Go to Post Pneumatic components always give me gas... - Alan Anderson [more]
Unread 27-05-2015, 01:14
cad321 cad321 is offline
Jack of all trades, Master of none
AKA: Brian Wagg
FRC #2386 (Trojans)
cad321 is just really nicecad321 is just really nicecad321 is just really nicecad321 is just really nice
Whats the big deal with in tube gearing?
This thread isn't meant to an insult to any type of drive train or style of building, merely a genuine question. Over my time on chief delphi I have seen countless numbers of drivetrains where the gears are all on the inside of the tube their chassis is made from. What are the benefits to this? To me this would seem like a poor decision as it makes maintenance on your sub system difficult at best. Should you strip a gear or need to lube up your transmission, it is very tight with little to no openings. Speaking of tight space, getting the gears inside the tubing to begin with seems like a challenge. Surely its doable (heck teams do it) but it seems like it would take an incredible amount of time ensuring they're seated correctly before it is assembled.
Again this is just me trying to understand the benefits to other designs to aid in the build in years to come. In no way do I feel that this style of building is bad, I may even find I prefer it once I've heard others opinions. Obviously all designs differ slightly, but this seems to be a common theme among a lot of them.
Unread 27-05-2015, 01:50
Mike Marandola Mike Marandola is offline
Lead Bumper Mentor
AKA: Mike Marandola
FRC #0316 (Lunatecs)
Mike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond repute
Re: Whats the big deal with in tube gearing?
The main advantage is that it saves space. This year, some robots needed the extra space for the totes to fit inside their chassis. It also opens up more options structure wise. For example, this large cross member on 254's robot wouldn't be possible with a traditional WCD. Other benefits are chain protection and aesthetics. Of course it would be up to your team to decide if the extra space is worth the challenge.
2015 - Pioneer Valley District Finalists/Upper Darby District Finalists/MAR District Championship #1 Seed and Winners with 225 and 203
2014 - Lenape Seneca District Winners/Chestnut Hill District Winners
2013 - Lenape Seneca District Winners/Chestnut Hill District Finalists
2011 - Philadelphia Regional Finalists
2009 - Finger Lakes Regional Finalists
Unread 27-05-2015, 08:27
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
While I haven't done one of these drives, I believe that protection (both of and from the chain) is the biggest advantage. Aesthetics and volume savings also contribute. One other point I noticed in a post was that if the tolerances are calculated correctly, it becomes nearly impossible for the chain to come off the sprocket without something breaking due to the limited clearance.
Unread 27-05-2015, 08:49
Abhishek R Abhishek R is offline
FRC #0624
Abhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond repute
Do you mean the transmission gears itself are in the tubing, or the chain, or both?
2012 - 2015 : 624 CRyptonite
Team Website
Unread 27-05-2015, 08:55
AKA: Brian Wagg
FRC #2386 (Trojans)
I have seen both done. Already these responses are very good points I hadn't considered.
Unread 27-05-2015, 10:18
FRC #0624
I see. We ran the chain-in-tube design this year on our robot, and it was great. Since the chain can't go anywhere (due to the constraints of the tubing) we didn't have to do any maintenance on it at all, and it went through 3 regionals and Championships fine, still running great as we head into the offseason.
Like others said, it was actually integral to our design as we needed the space to fit our elevator system and totes into the robot. Another hidden benefit was the fact that noodles couldn't get stuck in our chains as we saw with some other team because none of it was exposed.
Even installation wasn't that time consuming; we actually finished our drivetrain this year faster than any other year, getting the practice robot drive chassis done within a week into the build season.
Team Website
Unread 27-05-2015, 10:33
Justin Montois's Avatar
Justin Montois Justin Montois is offline
FirstUpdatesNow.com
FRC #3015 (Ranger Robotics)
Justin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond repute
Send a message via AIM to Justin Montois
340 first did Chain in Tube in 2012 and it was a learning experience. The main advantage was the gain of internal space and the aesthetic of a clean looking robot.
The installation of the chain the first year was a pain but we've gotten much better at it over the years. The size of the pockets, the order of installation, and the right combination of tools really makes all the difference.
If you're looking for an offseason project I would definitely recommend giving it a shot.
@jmontois340
Team 3015
2016- World Championship Finalists and Tesla Division Champions with 2056, 1690 and 1405
2016- Greater Pittsburgh Regional Chairman's Award
2016- Pittsburgh Regional Finalists with 1023 and 4050
2015- Newton Division Finalists With 195 and 1756
2015- Finger Lakes Regional Champions with 4039 and 378
Unread 27-05-2015, 10:54
Sperkowsky's Avatar
Sperkowsky Sperkowsky is online now
Professional Multitasker
AKA: Samuel Perkowsky
FRC #2869 (Regal Eagles)
Sperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond repute
Is there some sort of tutorial as this seems like a cool off season idea
Unread 27-05-2015, 11:05
bigbeezy's Avatar
bigbeezy bigbeezy is offline
AKA: Bryan
FRC #2338 (Gear it Forward)
bigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to behold
Send a message via AIM to bigbeezy
Seconded. We are working on a t-shirt cannon this off season and having the chain in the tube might be a good safety feature in addition to keeping dirt and other debris out of the chain. Do any teams use belt inside the tube?
Team 1592 Bionic Tigers -- Driver 2005-2008
Winner - Florida Regional 2005
Finalist - Newton Division 2007
Winner - Colorado Regional 2008
Florida State University - BS Mechanical Engineering
Team 2338 Gear it Forward -- Mentor/Drive Coach 2013-Present
Winner - Wisconsin Regional 2013
Chairman's Award - Midwest Regional 2015
Winner - Archimedes Sub-Division 2015
Chairman's Award - Midwest Regional 2016
Unread 27-05-2015, 15:15
Dunngeon Dunngeon is offline
Pumped
AKA: Ryan
Dunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond repute
It's possible, but you'd have to use 2x2 tubing to get both of the belts to fit into the interior. From what I've read on Delphi, chain in tube is better than belt since chains (rarely) snap and don't stretch over time, eliminating the need for a tensioning system.
(2015-?): 973
(2012-2015): 955
Unread 27-05-2015, 15:53
cadandcookies's Avatar
cadandcookies cadandcookies is offline
Director of Programs, GOFIRST
AKA: Nick Aarestad
FTC #9205 (The Iron Maidens)
cadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond repute
While chains do not stretch over time like belts do, they do wear over time, which has a very similar effect. For the most part in my experience neither phenomenon is typically noticeable in a robot during a standard (1-2) event season, but both can be observed on a practice robot with sufficient hours of use. In a high-use demobot, both have a potential to give you issues if you use it long enough.
Both chain in tube and belt in tube have been done successfully in competition-- 1625's Lobster Drive and of course 118's chain in tube come to mind as examples of belt and chain respectively.
Never assume the motives of others are, to them, less noble than yours are to you. - John Perry Barlow
tumblr | twitter
'Snow Problem CAD Files: 2015 2016
MN FTC Field Manager, FTA, CSA, Emcee
FLL Maybe NXT Year (09-10) -> FRC 2220 (11-14) -> FTC 9205(14-?)/FRC 2667 (15-16)
VEXU UMN (2015-??)
Volunteer since 2011
2013 RCA Winner (North Star Regional) (2220)
2016 Connect Award Winner (North Super Regional and World Championship) (9205)
Unread 27-05-2015, 16:11
Cash4587's Avatar
Cash4587 Cash4587 is offline
AKA: Cooper Cash
FRC #4587 (Jersey Voltage)
Cash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud of
I could be wrong, but I am pretty certain chain definitely does stretch over time, more so than belts. Due to the fact roller chain has metal pins and bushings that all see general wear and tear, I think chain elongates the more use it sees.
Unread 27-05-2015, 16:31
Ty Tremblay's Avatar
Robotics Engineer
FRC #0319 (Big Bad Bob)
319 hasn't made a chain-in-tube drivetrain yet, but what I find attractive about the design is it's simplicity and the volume savings. It may be a little less easy to work on, but due to the protected nature of the chain, the odds of you having to work on it are smaller. Mounting gearboxes becomes much easier as well.
Under the forces it'll see in FRC, chain cannot stretch. It can wear, however.
Unread 27-05-2015, 18:17
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
That large cross member would be possible with exterior chain/belt, you'd simply have to route the chain around it*.
*Which obviously comes at the price of additional chain and idlers.
Unread 27-05-2015, 20:23
Pumped
AKA: Ryan
I'm more concerned about the chance of snapping a drive belt, rather than the wear. It's nearly impossible to snap chain in FRC if assembled correctly, from my (limited) experience it's quite a bit easier with belts.
(2015-?): 973
(2012-2015): 955
