Re: pic: Wood Coast Drive
The main advantages of wood (IMO) are that it's dirt cheap and can be laser cut very quickly and easily. Polycarbonate is neither.
While both are true, I saw that someone was concerned about cutting the fiber up too much. I don't necessarily understand what that is, so I was guessing that is was something to do with structural integrity. Polycarbonate is (IMO) much more suited to take impact than plywood is, hence me asking the question in the first place.
We also use wood since it's so fast to make; we get turnaround times less than half an hour on our laser, while we'd have to cut Lexan by hand. |
Then why NOT use it for the front/side panels? I've gotten a lot of the benefits of using plywood, but no answers as to why polycarbonate would or would not be better.
Here are some more possible reasons: Wood is lighter than polycarb for the same size of piece (though it's quite possible that you might need a thicker piece). Wood is actually stiffer than polycarb--take a sheet of birch ply and a sheet of polycarb, hold at one end, shake. Wood is immune to loctite spidering... and it's a lot easier to drill without cracking if you forgot to CAD the holes for the laser. Note: The above specifically applies to birch plywood, ideally Baltic birch plywood. That being said, there ARE teams that build chassis out of polycarb: 1714 has been very hard to see for many years because their primary building material is polycarb (or is it acrylic? think it's polycarb). But they have to be very creative in terms of material attachment and stiffening. |
#7
In what way? I happen to be comparing WOOD and polycarb, thank you very much. The comment about the laser cutter was in a statement about WOOD.
#9
Again you can not laser cut polycarb with a commercially available machine. Last edited by mman1506 : 23-05-2015 at 22:31. |
#10
As I said earlier you are mixing up polycarbonate and acrylic. Acrylic is difficult to drill, polycarbonate is very easy to drill.
#12
Now, for the impact resistance: polycarb vs birch. Polycarb deflects, birch absorbs. They're about the same, but I'm going to have to give that to the plywood on strength-to-weight ratio. The main issue with birch ply is that it absorbs by getting dented or, eventually, splintering. (Acrylic never even enters this discussion, as the "standard" test for identifying unknown clear plastic is to clamp firmly and hit with the biggest hammer in the area--if it doesn't break, use the polycarb, otherwise it was acrylic.) |
#13
Polycarb is denser and less rigid
