Go to Post Winning is an outcome, not the whole point. - StephLee [more]
Unread 06-06-2015, 21:16
Rman1923's Avatar
Rman1923 Rman1923 is offline
AKA: Rohan Chatterjee
FRC #1923 (The MidKnight Inventors)
Rman1923 has a reputation beyond reputeRman1923 has a reputation beyond reputeRman1923 has a reputation beyond reputeRman1923 has a reputation beyond reputeRman1923 has a reputation beyond reputeRman1923 has a reputation beyond reputeRman1923 has a reputation beyond reputeRman1923 has a reputation beyond reputeRman1923 has a reputation beyond reputeRman1923 has a reputation beyond reputeRman1923 has a reputation beyond repute
Arduino Micro with Talon SR
Hey all, (This is not for our robot but for a personal project)
So I am trying to connect a Talon SR to an Arduino Micro (With the Leonardo Processor) to power a Mini-Cim. I think I have all the electrical down but I'm not sure how to connect the PWM from the talon to the Arduino. My guess is that I cut the pos and neg wires on the PWM and just connect the white wire (since I already have 12 volts going through the talon). If this isn't how to do it, where should I connect the pos and neg terminal to on the Arduino (or in my circuit)?
Thanks!
My posts do not reflect the values and opinions of my team
Build Co-Captain for The MidKnight Inventors
FLL Mentor for The Robot MasterMinds
FTC Student Mentor for MidKnight Magic
2015 Dean's List Finalist
Unread 06-06-2015, 21:36
Jacob Bendicksen's Avatar
Jacob Bendicksen Jacob Bendicksen is offline
Figuring out what's next
Jacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond repute
Re: Arduino Micro with Talon SR
You do want to connect the positive and negative to the Arduino - negative to a ground pin, positive to (I believe) a 5V pin.
jacobbendicksen.com | @jacobbendicksen
Yale University Class of 2020
Team 1540 | 2012-2016
7 Chairman's Awards, 6 other awards, 2015 Dean's List Finalist, 1 event win, 2 finalist finishes. Thanks for an amazing ride.
Unread 06-06-2015, 21:54
Rman1923's Avatar
Cool, Thanks!
And I'm guessing the White Wire goes to a PWM pin right?
I found this image like ten minutes ago
Unread 06-06-2015, 22:12
teslalab2's Avatar
teslalab2 teslalab2 is offline
RogueBotix LLC
VRC #8091
teslalab2 will become famous soon enoughteslalab2 will become famous soon enough
you don't need the red wire, its not connected to anything inside the talon
I need a jaguar development board for reprogramming a jaguars bootloader. if you have one that you want to sell, pm me. thanks
Run you CanJaguars on arduino with ArduRIO, you can also easily control Talons, Victors,Jaguars and Sparks on PWM. https://sourceforge.net/projects/ardurio/
Unread 06-06-2015, 22:39
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Connect PWM output od Arduino to PWM input of Talon, and connect the twos' grounds.
Not sure about the power wires.
Unread 07-06-2015, 00:45
timytamy's Avatar
timytamy timytamy is offline
AKA: Tim
Team Role: Electrical
timytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant future
There are a myriad of other threads out there that go into detail about connecting motor controllers to Arduinos.
But to get you started, read up on servo PWM, it's not the same thing as the pseudo analogue PWM you get from the PWM pins (with analogueWrite()). You'll probably need the Arduino Servo library to create the appropriate signals for the Talon.
Tim W
FIRST® Team 3132 - The Thunder Down Under
Sydney, Australia
Website | Facebook | Youtube
Unread 07-06-2015, 01:53
teslalab2's Avatar
RogueBotix LLC
VRC #8091
When you are writing the pwm signal make sure neutral = 47, 74 = full forward, 20 = full reverse. These are the correct values the controllers expect, otherwise you will have to re-calibrate the controllers for them to work properly.
Unread 07-06-2015, 22:55
Rman1923's Avatar
Thanks All, I figured it out, you have to connect the red to the VCC (5V or 3.3V depending on the board) black to ground and then the white one to a PWM pin. I used the Servo library and read the vals from a potentiameter and fed them to the talon during calibration. Now if i could get the underglow working...
Unread 08-06-2015, 00:39
AdamHeard's Avatar
Lead Mentor
I'd skip the servo function and instead use servo.writeMicroseconds.
Cleaner control numerically.
1000 is rev, 1500 neutral, 2000 forward.
Unread 08-06-2015, 02:04
gblake's Avatar
gblake gblake is offline
6th Gear Developer; Mentor
AKA: Blake Ross
no team (6th Gear)
These are nitpicks ... (everyone's a critic )
Servo.writeMicroseconds() is a function in the Servo library, and not a substitute for that library.
And, I think the Talon has a max/min pulse range larger than 1500+/-500.
Read the Talon's fine manuals (easily found using a Google search) to see wiring and pulse range information.
FYI: I'm using an Edison Arduino in a project, and having pretty good luck so far. I have worked around the one WiFi bug that was giving me trouble, and I don't have any other show-stoppers on the horizon (yet). At about $100, it gives you built-in WiFi, and a lot of computing bang for your buck, in situations where Arduino-style I/O is useful. Consider using one in your next project....
Blake
Unread 08-06-2015, 07:35
GeeTwo's Avatar
GeeTwo GeeTwo is online now
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
I don't agree here at all. If you have a working, well tested abstraction that does exactly what you want it to do but can be easily adjusted if the parameters are just a bit off, and you have enough resources to implement it, why would you work around it?
Unread 08-06-2015, 12:49
AdamHeard's Avatar
Lead Mentor
You're missing what I'm saying. servo.write() takes 0 to 180 degrees as an input and controls a "Servo". servo.writeMicroseconds() explicitly takes the pulse you would like to generate, which for a talon is 1000-2000 w/ 1500 at center. This leaves you a nice +/- 500 integer swing for clean math.
Unread 08-06-2015, 13:07
Joining the 900 Meme Team
FRC #0079
Arduino also has a really handy little map function even in the case of ugly math.
Unread 08-06-2015, 14:27
Rman1923's Avatar
Does anyone know how to calibrate the SR so it doesn't go reverse, I'm making an electric skateboard and don't plan to parallel park.
Unread 08-06-2015, 16:04
EmileH's Avatar
EmileH EmileH is offline
#dontbelarge
AKA: Emile Hamwey
FRC #1058 (The PVC Pirates) & SLFF (NE Way You Want It)
EmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant future
Here are the calibration instructions from per 7 of this document.
6) Calibration
The calibration procedure takes the minimum, maximum and center
values of the PWM input signal and scales the output based on these
values. Calibrating the Talon will allow full range of control with PWM
signals that are not within the default range. Calibrating will also
correct any non-center issues with input devices such as gamepads
or joysticks.
To calibrate the Talon:
1. Press and hold the button labeled “CAL” with a paper clip. The
LED should begin to blink red/green.
2. Continue to keep the button pressed while moving the joystick
full forward and full reverse. You may do this as many times as
you like.
3. Center the joystick and then release the CAL button.
4. If calibration was successful, the LED will blink green several
times. If the LED blinks red several times, the calibration was
not valid. If this happens, the Talon will use the last valid
calibration values.
All calibration values are retained after power cycle or reset.
2016-present: High School Student, FRC 1058 PVC Pirates
