Go to Post Multitasking is a myth. - DonRotolo [more]
Unread 03-06-2015, 19:22
Mr.Twister's Avatar
Mr.Twister Mr.Twister is offline
CADalicious
AKA: Dillon Tocco
FRC #0240 (Tempest)
Team Role: CAD
Mr.Twister is an unknown quantity at this point
Smile H Drive
I Was wondering if anyone could explain to me what an H-Drive is. Also, it would be great if you could add a couple pictures or videos. Thanks
Unread 03-06-2015, 19:25
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Re: H Drive
4 omni wheels in a regular 4-wheel drive configuration, and 1 omni wheel in the center of the robot perpendicular to the other wheels in a simple form.
See:
Unread 03-06-2015, 19:29
Mr.Twister's Avatar
CADalicious
AKA: Dillon Tocco
FRC #0240 (Tempest)
Team Role: CAD
Re: H Drive
Thanks! So all the wheels are directly driven I was thinking using chains on the sides and directly drive the middle, is that a good idea or should I stick with directly driving all of the wheels?
Unread 03-06-2015, 19:33
Pault's Avatar
Pault Pault is offline
FRC #0246 (Overclocked)
Pault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond repute
Re: H Drive
No problems with that. In fact, I would say that it is better, because if the front 2 wheels lift off the ground, you will still be driving your back wheels with 2 CIMS of power. Same goes for if the back 2 wheels leave the ground.
Unread 03-06-2015, 19:36
Mr.Twister's Avatar
CADalicious
AKA: Dillon Tocco
FRC #0240 (Tempest)
Team Role: CAD
Re: H Drive
Thank you paul i will try and post a picture once I create it in Autodesk to see what you think
Unread 03-06-2015, 20:46
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: H Drive
Chaining or belting each pair of wheels with the same center lines automatically distributes the necessary extra torque to the wheel which you're accelerating away from. If you have a CIM for each wheel, it also appropriately redistributes the torque and power of the two CIMS to the two wheels.
Getting the weight load on a strafe wheel correct can also be tricky. This year, we modified a KoP drive train into an H, and ended up pulling the strafe module to minimize weight. Try to make the strafe wheel so that it will carry a defined load, either through a spring or pneumatic cylinder. Using a cylinder also allows you to retract the strafe wheel, which better supports climbing ramps and so forth.
Unread 03-06-2015, 21:05
Re: H Drive
It automatically distributes the extra torque to the wheel with greater traction, once the one with lesser traction reaches its traction limit. Which wheel has greater traction depends on magnitude and direction of acceleration, location of center of mass, and wheel tread material (if wheels are not indentical).
Unread 04-06-2015, 07:35
trumpthero786's Avatar
trumpthero786 trumpthero786 is offline
What Part of the Sandwich Are You?
AKA: Humza
FRC #2729 (Storm Robotics)
Team Role: Electrical
Rookie Year: 2015
trumpthero786 will become famous soon enough
Re: H Drive
Here is a video of us testing our 8+1 wheel H-Drive. We later scrapped it for a different set of wheels altogether, but this was our first time strafing with it. Yup. Nine wheels.
https://www.youtube.com/watch?v=2rAjU9ncg8w
CLAP CLAP WHOOSH!
2015 - Hatboro Horsham - Quarterfinalist with 272 and 5181 - Entrepreneurship Award
2015 - Seneca - Quarterfinalist with 316 and 5684 - Engineering Inspiration Award
2015 - MAR Championships - 50th Seed - Quarterfinalists with teams 1923 and 11
2016 - Hatboro Horsham - Team Spirit Award
2016 - Seneca - Gracious Professionalism Award
"nice beaver tail"
Unread 04-06-2015, 12:19
Karthik Karthik is offline
VEX Robotics GDC Chairman
Karthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond repute
Re: H Drive
See:
You can find full CAD files and a Bill of Materials for an entirely COTS H-Drive here:
http://www.vexrobotics.com/vexpro/examples-guides
:: Karthik Kanagasabapathy ::
"Enthusiasm is one of the most powerful engines of success. When you do a thing, do it with all your might. Put your whole soul into it. Stamp it with your own personality. Be active, be energetic, be enthusiastic and faithful and you will accomplish your object. Nothing great was ever achieved without enthusiasm" -- R.W. Emerson
My TEDx Talk - The Subtle Secrets of Success
Full disclosure: I work for IFI and VEX Robotics, and am the Chairman of the VEX Robotics and VEX IQ Game Design Committees
Unread 04-06-2015, 18:50
cbale2000's Avatar
cbale2000 cbale2000 is offline
AKA: Chris Bale
FRC #0703 (Phoenix)
cbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond repute
Re: H Drive
It's probably worth noting that to make an effective H-Drive you really need to have the center wheel on some kind of suspension otherwise its very hard to get traction.
We found that out the hard way this year (our first time building an H-Drive), even after dropping the center wheel 1/16" we still only had enough traction to strafe about 75% of the time.
Unread 04-06-2015, 19:30
logank013's Avatar
logank013 logank013 is offline
Me: &quot;Ready to scout?&quot; Team: &quot;Ughh!&quot;
AKA: Logan Kreisher
FRC #0234 (Cyber Blue)
Team Role: Scout
Rookie Year: 2015
logank013 has a brilliant futurelogank013 has a brilliant futurelogank013 has a brilliant futurelogank013 has a brilliant futurelogank013 has a brilliant futurelogank013 has a brilliant futurelogank013 has a brilliant futurelogank013 has a brilliant futurelogank013 has a brilliant futurelogank013 has a brilliant futurelogank013 has a brilliant future
Re: H Drive
I don't know much about this drive train but, I'm assuming it isn't a good drive to have in games like Ariel Assist because in that game, drives needed a good amount of traction? Thanks. Just wondering.
Cyber Blue Season 2015
IN Indy District Chairman's Award Winner | IN Kokomo District Event Winner (With 135 and 3865)
IN Purdue District Event Winner (With 1024 and 2197) | IN District Championship Winner (With 1024 and 292)
WORLDS:
Archimedes Rank 3 After Quals. | Alliance #3 Captain
Archimedes Division Semi-Finalist (With 503,188, and 836)
Scouting is life. Excel is friend, not foe.
Unread 04-06-2015, 19:37
BenGuy's Avatar
BenGuy BenGuy is offline
Co-Driver - 3641 - Flying Toasters
AKA: Ben
FRC #3641 (The Flying Toasters)
Team Role: Operator
BenGuy is a glorious beacon of lightBenGuy is a glorious beacon of lightBenGuy is a glorious beacon of lightBenGuy is a glorious beacon of lightBenGuy is a glorious beacon of lightBenGuy is a glorious beacon of light
Re: H Drive
Hello, I'm from 3641, we did a different kind of H-Drive. Our system was called a deca drive, this consists of 2 CIMs driving a center gear in the middle of a seesaw type system with two small omni wheels on the ends, connected by gears to the center gear being driven by the CIMs. When power is applied either way, the system throws that side down into the ground (just from the motor's torque) and spins the omni wheel at the same time. If we switch the direction of the motors, the seesaw simply tilts to the other side. When the system is not being used, the seesaw balances even with the bottom of our robot, allowing us to easily go over the scoring platforms. This deca drive worked very well for us in Recycle Rush, and thanks to our four main drive wheels being omnis as well, we were very maneuverable.
Pictures of ours are attached, and a video of robowranglers with a similar system is right here: https://youtu.be/oRwvQ2D_B-c?t=34s
ID:	19070  Click image for larger version
ID:	19071  Click image for larger version
ID:	19072  Click image for larger version
Ben Wolak
The Flying Toasters Website
Team YouTube
Team Twitter
The real problem with computers is that they do what you tell them to do, not what you want them to do.
Unread 04-06-2015, 19:39
BenGuy's Avatar
AKA: Ben
Team Role: Operator
Re: H Drive
Our system, which I explain in my last post, was able to move up and down as far as it needed to get enough pressure to move the robot, whether we were on carpet or foam or solid concrete.
Ben Wolak
Team YouTube
Team Twitter
Unread 04-06-2015, 23:06
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
Re: H Drive
Thanks for the renderings! I like that the swing is clutched to the cluster axle, which causes the wheel on the side that you're accelerating away from to touch the carpet, which should improve traction. I do have a few questions about some of the details:
  • Did you have trouble overshooting your strafes? There does not seem to be any way to properly brake in the strafe direction.
  • The gearing looks rather fast for strafing in Recycle Rush; counting of gear diameters, I get about 8:1 or 9:1. Did you actually use strafing as a means of travel, or just to line up for pickups and scoring? Unless you needed the top speed, you could have made the output cluster gear smaller, pulled the wheels pulled in to match, and probably done as well with one CIM.
  • How do you control the coupling between the seesaw and the cluster shaft, to get the proper wheel loading? Is there a friction clutch between the output cluster gear and the seesaw, or is it just in the bearings, or what?
  • Is there a spring, or does the seesaw return to the horizontal when not driven just based on gravity? Given the amount of friction needed in that bearing, the short offset of the CoG from that shaft, and the large moment of inertia of the seesaw, gravity doesn't appear to be enough.
Unread 04-06-2015, 23:37
Zebra_Fact_Man's Avatar
Zebra_Fact_Man Zebra_Fact_Man is offline
]\/[ Go Blue!
AKA: Solomon
FRC #1076 (Pi Hi Samurai)
Zebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant future
Re: H Drive
Not necessarily; it just depends on how you want to play the game. As you may be able to tell from the pic below, 33 played 2014 with just 4 omnis and did just fine. Didn't even need powered strafe.
They went with the "run from your enemies and be too fast for them to catch you" route.
My Journey in FIRST:
Mentor/Coach/Engineer
2014-2017: Team 1076 - Pi Hi Samurai
____ 2014: Team 5220 - The Rockets
2009-2014: Team 313 - The Bionic Union/Bionic Zebras
Student
2006-2009: Team 313 - The Bionic Union
