Go to Post Alright, looks like we've sidetracked into "Off-Topic Land", an area I know I have to visit every so often but I am always happy to leave. - Jessica Boucher [more]
Unread 29-05-2015, 18:09
TBots TBots is offline
FRC #3350
TBots is an unknown quantity at this point
Re: Talon SRX and Analog Encoders
Originally Posted by MaGiC_PiKaChU View Post
1- we had tons of data cables, so we cut one side to connect each wire individually... you could also plug a small wire into each hole, but that would be harder
Cutting them would make it hard to plug them into the breakout board later. Just the same, we have had a lot of difficulty trying to find wires small enough to fit into the data cable's slots. Do you know what each hole does on the data cable?
2- No, your RoboRio has its own IP address, it changes if you connect via USB or ethernet. I don't remember the defaults, because we changed it to 10.33.60.2 as soon as we got it. You can find this address somewhere in the user's manual
The IP changes?? you mean it's not “roborio-XXXX.local”
where XXXX is the team number? It has an extension such as .2 or .6?
