Go to Post We’ve been chasing perfection since 2003 in the hopes of catching excellence. - Karthik [more]
Unread 25-05-2015, 21:37
zinthorne's Avatar
zinthorne zinthorne is offline
AKA: Avery
FRC #5827 (Code Purple)
zinthorne will become famous soon enough
pic: Help with solid works gears
Unread 25-05-2015, 21:39
cad321 cad321 is offline
Jack of all trades, Master of none
AKA: Brian Wagg
FRC #2386 (Trojans)
cad321 is just really nicecad321 is just really nicecad321 is just really nicecad321 is just really nice
Re: pic: Help with solid works gears
This table is what I use for all of my gear work. I find that it has everything I need when working with gears. Keep in mind that you should leave a small gap between the distance calculated. Ive seen several opinions on this forum about what the "proper" distance is to add however I tend to add about 0.005" to it.
Unread 25-05-2015, 21:43
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
http://www.wcproducts.net/how-to-gears/
Use the Calc at the bottom of the page
R.C.
MadTown Robotics Team 1323
Unread 25-05-2015, 21:59
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
(T1 + T2)/(DP*2) + C should be the distance between two gears.
T1 is the teeth on gear 1. T2 is the teeth on gear 2. DP is the diametrical pitch (usually 20 for FRC gears). C is the clearance, an added distance between gears to ensure that manufacturing tolerances don't force the gears to close to each other. Two gears must have the same DP to mesh properly.
Basically, you want the "pitch diameter" of two gears to be tangent, with a spacing of C between the two diameters. The pitch diameter is equal to T/DP, where T is the teeth on the gear and DP is the pitch. Just draw a circle, plus that in for diameter, and add C to the resulting number. Do the same for t your second gear and make the two circles tangent.
On a part to be milled or CNC'd, I use a C of 0.000". For waterjetted stuff I am starting to use 0.003" in case the holes are too close and I don't want to mill it as well.
Unread 25-05-2015, 22:36
orangemoore orangemoore is offline
AKA: Roger Moore
FRC #3135 (Robotic Colonels)
orangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond repute
I suggest you design the plates using circles as place holders for gears instead of creating an assembly. This will make your life a lot easier.
This video should show how this works.
https://youtu.be/GCjBx3TXB6Y?t=19m32s
Stronghold
Student 2013-2016
3135 -- Robotic Colonels
3507 -- Robotheosis (FTC)
Unread 25-05-2015, 22:52
Dunngeon Dunngeon is offline
Pumped
AKA: Ryan
Dunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond repute
The 610 design files are very useful for this as well, among other things.
610 Design Files by Ryan Tam
(2015-?): 973
(2012-2015): 955
Unread 26-05-2015, 00:20
rcmolloy's Avatar
rcmolloy rcmolloy is offline
Remote Mentor
AKA: Robert Cory Molloy
rcmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond repute
On top of the plate design using circles, I would advise using sketches to making your entire 2-D conceptual design before moving forward. It can keep things organized really well if you dimension and use relations properly.
FRC 1647: Iron Devils - 2009 - 2011
FRC 973: Greybots - 2011 - 20XX
"While I was a student in FIRST, it was all about becoming inspired. Now as a mentor/engineering student, it's all about making sure learn everything I can so I can carry that on inspiration for future generations while having a hell of a lot of fun!"
Unread 26-05-2015, 08:14
Chris Endres Chris Endres is offline
Play hard, Work harder
AKA: Topher
no team (WildStang)
Team Role: CAD
Chris Endres is just really niceChris Endres is just really niceChris Endres is just really niceChris Endres is just really niceChris Endres is just really nice
A really useful page I use quite a bit: http://computers.martinchick.com/spur_gear.html
You'd want to calculate the (Pitch Diameter)/2 for both gears, add them, and that'll be your distance between centers. I usually add about 2-5 thou (0.002"-0.005") to the sum, just for tolerances in manufacturing.
2009 FLL Illinois State Champions - iLEGO
2010 FLL Illinois State Champions - iLEGO
2011 FLL Illinois State 3rd Place - iLEGO
2011 FLL Illinois State 1st Ambassador - iLEGO
2013 FRC Milwaukee Regional Champions - WildStang
2016 FRC Midwest Regional Finalists - WildStang
Unread 26-05-2015, 10:21
Bennett548 Bennett548 is offline
Engineering Mentor
AKA: Steve Bennett
FRC #0548 (Robostangs)
Bennett548 is just really niceBennett548 is just really niceBennett548 is just really niceBennett548 is just really nice
Here is a solidworks file used to design a 3 CIM gearbox:
https://drive.google.com/file/d/0ByD...ew?usp=sharing
It has a 50 tooth gear in the center, with three cims with pinions driving it. On each cim we have included 3 different sized pitch diameters (12, 14, 17) so that the pinions can be swapped to get different ratios. Each pitch diameter circle is driven by an equation: pitch diameter = number of teeth/ 20 +0.002 because these are 20 dp gears. I have also added 0.002" to all pitch diameters to get the 0.002" extra on all center to center distances. Also included in the first sketch are mounting hole locations for the cims with each of the different pinions. Around each pitch diameter I have a circle 0.1" larger in diameter to show where the tips of the gear teeth are to make sure nothing will collide with them. Also shown are the bolt heads of cim mounting screws to make sure everything will clear.
The 0.002" extra value is not a strict rule. We have found that it works well for enclosed gearboxes that are waterjet.
I wish solidworks had sketch annotations so I could label every circle. It can get ridiculous trying to remember what each of the dozens and dozens of circles represent when doing a more complex gearbox.
Here is a screenshot of the assembled gearbox:
The cim mounting hole locations in the plate that the cims mount to is driven by the sketch in the front plate, so that any change made to the front plate will propagate through the whole assembly.
These gearboxes are a good example of how you can use solidworks bottom-up (start with sketches) or top-down (start with assemblies and use the parts to drive sketches for other parts). For example the gearboxes start with sketches, but the robot bellypan uses components placed in the assembly to drive the position of mounting holes.
Unread 26-05-2015, 19:05
nathannfm's Avatar
nathannfm nathannfm is offline
AKA: Nathan
FRC #3940
nathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant future
While I know the calculation is simple this is still a handy tool, especially being web based, think you could add 32DP to the drop down? You are the guys who sell those gears after all.
[2016-20??]: Mentor: FRC Team 3940"CyberTooth"
[2013-2016]: Mentor: FRC Team 365 "MOE"
[2012-2013]: Mentor: FRC Team 3929 "Atomic Dragons"
[2011-2012]: Mentor: FRC Team 365 "MOE"
[2008-2011]: Student: FRC Team 365 "MOE"
[2007-2008]: Student: FTC Team 365 "MOE"
[2005-2007]: Student: FLL Team "The MOEstangs"
Unread 26-05-2015, 19:07
zinthorne's Avatar
AKA: Avery
Thank you so much for the help!
