Go to Post There are so many creative and brilliant minds out there that build wonderful inventions and machines---surely we can be equally creative and open minded ... - Tonya Scott 476 [more]
Unread 02-05-2015, 18:37
SoftwareBug2.0's Avatar
AKA: Eric
FRC #1425 (Error Code Xero)
Re: Raspberry Pi C++
Originally Posted by FRC2501 View Post
Ok a few things:
1. build-essential is already the newest version
2. lib32stdc++6 is not available
3. libstdc++6 is already the newest version
Doe anybody know how to fix this?
What is the output if you run "apt show libstdc++6"?
Unread 04-05-2015, 00:34
yash101 yash101 is offline
AKA: null
That's quite a simple problem to understand, but I don't know how to fix it.
If you notice, in the error, there's some version info about the shared object file.
If this isn't the same, you will often get an error.
I guess that you can try getting that shared object from the system which compiled the code and place it in the libraries folder in your system. You'll need to run ldconfig to flush the changes. After that, it should work magically.
Ideally, you would want to just compile the software on your Pi. OpenCV's CMakeLists.txt is very smart and will automatically optimize your build for what's available for it to use. This way, it can add optimizations such as better GPU acceleration, etc.
Compiling on your Pi will also get rid of the error because you will have compiled your software using libraries already present on your system.
Unread 02-06-2015, 22:01
dubiousSwain's Avatar
dubiousSwain dubiousSwain is offline
The ride never ends
AKA: Christian Steward
FRC #5420 (Velocity)
dubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond repute
This is a little bit off topic, but I'm trying to get rudimentary tracking (nothing crazy like NN or 900's code) with the Raspberry Pi and Python, im just having trouble figuring out how to configure it to automatically run on the robot without having to be interfaced with
1. What distros can I use/should be using?
2. How do I run code without logging in?
After I figure out the answer to question 1, I can use my limited knowledge of GNU/Linux to disable GNOME/X, install OpenCV, and autorun my scripts, but those two questions are my current hangups. Any and all advice would be greatly appreciated.
2015 MAR District Champions
Unread 02-06-2015, 23:05
faust1706's Avatar
faust1706 faust1706 is offline
FRC #1706 (Ratchet Rockers)
faust1706 is infamous around these partsfaust1706 is infamous around these parts
1. I would recommend a linux distro as they are generally the lightest (and FREE!). A common OS is ubuntu.
2. You can set up any program (or script) to run upon boot in a linux. What 1706 has done for many years now is simply don't require a login and then set up the program to run on boot. This way, as soon as the board gets power (and maybe a press of the power button to start the booting process of the board), the program will start automatically.
"You're a gentleman," they used to say to him. "You shouldn't have gone murdering people with a hatchet; that's no occupation for a gentleman."
Unread 03-06-2015, 08:43
The ride never ends
Thank you. I have Raspbian on my RPi right now and the time it takes to log in is atrocious. Is it necessary to disable X if I'm not connected to a display? I want to maximize the resources that my code has available. Also, how does one make Ubuntu not require a login?
Unread 03-06-2015, 10:08
faust1706's Avatar
Um...you could try only showing terminal. I'm not sure how much that would speed up boot time and I do not recommend unless you are a hardened linux user.
Unread 26-06-2015, 21:38
FRC2501's Avatar
FRC2501 FRC2501 is offline
FRC #2501 (Bionic Poalrs)
FRC2501 is an unknown quantity at this point
So I had some issues with my Pi not booting, so I bought another and the new one works great, I had to restart my OS but now I have it back to operational.
apt show libstdc++ returns command not found
I had tried compiling on the Pi but then the Pi started asking for the FRC libraries.
Unread 27-06-2015, 16:28
apt-cache show libstdc++
dpkg -l libstdc++6
From looking at your initial error message, and this statement, it looks like you are trying to use the FRC toolchains to target the Pi. (The .20 is the version of libstdc++v3 built for the roboRIO) This isn't going to work like you are hoping. I'd recommend either building your code directly on the pi with compilers on the Pi, or finding a good tutorial on building code for the Pi.
Unread 30-06-2015, 15:07
nick4130 nick4130 is offline
4130 Mechanical Lead
AKA: Nick
FRC #4130 (The Blue Devils)
Team Role: Human Player
Rookie Year: 2015
nick4130 is an unknown quantity at this point
Does anyone have Raspberry Pi drive train code that i can copy and paste into it? Im doing a side project with one of my friends from 1718
