Go to Post Dean's "All Denim" (now referred to as "Deanim") look is apparently catching on. - AndyB [more]
Thread Tools Rating: Thread Rating: 6 votes, 5.00 average. Display Modes
  #61   Spotlight this post!
Unread 04-06-2015, 08:14
BrennanB's Avatar
BrennanB BrennanB is offline
TBC is good at getting almost first
AKA: Brennan Bibic
FRC #4476 (W.A.F.F.L.E.S.)
BrennanB has a reputation beyond reputeBrennanB has a reputation beyond reputeBrennanB has a reputation beyond reputeBrennanB has a reputation beyond reputeBrennanB has a reputation beyond reputeBrennanB has a reputation beyond reputeBrennanB has a reputation beyond reputeBrennanB has a reputation beyond reputeBrennanB has a reputation beyond reputeBrennanB has a reputation beyond reputeBrennanB has a reputation beyond repute
Re: State Power Alliances 2015
Originally Posted by Gregor View Post
If 1325 had the weight for one of 1114 or 2056's ramps that would be perfect.
Even if they don't, 2056/1114 make a tote ramp for the one side.
This alliance would put up, say 7 - 6 stacks conservatively. With that number going up to 9 easily, possibly one more.
Brennan Bibic - @b_bibic - Eh-Nalysis
10 years of inspiration compilation - W.A.F.F.L.E.S. #4476 YouTube Channel - 64 events and counting!
FRC 2013-2017 (W.A.F.F.L.E.S. Community Robotics #4476) - FLL 2006-2017 (W.A.F.F.L.E.S. #105) - VRC 2010-2013, 2015-2016 (W.A.F.F.L.E.S. #4476)
FRC 2009-2012 (K-Botics #2809)
Fantasy First 2014-2017 (The Breakfast Company) #TBCWin
2014 Dean's List Finalist
"Work until your idols become your rivals."
  #62   Spotlight this post!
Unread 04-06-2015, 09:05
EmileH's Avatar
EmileH EmileH is offline
uses the Talon SRX way too much
AKA: Emile Hamwey
FRC #1058 (The PVC Pirates) & SLFF (NE Way You Want It)
EmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant future
For Massachusetts:
125: At Champs they could put up 2-3 six stacks from their HP station with their feed-through-the-back-style intake. Also has super fast tennis ball can grabbers in auto.
2877: Another feeder station bot, 2877 can contribute 2 capped and noodled 6-stacks from their feeder station.
246: Landfill bot that can do 1-2 five-stacks capped and can grab 1 can in teleop if needed with their "scorpion" arm.
1768 could replace 2877 as a HP bot and still contribute 2-3 five stacks capped with litter. Also has a center can grabber that grabs 2 cans in auto.
2016-present: High School Student, FRC 1058 PVC Pirates
  #63   Spotlight this post!
Unread 04-06-2015, 13:06
TJP123 TJP123 is offline
AKA: Tom Pospeshil
FRC #0503 (Frog Force)
TJP123 has a brilliant futureTJP123 has a brilliant futureTJP123 has a brilliant futureTJP123 has a brilliant futureTJP123 has a brilliant futureTJP123 has a brilliant futureTJP123 has a brilliant futureTJP123 has a brilliant futureTJP123 has a brilliant futureTJP123 has a brilliant futureTJP123 has a brilliant future
Originally Posted by Bennett548 View Post
I didn't watch much of 67 in St. Louis. If they were able to get reliability up then I would do 1023-548-67.
I might also consider 503 in the third position depending on the landscape of the event. They are the fastest canburglars in MI as far as I know, and if a choke hold strategy is viable then I would pick 1023-548-503.
You're being modest. Until unseated, the crown for fastest in MI goes to 548. The side-by-side in the qualifying match we played together at MICMP was a virtual tie, but you guys were in the hole just ahead of us.
  #64   Spotlight this post!
Unread 04-06-2015, 13:10
carpedav000's Avatar
carpedav000 carpedav000 is offline
Studenting is hard, but worth it!
AKA: David Carpenter
no team (Jerry-Rigg school of DuctTapeology)
carpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant future
Originally Posted by tindleroot View Post
I didn't see 1741, 1720, or 71 at worlds (more than maybe a passing glance), but here's my take:
At ISC, I think personally 1720 was the best, but 71 was a little more consistent (probably why they were picked by 3rd seed 1501). 1741 was definitely the best at getting cans from the step accurately with the claw. As far as worlds goes, it looks like 1720 had the edge again given that they had the highest average of the three teams and seeded 6th in Newton (same division as 1741). For these reasons I feel like 1720 would be the best fit for an Indiana alliance, but that being said I did not see the teams enough at worlds to make the best judgment.
Okay, upon re-watching a lot of match video of all three teams, Ive come to this conclusion (not including can grabbing because all three teams have very accurate 1-can grabbers):
1720- Definitely the best IN landfill bot if you are looking for large amounts of points.
Biggest advantage: Fast tote intake
Biggest disadvantage: slow(ish) lift
Max. scoring ability: 2 36-point stacks
1741- Container specialist that can also stack from landfill
Biggest advantage: Able to cap stacks of 6
Biggest disadvantage: Rear 4-bar arm makes maneuvering the left landfill difficult once stacks start going up.
Max. scoring ability: 1 36 point stack and a stack of 4
71- Very good all-around landfill bot. Most consistent of the three robots
Biggest advantage: Faster lift
Biggest disadvantege: Their containers tend to roll of of their stacks
Max. scoring ability: 1 capped 4-stack and an uncapped stack of 5
  #65   Spotlight this post!
Unread 04-06-2015, 13:28
logank013's Avatar
logank013 logank013 is offline
System.out.println("Ready!");
AKA: Logan Kreisher
FRC #0234 (Cyber Blue)
Team Role: Scout
Rookie Year: 2015
logank013 has a brilliant futurelogank013 has a brilliant futurelogank013 has a brilliant futurelogank013 has a brilliant futurelogank013 has a brilliant futurelogank013 has a brilliant futurelogank013 has a brilliant futurelogank013 has a brilliant futurelogank013 has a brilliant futurelogank013 has a brilliant futurelogank013 has a brilliant future
I definitely agree with this. 1720 was also sort of slow to take the stack to the scoring platform if I remember right. 71 could also usually do 2 4-stacks capped but as you said, if they were not completely still, bins would roll. I know at IN District Championships, 1741 would usually just make 1 stack of 5 with bin and litter and then would usually spend the rest of the time capping everyone else's stacks. I believe that they are definitely capable of what you said they could do but I never saw them do that. I bet that's what they did at worlds.
Cyber Blue Season 2015
IN Indy District Chairman's Award Winner | IN Kokomo District Event Winner (With 135 and 3865)
IN Purdue District Event Winner (With 1024 and 2197) | IN District Championship Winner (With 1024 and 292)
WORLDS:
Archimedes Rank 3 After Quals. | Alliance #3 Captain
Archimedes Division Semi-Finalist (With 503,188, and 836)
Scouting is life. Excel is friend, not foe.
  #66   Spotlight this post!
Unread 04-06-2015, 13:30
logank013's Avatar
AKA: Logan Kreisher
Team Role: Scout
Rookie Year: 2015
I know that we haven't ever seen that alliance but i bet we will see plenty of 9 or 10 stacks at great events like IRI or Chezy Champs. Cant wait to see what these teams do in off season events.
WORLDS:
  #67   Spotlight this post!
Unread 04-06-2015, 13:43
Professional Stat Padder
I think we will see 9 stacks on a field a few times.
We might see 10.
But "plenty" of matches with 9 or 10 stacks on the field is a little crazy, even for IRI or Chezy Champs. That requires you to have three robots on the field each capable of at least 3 stacks that don't interfere with eachother and perform well, and 10 stacks requires one of those robots to be capable of 4 stacks.
10 stacks means every rightside-up non-step grey tote is scored (including your extra HP totes). That's a lot of totes.
(2015-Present)
  #68   Spotlight this post!
Unread 04-06-2015, 13:45
logank013's Avatar
AKA: Logan Kreisher
Team Role: Scout
Rookie Year: 2015
We might see 10.
Yeah. Plenty was the wrong word. I meant that mostly for elims when you have 2 powerhouse teams per alliance and better 2nd and 3rd picks than in divisions at worlds.
WORLDS:
  #69   Spotlight this post!
Unread 04-06-2015, 15:25
Hgree56's Avatar
Hgree56 Hgree56 is offline
AKA: Hunter Greene
FRC #4272 (Maverick Boiler Robotics)
Hgree56 will become famous soon enough
829 was an HP bot though, so they wouldn't mesh well with a 234-1024 alliance.
In their match with 1501 and 5188 at state champs, they played landfill and that was the match to set the high score in Indiana. Although they were best at HF the did do well in the LF
2016 Indiana Tipp. District Industrial Safety Award winner
2016 Indiana Perry M. District QF w/ (3487 & 4580)
2015 Indiana Purdue District Chairman's Award winner
2015 Indiana Indianapolis District QF w/ (5403 & 4008) and Industrial Safety award winner
2015 Indiana Indianapolis, Purdue, and State Champs Industrial Safety Award Winner
2014 Crossroad GP Award Winner
2014 Boilermaker SF w/ (337 & 4213)
  #70   Spotlight this post!
Unread 04-06-2015, 15:33
logank013's Avatar
AKA: Logan Kreisher
Team Role: Scout
Rookie Year: 2015
I must have missed that. I never saw 829 at the landfill... but that'd be cool to see again.
WORLDS:
  #71   Spotlight this post!
Unread 04-06-2015, 15:39
logank013's Avatar
AKA: Logan Kreisher
Team Role: Scout
Rookie Year: 2015
I'll take a shot at IN.
234 - 2 capped 6-stacks from HP station
1024 - see strategy below
1720/1741/71- all would be good for the strategy below, although 71 and 1741 stack slightly faster
Strategy:
234 does their thing and makes their HP stacks, 1024 makes capped and noodled stacks of 2. During this, the alliance landfill bot makes stacks of 4 for 1024 to make 6-stacks out of (1024 already does stack 4 and place 2 and a container on top)
1741 seems like a good match.I didn't think hard on that. Forget 1024 capping. 234 can make 3 full stacks easily out of the hp (1 with bin. other 2 without bins.) then, 1024 makes 2 full stacks with bins. 1741 makes their 5 stack w/ bin and caps 234s other 2 stacks. Easy 246 points with litter in all bins and 20 points for auto if 234 auto works. If it was with 1720, then it would probably only be 5 full stacks and with 71, we would have only five stacks because i would probably want 1024 to cap 71s stacks to make 6 stacks. Never thought about 1741 like that... sounds awesome.
WORLDS:
  #72   Spotlight this post!
Unread 04-06-2015, 17:57
So what Im hearing is... all IN IRI alliance? Also on that note, if that alliance happened during quals at IRI and coop happened + 234's auto , this alliance would score 306.
  #73   Spotlight this post!
Unread 04-06-2015, 18:15
logank013's Avatar
AKA: Logan Kreisher
Team Role: Scout
Rookie Year: 2015
Ready for the schedule to come out... lol. I really am excited to see all the crazy events in the offseason...
WORLDS:
  #74   Spotlight this post!
Unread 04-06-2015, 18:56
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Yes we can landfill but we don't do it well HP is our thing.
I can't believe that you are leaving 447 out of the landfill group.
  #75   Spotlight this post!
Unread 04-06-2015, 18:59
Can you explain why they should be in the landfill group (besides the fact that they are a landfill bot)
