Go to Post SELECT YOUR STRATEGY BEFORE YOUR ROBOT DESIGN. - Kims Robot [more]
Unread 25-05-2015, 16:24
TheModMaster8's Avatar
TheModMaster8 TheModMaster8 is offline
Active Alumni
FRC #5492 (Robo Jockeys)
TheModMaster8 is a jewel in the roughTheModMaster8 is a jewel in the roughTheModMaster8 is a jewel in the rough
Need help with lego NXT lejos xbox controlling
I'm attempting to use an Xbox One wired controller on my MacBook Pro laptop, Im using Java with Eclipse that has lejos and LWJGL installed on it in order to control an NXT via my controller, like how we control our robots. I have a gamepad driver installed, it's called "XOne Controller" (link)https://github.com/FranticRain/Xone-OSX Also i have a little program to test the data from the joysticks and buttons of the controller
import org.lwjgl.LWJGLException;
import org.lwjgl.input.Controller;
import org.lwjgl.input.Controllers;
public class Start extends Virtual_JoyStick
	public static Controller control;
	public static boolean Start;
	public static void main(String[] args)
		try
			Controllers.create();
		catch(LWJGLException e)
			e.printStackTrace();
		Controllers.poll();
		for(int i=0;i<Controllers.getControllerCount();i++)
			control=Controllers.getController(i);
			System.out.print(control.getName());
		control=Controllers.getController(0);
		for(int i=0; i < control.getAxisCount(); i++)
			System.out.print(i+ ": "+ control.getAxisName(i));
			//System.out.print("c");
			control.setDeadZone(i, (float) 0.30);
		for(int i=0; i < control.getButtonCount(); i++)
			System.out.print(i+ ": "+ control.getButtonName(i));
		while(true)
			control.poll();
		    //Start=control.isButtonPressed(7);
			/**System.out.print(control.getAxisValue(0));
			System.out.print("   ");
			System.out.print(control.getAxisValue(1));
			System.out.print(control.getAxisValue(2));
			System.out.print(control.getAxisValue(3));
			System.out.print(control.getAxisValue(4));
			System.out.print(control.getAxisValue(5));
			System.out.println(); */
			Virtual_JoyStick joy = new Virtual_JoyStick();
			joy.repaint();
my problem is i don't know how to make the main program listen to live input data and send it to the robot wirelessly, Also note that I'm not at basic but not advanced in the realms of coding. JSYK (just so you know).
2009-2011: (FLL) Robot Builder / Operator
2012: (FRC Team 2783) Fabrication / HumanPlayer / FLL Ref
2013: (FRC Team 2783) Fabrication / HumanPlayer / FLL Ref
2014: (FRC Team 2783) Fabrication Student Lead / HumanPlayer / FLL Ref
2015: (FRC Team 2783) Fab Student, Teacher / HumanPlayer / Backup Driver / FLL Ref / FLL Mentor of 6 Teams
2016: (FRC Team 5492) Fabrication Student Lead / Driver / FLL Mentor of Crestwood Elementary
Past Alliance:(2783, 1208, 4154)(2783, 1002, 4265)(2783, 1182, 3868)(2783, 451, 4028)(2783, 1208!, 1288)(5492, 63, 1014) I Will Never Forget
Unread 25-05-2015, 17:41
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
Re: Need help with lego NXT lejos xbox controlling
Originally Posted by TheModMaster8 View Post
		while(true)
			control.poll();
			joy.repaint();
I'm not sure what each line of this is doing, but assuming those are the correct methods, all you have to do is assign their values to variables instead of printing them (see below). From there, you need to figure out how you are getting the commands from the computer to the NXT. For this you would want to also include a bluetooth library on the computer side. I would imagine that Lejos has methods for bluetooth on the NXT side.
                     axisZero = control.getAxisValue(0);
Hope that helps.
EDIT: what do the last 2 lines of the while loop do? it seems like that might not be something you want to do for every iteration of the loop, but I could be wrong.
EDIT (again): I see that the constructor called in the lines I referenced above is the constructor for the parent class. Is the start class the class that you are using to run the program in the JVM, or is it a class that you intend to use to create start objects? I assumed the former since you omitted a constructor but included a main() method, but it occurred to me that you might have intended the latter.
Unread 25-05-2015, 18:01
Dartmouth 2020
AKA: lopsided98
FRC #2084 (Robots by the C)
The easiest way to set up communication between the computer and the robot is to use the communication classes included in the leJOS PC library.
The computer side project (the one that reads from the controller) should be set up according to these instructions. Then you can use DataOutputStream (on the computer) and DataInputStream (on the robot) to send numbers over bluetooth. I would recommend using USB for testing as it is more reliable and faster to connect and the APIs are nearly identical. These instructions might help with setting up communications.
I also have some more complicated communication code that you can look at if you want. This provides a way for bidirectional communication that is sort of similar to I2C. There are a few intermittent threading bugs, but it might give you some idea of how to connect the computer and the robot.
Computer Code
Robot Code
Feel free to ask any other questions you have about the specifics of getting your leJOS working.
Unread 25-05-2015, 18:10
Jalerre's Avatar
Jalerre Jalerre is offline
FRC #4965 (FIRE)
Jalerre is on a distinguished road
This might help. I have a little bit of experience using LeJos with an NXT with Bluetooth and Joystick control so I may be of some assistance.
Vex
2013: 415 - Fabrication, Programming, Electrical
2014: 415D - Captain, Programming Lead
FTC
2014: 7354 - Programming Lead
FRC
2013: 415 - Safety Animation, Fabrication
2014-2015: 4965 - Programming & Electrical
2016: 4965 - Captain, Programming Lead, Electrical
Unread 25-05-2015, 19:26
Active Alumni
Originally Posted by dongeng View Post
Thanks for help, Its same with me problem since 3 week ago
Ikr, i've search the web for like 3 weeks al the links are clicked on and i still couldnt find anything
Unread 27-05-2015, 23:38
Active Alumni
I need some help i keep getting this error and i can't figure out why
Native Library bluecove not available Failed to open connection to the NXT
Solution!: it is solved by adding -d32 in the arguments tab of the run config file !
Unread 28-05-2015, 13:06
Active Alumni
Hopefully the last time i need help. everything runs fine but when it connects this is the error i get
Loading: net.java.games.input.OSXEnvironmentPlugin
Using joystick: Xbox One Controller
Found NXT: Tim fork 0016530A7EAE
Connected to NXT: Tim fork@0016530A7EAE
Connection to NXT timed out.
Any clue as to what is going on ?
Unread 28-05-2015, 13:14
Dartmouth 2020
AKA: lopsided98
Are you running the code on the robot that responds to the requests from the computer? This error means that the program on your computer sent a request to the robot and the robot did not respond.
You have to start the program on the robot before starting the program on the computer. I might add the ability to cleanly connect, disconnect and reconnect (like the FRC system), but it doesn't have that capability at the moment.
Unread 28-05-2015, 21:25
Active Alumni
Talking Re: Need help with lego NXT lejos xbox controlling
I did as you suggested and now i get this
dyld: lazy symbol binding failed: Symbol not found: _IOBluetoothLocalDeviceReadSupportedFeatures
  Referenced from: /private/var/folders/_2/xj9xgcd50xd820c_rjmpltwc0000gn/T/bluecove_BradenShepard_0/libbluecove.jnilib
  Expected in: /System/Library/Frameworks/IOBluetooth.framework/Versions/A/IOBluetooth
dyld: Symbol not found: _IOBluetoothLocalDeviceReadSupportedFeatures
last time i hopefully
Unread 29-05-2015, 10:14
Dartmouth 2020
AKA: lopsided98
That's an OSX problem, not my code, but I'll try to help anyway.
It looks like this is a bug in BlueCove (the bluetooth library) caused by some changes in Mac OS 10.8 and newer. What are your OS and BlueCove versions?
I don't much experience with Mac OS, so Googling might help more than I can.
Unread 29-05-2015, 11:39
Active Alumni
OSX: 10.10.2 Yosemite
and im using lejos version: leJOS_NXJ_0.9.1beta-3 2 i can't find the versoin of bluecove.
Solved it, the usb that is i needed to switch this little line of code
 public Robot() {
        // RConsole.open();
        // pilot.steer(90, false);
        // pilot.steer(140, false);
        // pilot.steer(180, false);
        // pilot.steer(0, false);
        final NXTConnection connection = Bluetooth.waitForConnection();
        communication = new CommunicationSlave(connection.openInputStream(), connection.openOutputStream(), new CommunicationHandler() {
to
  public Robot() {
        // RConsole.open();
        final NXTConnection connection = USB.waitForConnection();
in the robot class, $@#$@#$@# well at the tri controller class
Unread 29-05-2015, 21:46
Active Alumni
I'll take you up on that offer, i got everything to work, but i am now stuck on how to integrate the xbox controller's inputs into the code. as far as i can tell, it is only passing on the key and then the keystroke reaches the robot, it goes forward, i want it to coast up to speed but i don't know if you can called in joystick function on the robot (server) side,
ex.
int i = 0
if(control.getAxisValue(1) > 0.35){
i = i +5;
Motor.BC.setSpeed(i) }
else
i=0;
how would i add this to the code?
