Go to Post Thanks for the heads up on the elevator game. - Andrew_L [more]
Thread Tools Rating: Thread Rating: 7 votes, 5.00 average. Display Modes
Unread 02-06-2015, 12:01
Munchskull's Avatar
Munchskull Munchskull is offline
CAD Designer/ Electrical Consaltant
AKA: Anthony Cardinali
FRC #0997 (Spartan Robotics)
Team Role: CAD
Munchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to behold
Re: Fantasy Product's-what u wish was made
Originally Posted by Monochron View Post
I was talking to a 900 mentor about this idea this season. Honestly I think one of the biggest barriers to team's using encoders is the mechanical mounting and something so simple to integrate like this would be huge.
More encoder mounting for all motors.
“In theory, theory and practice are the same. In practice, they are not.” ― Anonymous
Anthony Cardinali
4th year of FRC
Class of 2017
Unread 02-06-2015, 12:46
Pault's Avatar
Pault Pault is offline
FRC #0246 (Overclocked)
Pault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond repute
Originally Posted by mman1506 View Post
An incremental encoder "stage" for a VersaPlanetary that is linked directly to the output shaft.
Step 1: Drill a 1/4in hole 3/4in deep into the center of the output shaft
Step 2: Use a hacksaw to cut down the center of the shaft to the same depth as the hole.
Step 3: Assemble VersaPlanetary and mount onto robot.
Step 3: Put a 1/2in hex shaft collar around the end of the shaft.
Step 4: Cut a piece of thin polycarb and drill a 3/8in hole near one end.
Step 5: Use a nut to screw an incremental encoder, absolute encoder, single turn potentiometer*, or 10 turn potentiometer into the hole in the polycarb.
Step 6: Insert shaft of sensor into hole in the output shaft.
Step 7: Tighten shaft collar.
Step 8: Attach the loose end of the polycarb to any nearby piece of the robot.
We did this on 9 out of 11 of the VersaPlanetaries on our robot. It was so simple, and just worked. Should accomplish what you want fairly well.
*I don't have the link for where we bought these, but I doubt it would be difficult to find them with the right shaft size.
Unread 02-06-2015, 12:51
2544HCRC's Avatar
2544HCRC 2544HCRC is offline
FRC #2544 (HCRC)
2544HCRC has a spectacular aura about2544HCRC has a spectacular aura about2544HCRC has a spectacular aura about
Richer variety of cheap Aluminum pressed gears and sprockets. The AndyMark hex gears and sprockets are a bargain but I wish there was just more of a variety in size. Also a set of right angle gears that one could build a gearbox around. Also adapter gears for the shafts of many of the First motors.
A more inexpensive pneumatics valve for FIRST applications along with a compressor that delivered a slightly larger cfm in a similar sized package (Its MY wishlist).
Unread 02-06-2015, 13:07
Kevin Ray's Avatar
Kevin Ray Kevin Ray is offline
None #0329 (Raiders)
Kevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to behold
One final item: [geezer]Back in my day, we didn't have these newfangled 3-CIM gearboxes! All we had was drill motors, with drill gearboxes! Had ta make 'em shifting ourselves! COTS parts? HA! Had to build the entire robot, 'cept the KOP! More than 2 CIMS? HA! We was lucky to get that! You young whippersnappers have everything handed to you! Ya wouldn't last 2 days if you had to build all this stuff yourself![/geezer] Incidentally, there's some truth to that... 4 CIMs weren't an option until my third year on a team.
Man! Now THOSE were the days... We'd spend 2-3 weeks just getting the drive train to work.
Now, so as to not hijack this thread, I'd like to have a set of hole cutters like these: http://www.mscdirect.com/product/details/98332570 but 5 thou undersized so that we could press fit bearings into the hole.
_____________________________________________
Last words before magic smoke appears: "There, that oughta work!"
2016 Utah Regional- Engineering Inspiration
2016 Utah Regional- Dean's List Semi-Finalist- Ed O'Connor
2016 Utah Regional- Dean's List Semi-Finalist- Emily Ferrari
2016 Utah Regional- 3rd seed
2016 SBPLI Regional- Finalist, 6th seed
2016 SBPLI Regional- Gracious Professionalism Award
Unread 02-06-2015, 16:15
RoboChair's Avatar
AKA: Devin Castellucci
Toolpost Grinder? I recently ran into an issue tapping a 1/4-20 hole, had to tap past the shoulder and had no reduced shank tap. Put my tap in the Bridgeport spindle and a Die Grinder in the vise and reduced the shank in about 15 minutes.
Good times.
12 Years and counting! Over a third of my life has been spent with FRC.
Unread 02-06-2015, 16:31
Munchskull's Avatar
Team Role: CAD
How about a servo version of the CIM everyone would love that.
Anthony Cardinali
4th year of FRC
Class of 2017
Unread 02-06-2015, 20:43
marshall's Avatar
marshall marshall is offline
FRC #0900 (The Zebracorns)
Can you provide pictures for this?
Personally, I'd rather see more integrated options made available to teams than us using the same old hacks to make our existing solutions work. Yes, they work, but they aren't pretty. I think I have a good idea of what you are describing and the encoder/sensor being exposed is still the biggest problem for longevity (read: durability).
Unread 02-06-2015, 20:58
Jared's Avatar
Jared Jared is offline
Double 25 sprockets, 3mm pitch belts/pulleys with 3/8" hex and press fit for common FRC motor shafts, steel on brass worm gearbox, and half inch hex sleeve.
Some sort of simple system for large diameter hollow tube axles/bearing for arm joints.
Unread 02-06-2015, 21:02
ajlapp ajlapp is offline
AKA: Anthony Lapp
None #0118 (Team RUSH and Robonauts)
ajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond repute
Double 25 sprockets exist...in one tooth size at least.
http://www.team221.com/viewproduct.php?id=132
Anthony Lapp
FIRST Engineering Mentor
Owner/Operator 221 Robotic Systems
221 Robotics Systems - Quality Hardware, Made in the USA
RobotOpen
anthony@221robotics.com
Twitter us: @221RobotSystems
Team 1 --> 94 --> 68 --> 221 --> 857 --> 27 --> 118
Design Engineer/Fabricator and 17 year vet
Team Rush (FRC27) and Robonauts (FRC118)
Unread 02-06-2015, 21:41
Scott Kozutsky's Avatar
Scott Kozutsky Scott Kozutsky is offline
FRC #0865
Scott Kozutsky will become famous soon enough
I'd like to see vex or AM make sprockets compatible with bike chain.
It's really strong, more resistant to misalignment, more readily available, has much better breaking/joining tools and is lighter than 35 chain per linear distance. There are also a few existing mechanisms that could potentially be pulled from bikes for it.
2010-2012 FRC 865 Warp7 Student, Mechanical
2013 FRC 1310 RUNNYMEDE ROBOTICS Student, Mechanical, Design
2014 FRC 865 Warp7 Student, Mechanical, Design
2015 FRC 865 Warp7 Alumni, Mechanical Mentor
Unread 02-06-2015, 22:05
Electronica1's Avatar
Electronica1 Electronica1 is offline
Former Design and CAD Captain 1086
AKA: Alexander Kaplan
FRC #0401 (Copperhead Robotics)
Electronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond repute
How about a 2 inch colson wheel with hex hub (I know it is a tad random, but would help with my teams octocanum)
Plus, on the more unrealistic side:
locking mecanum wheels
A disk brake stage that stacks with other gearboxes that have a hex output shaft
Unread 02-06-2015, 22:12
Mike Marandola Mike Marandola is offline
Lead Bumper Mentor
AKA: Mike Marandola
FRC #0316 (Lunatecs)
Mike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond repute
Why not buy them from Mcmaster? Bike chain is ANSI #40 and 1/2" pitch right?
2015 - Pioneer Valley District Finalists/Upper Darby District Finalists/MAR District Championship #1 Seed and Winners with 225 and 203
2014 - Lenape Seneca District Winners/Chestnut Hill District Winners
2013 - Lenape Seneca District Winners/Chestnut Hill District Finalists
2011 - Philadelphia Regional Finalists
2009 - Finger Lakes Regional Finalists
Unread 02-06-2015, 23:21
Munchskull's Avatar
Team Role: CAD
That is not unrealistic at all. I would love a modular hex disk break.
Anthony Cardinali
4th year of FRC
Class of 2017
Unread 03-06-2015, 00:26
FRC #0865
Not compatible with existing wheels (versapattern/1.875 hexagonal bolt pattern) and no cheap hex options. Additionally, #40 chain is physically thicker than bike chain making the sprockets incompatible.
I've seen teams mount disks to the 1.875 hole pattern adapters so that's a pretty good starting point. It's a pretty simple thing to execute and is not necessary for most games so it would be too specialized IMO.
It would also be cool to see versablocks to mount to standard lumber sizes to make prototype and otherwise cheap robots easier.
Last edited by Scott Kozutsky : 03-06-2015 at 00:33. Reason: Adding stuff that i didn't comment on previously
Unread 03-06-2015, 01:33
Lead Bumper Mentor
AKA: Mike Marandola
Ahh, I am not very familiar with bikes. I never knew there were various bike chain roller widths. Neat!
