Go to Post OK, I may have heavily influenced their decision, but I would never kill a mentor for not choosing an event I was planning... maim maybe, but never kill! :D - KathieK [more]
Unread 08-06-2015, 16:19
Re: Arduino Micro with Talon SR
Originally Posted by Rman1923 View Post
Does anyone know how to calibrate the SR so it doesn't go reverse, I'm making an electric skateboard and don't plan to parallel park.
You can't "calibrate" it to only go one direction. If you try giving it only forward commands while calibrating it, the procedure will fail and the calibration will not be changed. The Talon SR doesn't have limit switch inputs, so the simple option of permanently activating the "reverse" limit is not available either.
The obvious answer is just to only send it "forward" commands, using pulse widths between 1.5 and 2.0 milliseconds. Never give it anything less than 1.5 milliseconds, and it will never go in reverse.
