Go to Post FIRST is just a single step in a multi-step process. Rome wasn't built in a day, and neither are solutions to the world's problems. - Tim Baird [more]
Unread 23-05-2015, 21:57
FRC #1836 (MilkenKnights)
Re: pic: Wood Coast Drive
Originally Posted by carpedav000 View Post
Then why NOT use it for the front/side panels? I've gotten a lot of the benefits of using plywood, but no answers as to why polycarbonate would or would not be better.
Polycarb is denser and less rigid
Unread 23-05-2015, 22:05
mman1506's Avatar
mman1506 mman1506 is offline
Focusing on Combat Robots!
AKA: Marcus Quintilian
no team (WARP7)
In this case, plywood takes impacts at least as well as polycarb, and is faster by far to cut and install.
Here are some more possible reasons: Wood is lighter than polycarb for the same size of piece (though it's quite possible that you might need a thicker piece). Wood is actually stiffer than polycarb--take a sheet of birch ply and a sheet of polycarb, hold at one end, shake. Wood is immune to loctite spidering... and it's a lot easier to drill without cracking if you forgot to CAD the holes for the laser.
Note: The above specifically applies to birch plywood, ideally Baltic birch plywood.
That being said, there ARE teams that build chassis out of polycarb: 1714 has been very hard to see for many years because their primary building material is polycarb (or is it acrylic? think it's polycarb). But they have to be very creative in terms of material attachment and stiffening.
I think your mixing up polycarbonate (lexan) and acrylic (plexiglass). Polycarb is extremely impact resistant but cannot be cut on a commercial laser cutter. Acrylic is very brittle and can very easily be cut on a laser cutter.
2016: FRC 865 Mentor
Unread 23-05-2015, 22:12
In what way? I happen to be comparing WOOD and polycarb, thank you very much. The comment about the laser cutter was in a statement about WOOD.
Unread 23-05-2015, 22:24
mman1506's Avatar
no team (WARP7)
I believe you are comparing wood and acrylic.
Polycarb is much more impact resistant than baltic birch.
It's very difficult to crack both polycarbonate and baltic birch while drilling. Out of the two baltic birch is easier to crack.
Again you can not laser cut polycarb with a commercially available machine.
Unread 23-05-2015, 22:32
My understanding was that acrylic is easy to drill, polycarb needs a special drill bit or it'll crack, and birch merely splinters if you make a mistake--not crack.
I never, EVER, said you COULD cut polycarb on a laser. If you can show me where EXACTLY I said that, by QUOTING, then I'll retract this statement. Otherwise, leave any discussion of cutting polycarb by laser out.
Unread 23-05-2015, 22:36
mman1506's Avatar
no team (WARP7)
As I said earlier you are mixing up polycarbonate and acrylic. Acrylic is difficult to drill, polycarbonate is very easy to drill.
Unread 23-05-2015, 22:44
Ah. (Makes me wonder why acrylic is found with FRC teams--and their "unskilled" drillers--around, but that's beside the point.)
Now, for the impact resistance: polycarb vs birch. Polycarb deflects, birch absorbs. They're about the same, but I'm going to have to give that to the plywood on strength-to-weight ratio. The main issue with birch ply is that it absorbs by getting dented or, eventually, splintering. (Acrylic never even enters this discussion, as the "standard" test for identifying unknown clear plastic is to clamp firmly and hit with the biggest hammer in the area--if it doesn't break, use the polycarb, otherwise it was acrylic.)
Unread 23-05-2015, 23:11
Sperkowsky's Avatar
Sperkowsky Sperkowsky is offline
Professional Multitasker
AKA: Samuel Perkowsky
FRC #2869 (Regal Eagles)
Sperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond repute
Plywood loses to poly on strength to weight. Lexan is crazy strong. I stood on a freely Standing peice of 1/16 lexan and it just bent I stepped off bent right back into shape no problem. I can't say the same for a piece of 1/16 plywood.
Unread 23-05-2015, 23:20
Originally Posted by Sperkowsky View Post
Plywood loses to poly on strength to weight. ... 1/16 lexan ... 1/16 plywood.
FWIW: That's strength to volume, not weight.
Unread 23-05-2015, 23:22
Sperkowsky's Avatar
Yea but in order to get a similar strength you would need much thicker wood which may be heavier then the thinner poly carb
Unread 23-05-2015, 23:27
Plywood loses to poly on strength to weight. [...] I stood on a freely Standing peice of 1/16 lexan and it just bent I stepped off bent right back into shape no problem. I can't say the same for a piece of 1/16 plywood.
Which is lighter? Think about that one for just one moment.
You're confusing strength and strength-to-weight.
Here's an example: Steel is stronger* than aluminum. But aluminum tends to be the material of choice** in applications that need low weight, despite being weaker. Why is that?
Because aluminum, in general, is stronger for the same weight. Some alloys of steel are very light. Most are not. Use aluminum and you get a lighter weight, even if you have to use more material to do it, for the same strength.
So: if you got an equal weight of plywood and polycarb in the same general shape, which would break first?
*I do need to point out that this is a generalization--there are, in fact different kinds of strength, and because of that, any declaration that X is stronger than Y is dependent on application. In this particular case, it's true mostly across the board.
**Excluding exotic materials or odd applications, of which there are plenty.
Unread 23-05-2015, 23:35
Necroterra's Avatar
Necroterra Necroterra is offline
FRC #4183 (Bit Buckets)
Rookie Year: 2015
Necroterra will become famous soon enough
In 4 competitions, the only thing we broke on our wood robot was the polycarbonate switch covers.
Of course they took the brunt of the stress and weren't boxes.
2015 Arizona East - Regional Winners, Creativity Award
Unread 24-05-2015, 07:49
The point was, your 1/16" test doesn't resolve that question.
Unread 24-05-2015, 12:01
You are confusing material properties.
I could build a robot out of rubber and it would never break. It also would be completely unsuitable because it has no rigidity.
Unread 24-05-2015, 13:36
TheOtherGuy's Avatar
TheOtherGuy TheOtherGuy is offline
Unregistered User
AKA: Kevin Forbes
TheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond repute
For reference, baltic birch plywood is ~0.65 g/cm^3, while polycarbonate is around 1.2g/cm^3 and aluminum is ~2.7.
There are many more factors that determine what material we use than simply density and strength. As Cal mentioned, we use plywood because it is incredibly cheap and easy for our team to work with. If using polycarbonate makes sense for your team and application, go for it.
The cutter also leaves a fairly smooth finish on the sides (structurally, though, the lightening patterns aren't really justified).
