Go to Post Being the GDC is not an easy job, anything can happen. Lunacy happened ::rtm:: - Conor Ryan [more]
Unread 08-06-2015, 19:30
teslalab2's Avatar
teslalab2 teslalab2 is offline
RogueBotix LLC
VRC #8091
teslalab2 will become famous soon enoughteslalab2 will become famous soon enough
Re: Building a RogueBot!
Not to worry ya people There is a 20 amp fuse in series with the switch under the switch in the box. and btw you'd be surprised what a light switch can take... I used a light switch to shut off the power supply for my capacitor bank before it fires, the power supply is 4 microwave oven transformers which draw roughly 12amp a piece, and the switch never failed, even after a lot of use. But I understand your cringing and concern for safety.
I need a jaguar development board for reprogramming a jaguars bootloader. if you have one that you want to sell, pm me. thanks
Run you CanJaguars on arduino with ArduRIO, you can also easily control Talons, Victors,Jaguars and Sparks on PWM. https://sourceforge.net/projects/ardurio/
