Go to Post ...when you see someone post about something they don’t like, please don’t post another “I’m sick of all this whining” type of post. If you disagree with them, try to offer an intelligent argument back. - Phil 33 [more]
Go Back   Chief Delphi > Technical > CAD
Unread 04-06-2015, 14:11
MasterMentor's Avatar
MasterMentor MasterMentor is offline
TheGreatGonzo
AKA: George Gonzo
MasterMentor will become famous soon enough
SketchUp Field Models
I don't mean to annoy the AutoDesk or SolidWorks purists, but can anyone point me to any FRC Field model resources compatible with SketchUp? I would like to have models of a basic FRC field (both the rectangular and octagonal configurations, if possible, but I'd appreciate either) without game-specific elements.
Thanks!
-MM
"Badges? We ain't got no badges! We don't need no badges! I don't have to show you any stinking badges!"
Unread 04-06-2015, 19:11
gblake's Avatar
gblake gblake is offline
6th Gear Developer; Mentor
AKA: Blake Ross
no team (6th Gear)
Re: SketchUp Field Models
Thanks!
-MM
MAYBE... If you and I are lucky, I can find something from when my buddies and I were doing the 5th Gear FRC game simulations. I'll look.
Unread 04-06-2015, 19:47
gblake's Avatar
AKA: Blake Ross
no team (6th Gear)
I looked through all of my memory sticks, and even a few CDs. I remember doing some SketchUp work for the 5th Gear FRC game simulations; but I came up empty.
I think I stopped using SketchUp because I couldn't successfully import the SketchUp models into SolidWorks (that was a few years ago).
If you want some fairly accurate VEX EDQ (the VRC stuff) part models, I have quite a few of those...
Sorry. Maybe someone else will have what you need.
Blake
Unread 05-06-2015, 00:22
cadandcookies's Avatar
cadandcookies cadandcookies is offline
Director of Programs, GOFIRST
AKA: Nick Aarestad
FTC #9205 (The Iron Maidens)
cadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond repute
To my knowledge there are no official sources of SketchUp models. Your only chance is someone like Blake who might have done it themselves.
A little bit of background on why what you're asking is an issue:
Basically all modern CAD software uses either polygonal meshes or NURBS for how it models solids. It's a bit like vector versus raster graphics, if you're familiar with that. You can convert NURBS surfaces to mesh but the other way is more difficult (well, actually pretty much impossible). NURBS to mesh isn't really any issue with most software that uses NURBS (like Creo, Solidworks, or Inventor)-- in fact, this is what anyone who designs in one of those programs for a 3D printer is doing every time they convert to STL (stereolithography) format and sent that to the printer's software-- but presents an issue to SketchUp, which deals in a format literally nothing else uses and last time I checked doesn't have any sort of control on its export to DWG (which is just about the only "nice" format it deals in last I looked).
The upside to this is that you might be able to use a Creo, Solidworks, or Inventor to convert to a format SketchUp is friendly with and use that. You'd probably either have to do everything individually or try doing the entire model at once and risk some inaccuracies. If you have the Pro version you can import DWG or DXF format, and any of the big three can export to that.
I'm sorry I couldn't be more help, but I tend to avoid SketchUp. Best of luck finding your models! In the worst case, you can use the field drawings to recreate the elements in SketchUp.
Never assume the motives of others are, to them, less noble than yours are to you. - John Perry Barlow
tumblr | twitter
'Snow Problem CAD Files: 2015 2016
MN FTC Field Manager, FTA, CSA, Emcee
FLL Maybe NXT Year (09-10) -> FRC 2220 (11-14) -> FTC 9205(14-?)/FRC 2667 (15-16)
VEXU UMN (2015-??)
Volunteer since 2011
2013 RCA Winner (North Star Regional) (2220)
2016 Connect Award Winner (North Super Regional and World Championship) (9205)
Unread 17-06-2015, 18:11
Whippet's Avatar
Whippet Whippet is offline
MIT Class of 2020
AKA: Luis Trueba
FRC #4301 (New Tech Narcissists)
Whippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond repute
Send a message via Yahoo to Whippet
If you're willing to do a bit of work, this page on the SketchUp 3D Warehouse has a fairly accurate field set up for Logomotion. All you would need to do is remove the Logomotion field elements and you'd have it pretty much set up.
2010: FRC 3043, Build Assistant
2011: FRC 3043, Head of Minibot subteam; FLL 12762, Team Captain
2012: FRC 3043, Electrical; FLL 12762, Team Captain; FTC 5670, Team Captain
2013: FRC 4301, Electrical, Team Co-Captain
2014: FRC 4301, Electrical/Programming, Team Co-Captain
2015: FRC 4301, Electrical/Programming, Team Captain
2016: FRC 4301, Chief Technical Officer; FTC 10860, 10861, and 11004: Mentor. Winner, Hub City Regional (3310 & 4063)
