Go to Post Although I've never oxy welded myself, I know it is doable - jamie_1930 [more]
Unread 30-05-2015, 21:11
x86_4819's Avatar
x86_4819 x86_4819 is offline
computer-whisperer
AKA: Christian Balcom
FRC #4819 (Flat Mountain Mechanics)
x86_4819 is on a distinguished road
Learning More about Motion Control
Hi,
This last season I started learning and using multiple new and increasingly advanced (for me) concepts and algorithms for motion control (trapezoid motion profiles, feed-forward PID, etc). I also watched the very enlightening seminar that team 254 gave at worlds this year, and have been searching for more information on the subject.
My question is, what good resources (books, websites, etc) are there for learning more about different/more advanced algorithms for robotic motion control and navigation?
My Github Repositories
Unread 30-05-2015, 21:46
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: Learning More about Motion Control
Search CD for "profiling".
A couple of links I found that way:
http://www.chiefdelphi.com/forums/sh...d.php?t=136798
http://www.chiefdelphi.com/forums/sh...d.php?t=134965
I also found a few links about CPU profiling, so maybe you could neck it down a bit with "motion profiling", but you're also likely to miss some threads that way.
And there was this recent thread:
http://www.chiefdelphi.com/forums/sh...d.php?t=137317
Unread 31-05-2015, 18:51
SoftwareBug2.0's Avatar
AKA: Eric
FRC #1425 (Error Code Xero)
Here are a few more navigation-related things you could read up about:
http://en.wikipedia.org/wiki/Voronoi_diagram
http://www.cs.columbia.edu/~pblaer/p.../path_planner/
http://en.wikipedia.org/wiki/Visibility_graph
http://en.wikipedia.org/wiki/Configuration_space
If you want I can answer questions.
