Go to Post Finally!!! I love hugs. - Eugenia Gabrielov [more]
  #31   Spotlight this post!
Unread 25-05-2015, 13:10
BenGuy's Avatar
BenGuy BenGuy is offline
Co-Driver - 3641 - Flying Toasters
AKA: Ben
FRC #3641 (The Flying Toasters)
Team Role: Operator
BenGuy is a glorious beacon of lightBenGuy is a glorious beacon of lightBenGuy is a glorious beacon of lightBenGuy is a glorious beacon of lightBenGuy is a glorious beacon of lightBenGuy is a glorious beacon of light
Re: Windows 10
Originally Posted by asid61 View Post
Personally I've found that Windows 8.1 takes up massive amounts of memory (I have 8gb) such that SolidWorks will throw a "low memory" error after a few hours of running, even if nothing else is open. It might just be my computer, but I'm probably going to try Windows 10 later to see if it helps.
Before you throw the white flag, I'd make sure it's a problem that needs such big change. When it gives that kind of error, use the Windows 'Resource Monitor' to find out what is using the most memory - just go to the 'Memory' tab and click on total read / write to see what's using the most memory. There could be a background program eating it that you don't notice. If that's the case, use 'Task Manager' to end the process to free up that memory.
Ben Wolak
The Flying Toasters Website
Team YouTube
Team Twitter
The real problem with computers is that they do what you tell them to do, not what you want them to do.
  #32   Spotlight this post!
Unread 25-05-2015, 13:13
MikLast's Avatar
MikLast MikLast is offline
CAO/Drive Coach
AKA: Mikal Dieatrick
FRC #4513 (Circuit Breakers)
MikLast has a reputation beyond reputeMikLast has a reputation beyond reputeMikLast has a reputation beyond reputeMikLast has a reputation beyond reputeMikLast has a reputation beyond reputeMikLast has a reputation beyond reputeMikLast has a reputation beyond reputeMikLast has a reputation beyond reputeMikLast has a reputation beyond reputeMikLast has a reputation beyond reputeMikLast has a reputation beyond repute
Re: Windows 10
Originally Posted by DareDad View Post
An OEM system builder license with full media is pretty cheap, almost certainly much cheaper than any hardware you're putting it on. http://smile.amazon.com/Windows-8-1-...dp/B00F3ZN2W0/
Word of warning, buying an OEM version of windows 8/8.1 will give you a non-genuine copy of windows, as you are not using it for resale. Anything windows 7 or earlier is okay.
http://www.howtogeek.com/197232/micr...der-licensing/
Check out the FRC Discord!
2014: programmer, scout
2015: programmer, admin, drive team
Innovation in control award, WVHS district event
Innovation in control award, CWU district event
finalist, PNW district championship
2016: CAO, Drive team.
Excellence In Engineering awad, WVHS District event
  #33   Spotlight this post!
Unread 25-05-2015, 15:33
FlamingSpork FlamingSpork is offline
Eating Utensil
FRC #3003 (Tan[X])
Rookie Year: 2015
FlamingSpork is just really niceFlamingSpork is just really niceFlamingSpork is just really niceFlamingSpork is just really niceFlamingSpork is just really nice
Re: Windows 10
I really can't say whether 10 is better than 8.1 with memory because coding/compiling and driving doesn't use all that much RAM.
If Windows 10 doesn't have good memory handling, I would recommend Linux, which works quite well on low-RAM systems. (My main Linux computer has only 2GB of RAM.)
Windows NT 4.0, 98, XP, 7, 8, 8.1, and 10
Fedora Core 10
Ubuntu 12.04 LTS
C++, Bash, TI-Basic, and Javascript
  #34   Spotlight this post!
Unread 25-05-2015, 19:18
Jared's Avatar
Jared Jared is offline
Re: Windows 10
Did you check to see how much RAM is actually being used? SolidWorks may give you a low memory error because it's running out of GDI objects, which isn't actually a problem. I get the error all the time on my laptop with windows 8.1 and 6 gb of RAM, but I've never had solidworks close or crash, even after the critical system resource error shows up multiple times. It seems that an update to solidworks caused these warning to show up a bunch on many computers for some reason.
  #35   Spotlight this post!
Unread 25-05-2015, 20:23
mman1506's Avatar
mman1506 mman1506 is offline
Hater of Tiny Molex Connectors
AKA: Marcus Quintilian
no team (WARP7)
I have 24gb of ram and I get those errors at 40% allocation.
2016: FRC 865 Mentor
