on mobile and can't hunt it down.
Unread 23-05-2015, 01:26
Rachel Lim Rachel Lim is offline
FRC #1868 (Space Cookies)
Team Role: Student
Rachel Lim has a reputation beyond reputeRachel Lim has a reputation beyond reputeRachel Lim has a reputation beyond reputeRachel Lim has a reputation beyond reputeRachel Lim has a reputation beyond reputeRachel Lim has a reputation beyond reputeRachel Lim has a reputation beyond reputeRachel Lim has a reputation beyond reputeRachel Lim has a reputation beyond reputeRachel Lim has a reputation beyond reputeRachel Lim has a reputation beyond repute
This one?
http://www.chiefdelphi.com/forums/sh...0&postcount=48
I'm going to toot my own horn for a moment....
We've done
1) 1/16" G-10/FR4 Garolitem (2009, 2009 offseason, 2010, 2012)
Pros
-Looks darn good (glossy black)
-Very Stiff/strong
-Easy enough to drill, but vacuum the mess!
Cons
-Expensive
-Waterjet delaminates it, so they pierce 3-4" away from final cut and feed over. We did some external slots to act as rivet holes, then match drill rest on robot.
2) 6mm (~1/4") 5 ply baltic Birch (2012 offseason, 2013 season, 2014 offseason, 2015 season)
Pros
-Easy to cut
-Cheap
-Very HIGH stiffness to weight
-Can thread fasteners right into it for components
-When painted, looks nice enough.
Cons
-Termites
-Ignorant teams look down on it. This is fine, it just points out their lack of understanding of material properties and basic math
3) .125 6061-T6 diamond pattern (Waterjetted/lasercut). (2011 season, 2011 offseason, 2014 season)
Pros
-Hypetrain
-Forces you to do layout
Cons
-Expensive resource wise
-Not as stiff as the other 3 items
-One and done, no mods
4) .25 ABS (if you count 294). This is similar enough to (2007 season)
-It's really just a heaver version of plywood. I'd use plywood over this.
I highly recommend the wood, no need to laminate or do anything to it. Just use it as is. If your frail ego can't handle the wood, garolite is a great option at 1/16" thick but requires more tools to work with.
The diamond bellypan is nice... but in nearly all cases is a huge resource waste. Many subsystem gearboxes and gussets could be cut in the same time.
Unread 23-05-2015, 01:36
asid61's Avatar
AKA: Anand Rajamani
FRC #0115 (MVRT)
We're usually somewhat of a tradition-led team. We recently changed officers, so I'll have to speak with the new officer team about their thoughts on plywood. Compared to the punched 1/8" 5052 we use now, pretty much anything is better.
Garolite makes it look more "professional" compared to plywood, but I feel like we could just paint over it.
I've seen your bellypan threads, and I thought they were very helpful. It's also reassuring to know that your team has tried many different options and optimized.
As long as we don't have a game like this year's and we don't build too big, we're probably okay weight-wise. Both Garolite and plywood are so easy to use that I'm reasonably certain we can swap it out on one robot if the need is dire.
Unread 23-05-2015, 03:26
chrisfl chrisfl is offline
FRC #1991 (Dragons)
chrisfl is a name known to allchrisfl is a name known to allchrisfl is a name known to allchrisfl is a name known to allchrisfl is a name known to allchrisfl is a name known to all
Another really lightweight pption is 1/2in or3/16in corrugated plastic. That stuff is sure light and great for electronics boards. We've used it the past few years and have seen many teams using it before. You can even get it in colors to look good
Unread 23-05-2015, 10:39
philso philso is offline
FRC #2587
You and your team should define what "look more professional" really means, what your teams overall values are and how much priority and resource your team is willing to put into building a professional looking robot. You should also look around CD for the various threads about wood robots. If done right, they can look just as professional as a robot made from metal. While it is great that your team has a history of tradition to build on, FRC requires that teams think outside of the box (and sometimes inside of the box).
How good the robot looks depends more on how you use the material and your workmanship. There was a mostly wood robot in the Tesla Division that exhibited better workmanship and looked more professional than 80% of the other robots in Tesla. Of course, there were metal robots that also looked better than 80% of the other robots in Tesla.
Unread 23-05-2015, 13:54
FRC #1836 (MilkenKnights)
The biggest negative (performance wise) to plywood over G10 is that it is thicker. If ground clearance is important it can make a difference. Otherwise its much easier to manufacture and secure components into(pre drill and then self tapping screws). The extra weight is negligible because it is so low to the ground.
Unread 24-05-2015, 00:19
highlander's Avatar
highlander highlander is offline
Registered Boss
Team Role: Student
highlander has a spectacular aura abouthighlander has a spectacular aura abouthighlander has a spectacular aura about
I have to address a pet peeve here: anecdotal evidence. Stating a random example doesn't prove or disprove anything.
Has anyone actually performed a statistical test on how wooden robots perform vs how metal robots do? I don't know or suspect an answer, it just would be interesting to know.
Unread 24-05-2015, 02:14
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
I'm not sure there is large enough sample of wooden robots to draw any conclusions. Does anybody have a list of wooden robots?
