Go to Post I want to use some of that mass-less rod in our robot - saves weight. - ebarker [more]
  #37   Spotlight this post!
Old 26-05-2015, 16:26
Re: Incorporating Opposing Alliance Information in CCWM Calculations
...the following two computational methods yield virtually identical results for min L2 norm of b-Ax:
Method 1
1a) [U,S,V] = svd(A)
1b) Replace the diagonal elements of S with their reciprocals, except when abs(Sjj)<threshold (I used 1e-4 for threshold), in which case make Sjj zero.
1c) compute x = V*S*(U'*b)
Method 2
2a) N = A'*A
2b) d= A'*b
2c) compute x = N\d ..... (Octave mldivide notation)
2d) compute m = mean(x)
2e) subtract m from each element of x
Notice Method 1 factors A, not A'A, resulting in less rounding error.
There's a simpler way to do Method#1 above if you are using Matlab or Octave (hat tip to AGPapa):
x = pinv(A,tol)*b;
pinv() is explained in detail here:
http://www.mathworks.com/help/matlab/ref/pinv.html
(well worth reading; explains the interesting difference between x1=pinv(A) and x2=A\b)
