Go to Post The most important deisgn criteria is always performance in any of the parts / systems we design. But we do try to abide by the saying -- if it doesn't look good (right), it probably isn't good (right). - Adam Freeman [more]
Thread Tools Rating: Thread Rating: 7 votes, 5.00 average. Display Modes
Unread 02-06-2015, 00:08
Munchskull's Avatar
Munchskull Munchskull is offline
CAD Designer/ Electrical Consaltant
AKA: Anthony Cardinali
FRC #0997 (Spartan Robotics)
Team Role: CAD
Munchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to behold
Fantasy Product's-what u wish was made
So I have come to points in my time in first where I will encounter a problem that certain slight variations would fix. My question for you is what product do you wish that Andymark, Vex pro, Cross The Road Electronic, ect, would make to assist teams.
My two products that I would love to see are Banebot gear box adapters that could use Bag Motors because many teams have a number of both banebot gearboxs and Bag motors and I sure know I could like to use both together.
Second is a variation of the traditional CIM motor that had a small back shaft and mounting points. This is because encoder mounting is sometimes a pain. With the right encoders we could just stick the one the back of CIM motors and be finshed.
“In theory, theory and practice are the same. In practice, they are not.” ― Anonymous
Anthony Cardinali
4th year of FRC
Class of 2017
Unread 02-06-2015, 00:13
AdamHeard's Avatar
Lead Mentor
Re: Fantasy Product's-what u wish was made
3/8 bearing rounded shaft with a .191 hole.
Unread 02-06-2015, 00:20
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
3/8" hex bore versahubs. I ask for this every time lol.
3/8" hex bore sprockets and timing pulleys.
Pre-lightened gears (the 32p ones from WCP would be be useful if they were lighter).
What would you use that for? Elevator?
Unread 02-06-2015, 00:33
AdamHeard's Avatar
Lead Mentor
Axles and standoffs. Pretty much everywhere.
Unread 02-06-2015, 00:36
josesantos's Avatar
josesantos josesantos is offline
Mentor; Former Design Chairman
FRC #0687 (Nerd Herd) (VRC #687z) & FRC #5499 (BHS Robotics)
josesantos has a reputation beyond reputejosesantos has a reputation beyond reputejosesantos has a reputation beyond reputejosesantos has a reputation beyond reputejosesantos has a reputation beyond reputejosesantos has a reputation beyond reputejosesantos has a reputation beyond reputejosesantos has a reputation beyond reputejosesantos has a reputation beyond reputejosesantos has a reputation beyond reputejosesantos has a reputation beyond repute
Most likely. I suppose for lower-load applications you could make 10-32 dead axle gearboxes, axles, etc.?
CAMS Robotics, FIRST Team 687 The Nerd Herd 2010-Present
College Mentor 2013-Present // Design Chairman 2012-2013
Berkeley High Robotics, FIRST Team 5499 2014-Present
College Mentor 2014-Present
Unread 02-06-2015, 00:38
BJT's Avatar
BJT BJT is offline
uh, should that be smoking?
AKA: Ben Thorsgard
FRC #0876 (Thunder Robotics)
BJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond repute
90 degree gearbox the size of a versaplanetary, 3/8 hex output.
2016 Central Illinois Winner. Curie Division finalist
Unread 02-06-2015, 00:48
AdamHeard's Avatar
Lead Mentor
As well as high load applications.
Unread 02-06-2015, 01:08
Andrey K. Andrey K. is offline
FRC #0955 (CV Robotics)
Team Role: CAD
Andrey K. is an unknown quantity at this point
A good COTS brake solution. Perhaps one from VEX that would interface with their versaplanetary system. This would have saved our team a lot of time and resources this past season.
Unread 02-06-2015, 01:23
You know... Y'all are learning engineering. I'm aware that AM at least will take design ideas from teams (they've done it in the past).
So... You want something to be a COTS offering, how about you make a prototype, do a bit of market research, and see about making a deal with the appropriate company?
Just a thought.
One final item: [geezer]Back in my day, we didn't have these newfangled 3-CIM gearboxes! All we had was drill motors, with drill gearboxes! Had ta make 'em shifting ourselves! COTS parts? HA! Had to build the entire robot, 'cept the KOP! More than 2 CIMS? HA! We was lucky to get that! You young whippersnappers have everything handed to you! Ya wouldn't last 2 days if you had to build all this stuff yourself![/geezer] Incidentally, there's some truth to that... 4 CIMs weren't an option until my third year on a team.
Unread 02-06-2015, 09:56
jwfoss jwfoss is offline
Chasing Elegant Simplicity
AKA: Justin Foss
Yes please. And while were at it, I'd enjoy Colson wheels with integrated sprocket bolt pattern and a 1.125" through hole.
Unread 02-06-2015, 09:57
Brandon Holley's Avatar
Consider this a gigantic second to the above suggestion. Given the choice I would prefer a 0.159" hole option over a 0.191" only because I can easily open the hole up if I need that variety. However, BOTH would be absolutely amazing to have.
The time savings for us if we had this variety of shaft would be unreal. Making standoffs is one of the last full blown manual operations we have to do each year.
-Brando
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
Unread 02-06-2015, 10:29
IronicDeadBird's Avatar
IronicDeadBird IronicDeadBird is offline
Theory Crafting Fo days...
AKA: Charles Ives "M" Waldo IV
FRC #1339 (Angelbots)
Team Role: Tactician
IronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond repute
Captive Ball omnis that can lock and unlock.
HERO 俺を讃える声や 喝采なんて 欲しくはないさ
I liked my team more before they stole my jacket.
Play is for kids this is serious...
Unread 02-06-2015, 10:36
mman1506's Avatar
mman1506 mman1506 is offline
Focusing on Combat Robots!
AKA: Marcus Quintilian
no team (WARP7)
An incremental encoder "stage" for a VersaPlanetary that is linked directly to the output shaft.
2016: FRC 865 Mentor
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
AndyMark makes a 3/8" hex hub. It isn't as thin as a versahub, but shortening it is trivially simply on a lathe (plus you're left with a 3/8" hex ID, 1" OD billet which has some utility in unexpected places).
I'd love the new shaft ideas, both 0.159 & 0.191 holes. Our #7 bit is so overworked...
Unread 02-06-2015, 11:18
Monochron's Avatar
Monochron Monochron is online now
Engineering Mentor
AKA: Brian O'Sullivan
FRC #4561 (TerrorBytes)
Monochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond repute
I was talking to a 900 mentor about this idea this season. Honestly I think one of the biggest barriers to team's using encoders is the mechanical mounting and something so simple to integrate like this would be huge.
