Go to Post If there's one bit of advice I can give, its never underestimate the power of a hurricane. - Joshua May [more]
Unread 09-06-2015, 07:09
Scorpio01 Scorpio01 is offline
Scorpio01 is an unknown quantity at this point
HOW TO CHANGE LISTBOX TO LABELS
Please I need help.
I want to select a text inside a listbox and then display a description about that slected text in a labelform.
Example if I select 'Delphi' in the list box then it should display a label saying 'Programming'.
Label1.Caption := Listbox1.Items.strings[ListBox1.itemindex] only displays the word 'Delphi' once I select it.
PLEASE any one
Unread 09-06-2015, 08:01
Re: HOW TO CHANGE LISTBOX TO LABELS
Is this a question about the Delphi programming language? It's possible that someone here can help you, but you have misunderstood the purpose of these forums. This participants here are involved in a robotics competition program and its parent organization called FIRST. The name "Delphi" in "Chief Delphi" refers to one of the team sponsors, not to the language.
Unread 09-06-2015, 08:14
Thanks Alan for your response.
Unread 09-06-2015, 09:35
Monochron's Avatar
Monochron Monochron is offline
Engineering Mentor
AKA: Brian O'Sullivan
FRC #4561 (TerrorBytes)
Monochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond repute
I think the Embarcadero forums would be a better place for help. There is a good C++ Builder and Delphi support group there.
