Go to Post Last year we saved a ton of money by using a good bit of square tubing for the frame of our robot, square tubing is a lot cheaper then C channel. We get to use so much raw material that the cost should go down in certain places. - Derrick Maust [more]
Unread 08-06-2015, 18:38
Qbot2640's Avatar
Qbot2640 Qbot2640 is offline
AKA: Terry McHugh
FRC #2640 (Hotbotz)
Qbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond repute
Re: Operating two Robots Simultaneously
Originally Posted by Alan Anderson View Post
If you're going to do it by changing the team number, you must change the number on the [robo/c]RIO as well. But that's not the easiest or most reasonable way to do it. It's best to keep the team number consistent. The only thing you need to do is to make sure the SSIDs on the D-Links are different. That way you can connect the appropriate Driver Station computer to each robot. With the two robots' networks thus separated, there is no interference.
We have done this before, and I am fairly certain we did not do anything significant to the c-RIO. In 2014 we used our 2013 robot to practice defense, and after the 2012 season we used our 2011 robot in demos to load balls into 2012.
That being said - I would much rather do this without having to change the team number, and what you're recommending sounds easy.
We've always used a distinctive SSID on each robot's access point. It's easy to do. Just log into the D-Link's admin web page and change it to something that identifies that particular robot. Then you can connect your driver station computer to the wireless network corresponding to the robot you want to control.
Once again...please don't judge, but I have no idea what an SSID is. It's sounding like you want me to pull up the configuration page on the D-Link, not make my change by using the FRC bridge configuration tool. I've never done that, are there instruction somewhere for what you recommend?
Originally Posted by FrankJ View Post
The IP of the dlink really doesn't matter unless you need to connect to its web page. The address range of the DHCP is important if you are not running static IPs. For the RoboRio bot make sure the DHCP is turned on and set for the correct range. Just changing the IP of the dlink will not do this. The Week zero page of screensteps is a good read for the Crio. The IP of the driver station for the crios needs to be 10.te.am.xx where the te.am. matches the CRio.
I'll look at the link you recommend...does this have instructions that will get someone who hates, and is awful at network configuration stuff, through the process? Like with "SSID" I have no idea what "DHCP" is either...remember...I'm the mechanical guy trying to fill a gap left by the loss of our programming mentor.
2012 Palmetto Regional Winners (Thanks 2059, 2815, and 287).
2012 Newton 14th Seed
2013 Chesapeake Regional Imagery Award Winners
2014 North Carolina Regional Imagery Award Winners
2014 Greater DC Regional Team Spirit Award Winners
2015 North Carolina Regional Finalists (Thanks 3971 and 587)
Unread 08-06-2015, 19:54
SSID is what the network is seen as by other wireless devices that are looking for networks. Example, FRC1234 is an SSID that team 1234 would be using on the competition field while competing. Home router networks are often nicknamed "linksys" or "netgear" or something creative. Hotel wireless is often the name of the hotel. I know that 1197 has one of their robots (last summer's practice base) SSID'd as "Smooth Jazz" for some reason that I can't recall.
Now, how to change it I'm not entirely sure, but I think it is the D-Link's configuration page.
Unread 08-06-2015, 21:19
Here's the SSID setup for Netgear WPN824. I assume other routers have something similar in their config setup.
Name:	SSID Netgear WPN824v3.jpg
Unread 09-06-2015, 11:53
First you can start by setting up your DLink using the FRC Bridge Utility if you aren't sure what state it was last left in.
It also gives you a known starting point at any time if you feel that something may have been messed up.
Changing the DLink SSID:
  1. Change your PC Ethernet IP address to 10.26.40.5 solely to be compatible with logging into the DLink. Remember the original settings so you can set it back later. (see addendum below if you've never done this before)
  2. Connect directly to the powered DLink via Ethernet cable
  3. Browse using Internet Explorer to 10.26.40.1 and you should see the DLink login page
  4. Default user is Admin/(leave password blank)
  5. Click on Wireless Settings on the DLink homepage from a short list on the left hand side (seen highlighted also in attached image).
  6. (Attached is a picture of the page you should have up now)
  7. Change the SSID line (highlighted) to something unique like the name of the robot.
  8. Click Save Settings at the bottom of the page.
  9. Disconnect DLink and repeat on the next robot's DLink using a different unique SSID name.
  10. Disconnect and reset your PC's network adaptor to normal.
Addendum on changing PC's IP address:
  1. Left-click on the PC's START button (lower left of the desktop)
  2. Use the search box there to type in Network
  3. Choose Network and Sharing Center from the resulting list of finds.
  4. Left-click on Change adaptor settings in the upper left sidebar.
  5. Right-click on Local Area Connection and choose Properties
  6. Double-click on the list entry Internet Protocol Version 4 (TCP/IPv4)
  7. Select Use the following IP address
  8. Enter 10.26.40.5
  9. Click in the netmask area and you will get a default netmask (just use that)
  10. Click OK at the bottom of the pop-up window
  11. Click OK at the bottom of the previous pop-up window
