Go to Post a robot can always be your girl. xcept for the fact you need to share - greencactus3 [more]
Unread 16-05-2015, 17:17
TBots TBots is offline
FRC #3350
TBots is an unknown quantity at this point
Talon SRX and Analog Encoders
We just got some Talon SRX motor controllers and are working on understanding all of their potential. Mainly, we need to figure out how to hook up and use a magnetic absolute encoder (MA3) to each of our SRX. The SRX will be what controls the turning of our wheels in a swerve drive.
I've hear that the SRX have 'built-in' PID controllers. Is this true? And if so, do I still need to include PID in our labVIEW programming?
There are several examples of using the talon SRX in the software manual that was included with the SRX, but we are unable to distinguish which of them we are meant to use.
Thank you for the help!
Unread 16-05-2015, 18:05
Re: Talon SRX and Analog Encoders
Yes.
No. But you do need to do the following:
- connect the feedback sensor directly to the Talon (not the roboRIO)
- use CAN bus (not PWM) to control the Talon
- use the appropriate CAN commands to tell Talon what closed-loop mode you want (e.g. position or speed etc)
- use the appropriate CAN commands to set the gains in the Talon's PID controller.
- use the appropriate CAN commands to communicate the desired setpoint to the Talon's PID so it knows what value you want it to control to.
Unread 16-05-2015, 19:42
MaGiC_PiKaChU's Avatar
MaGiC_PiKaChU MaGiC_PiKaChU is offline
Drive Coach
AKA: Antoine L.
FRC #3360 (Hyperion)
MaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond repute
Yes.
also you'll need one of those for each talon
http://www.vexrobotics.com/217-4401.html
We had 14 SRX this year, 12 of them with a sensor in the breakout... This is amazing
2012 - 3360 - Junior member
2013 - 3360 - Lead Programmer, Human player
2014 - 3360 - Lead Programmer, Human player
2015 - 3360 - Lead Programmer, Driver
2016 - 3360 - Mentor, Drive coach
Unread 16-05-2015, 22:24
FRC #3350
Is it absolutely necessary to use the breakout board? It may be messy, but could you accomplish the same thing without it? What exactly does it do? Is it just making it easier to use the SRX?
Unread 16-05-2015, 22:31
ozrien's Avatar
ozrien ozrien is online now
Omar Zrien
AKA: Omar
Here's a snippet from the link Ether mentioned....
This breakout board is designed specifically for use with the Talon SRX - it scales a native 5V analog signal to a Talon SRX compliant 3.3V, helping 5V magnetic shaft encoders to "just work" without additional circuitry.
See section 1.4.7 of the Talon SRX User's Guide for more details.
So in other words the MA3 is a 0-5V sensor, but the Talon analog input takes 0-3.3V (also in electrical specs in user's guide).
Unread 16-05-2015, 23:08
Gotta give Antoine credit for that link :-)
Unread 17-05-2015, 00:10
FRC #3350
Alright I understand what is it now, but is it the only way to turn 5V of analog signal to 3.3? I'm asking because while the breakout board would be helpful, it doesn't look like we will be getting it any time soon seeing how it is currently sold out.
I still think it might be possible to recreate it, but maybe I don't yet understand the uniqueness of it. The talon SRX user guide makes the comment that the board is useful in the aspect that is uses "a resistor divider and voltage buffer" to make the 5V to 3.3V transition. What are these, and where are they located on the board? Is is something to do with the A63A?
Unread 17-05-2015, 00:24
Drive Coach
AKA: Antoine L.
we made a custom 5 to 3.3V converter on a breadboard at first...
pretty simple, but would highly recommend the breakouts with the designed cable
Unread 17-05-2015, 00:43
FRC #3350
What is the "Q1" in the diagram?
Did it still work with the breadboard design? I mean, was there a major flaw in it, or did the breakout board just work better?
Yes the breakout board would be preferable, but if there is no way to get it at this moment, we would like to try alternate methods.
Unread 17-05-2015, 00:54
Drive Coach
AKA: Antoine L.
breadboard works, just takes a lot of space... As this is an offseason project, you should be fine.
breakout also allows you to use multiple sensors easily on a single SRX.
this diagram is an easier circuit you could use. The other was working both ways
http://www.savagecircuits.com/attach...6&d=1430452949
Unread 17-05-2015, 01:08
FRC #3350
looks good Thank you for the help!
Unread 17-05-2015, 01:10
Drive Coach
AKA: Antoine L.
No problem Good luck with your project!
Unread 23-05-2015, 23:18
FRC #3350
The Talon SRX Software Manual mentions that "the Set Output VI is also the method for specifying the setpoint." How can this be? I thought all the set output VI did was change the motion of the motor specified to either clock-wise or counter clock-wise and at your chosen speed. how can it also change setpoint?
If you wanted to change the position of the motor to the 90 degree mark, what value would you enter? Normally the VI's values range from -1 to 1. So how can you place an angle? What would be the range of values?
Unread 23-05-2015, 23:27
Drive Coach
AKA: Antoine L.
i'm not sure about LabView, but with Java it's also the same command;
depending on the Control mode, the input will not have the same effect
for example, we used "PercentVBus" during teleop, which ranges from -1 to 1
we used it like this
talon.set(0.7);
//this sets the voltage output to the motor to 70% of the battery
During autonomous, we used "Position" , which ranges from 0 to 1024 (0V on the sensor to 3.3V)
talon.set(512);
//this sets the talon to 180 degrees, like a servo would do
I guess it's the same with Labview, but I might as well be wrong
Unread 23-05-2015, 23:32
FRC #3350
I see what you mean. There is a similar command in labVIEW when initializing the Talon SRX objects to change it from PercentVBus to Position, I just never knew what it meant! Thanks for clearing that up!
