Go to Post 2004 qualifies as vintage now? Ugh. - Lil' Lavery [more]
Thread Tools Rating: Thread Rating: 7 votes, 5.00 average. Display Modes
  #31   Spotlight this post!
Unread 03-06-2015, 04:31
DampRobot's Avatar
Physics Major
AKA: Roger Romani
Re: Fantasy Product's-what u wish was made
You know... Y'all are learning engineering. I'm aware that AM at least will take design ideas from teams (they've done it in the past).
So... You want something to be a COTS offering, how about you make a prototype, do a bit of market research, and see about making a deal with the appropriate company?
Just a thought.
I've talked with some people that did this and actually got their product to market. I know that they learned an absolute ton, and enjoyed the experience of developing the product, but from a financial perspective really got screwed over by the company they were working with. It sounded like a learning experience, both in design and business skills.
To people commenting on this thread, if you really want something, go ahead and design a product that's suitable for mass mfg (injection molding, extrusion, minimum mill passes, etc), estimate how much it might cost, and see if there's any money to be made. If there is, draw up a solid business plan (why teams need it, how much it will cost, how much investment it will take, how much money there is to be made, etc), and talk to people. If it really will make them money, businesses will sometimes listen.
-Plutarch
  #32   Spotlight this post!
Unread 03-06-2015, 14:02
Monochron's Avatar
Monochron Monochron is online now
Engineering Mentor
AKA: Brian O'Sullivan
FRC #4561 (TerrorBytes)
Monochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond repute
Originally Posted by Pault View Post
Step 1: Drill a 1/4in hole 3/4in deep into the center of the output shaft
Step 2: Use a hacksaw to cut down the center of the shaft to the same depth as the hole.
Step 3: Assemble VersaPlanetary and mount onto robot.
Step 3: Put a 1/2in hex shaft collar around the end of the shaft.
Step 4: Cut a piece of thin polycarb and drill a 3/8in hole near one end.
Step 5: Use a nut to screw an incremental encoder, absolute encoder, single turn potentiometer*, or 10 turn potentiometer into the hole in the polycarb.
Step 6: Insert shaft of sensor into hole in the output shaft.
Step 7: Tighten shaft collar.
Step 8: Attach the loose end of the polycarb to any nearby piece of the robot.
Step 1: Assemble VersaPlanetary with "VersaEncoder Stage" and mount on robot.
Done.
This also has the benefit of not requiring a male style encoder as in your method. The downside is, I imagine you would be stuck with whatever kind of encoder Vex wanted to use.
  #33   Spotlight this post!
Unread 06-06-2015, 14:43
Everett33's Avatar
Everett33 Everett33 is offline
AKA: Everett Owen
FRC #2145 (HAZMAT)
Everett33 is on a distinguished road
Originally Posted by marshall View Post
Can you provide pictures for this?
Personally, I'd rather see more integrated options made available to teams than us using the same old hacks to make our existing solutions work. Yes, they work, but they aren't pretty. I think I have a good idea of what you are describing and the encoder/sensor being exposed is still the biggest problem for longevity (read: durability).
Here is a photo of a very clean example of mounting an encoder in this manner. You are basically using the end of the shaft as a collet. Very ingenious and easy to do with the simplest of tools.
https://www.flickr.com/photos/joseph...7649689515713/
- Everett
I walk the pits of FIM and take cool robot photos.
•Lead Driver 2009-2013 •Mechanical Mentor 2014-2015
•Record of 6-2
  #34   Spotlight this post!
Unread 09-06-2015, 13:40
nuclearnerd's Avatar
nuclearnerd nuclearnerd is offline
Speaking for myself, not my team
AKA: Brendan Simons
FRC #5406 (Celt-X)
nuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant future
Here's a new one: Hardware to make 1" tube an FRC "standard" for drive shafts.
Currently 1/2" hex bar is very popular for torque carrying shafts because it's common to many FRC parts. Unfortunately, you quickly find that 1/2" 7075 aluminum is pretty flimsy if you overhang the load by more than an inch or so, or if the angle of twist is important. A 1" OD x 1/16" wall aluminum tube is easy to source, about the same weight as 1/2" hex, 2.5 times as stiff in bending and torsion, fits through a 1.125" bore wheel*. Thicker tube can be used for even higher stiffness and strength. There are also plenty of lightweight pillowblock bearings available for 1" shafts.
If someone made a two piece hub that clamped tightly enough on a 1" tube to transfer torque, and had a 1/2" hex bore and/or a versahub/AM bolt pattern, it would enable teams to use 1" tubes for drive shafts where the loads would twist 1/2" hex bar (dual chain lifts, four bar linkages, roller intakes etc).
...and go.
*Vex Wheels anyway. AM HiGrip wheels are actually 0.96" bore at their smallest, so they wouldn't work on the shaft without modification
Last edited by nuclearnerd : 09-06-2015 at 13:50. Reason: Added link to Igus bearings for 1" shafts
  #35   Spotlight this post!
Unread 09-06-2015, 14:03
marshall's Avatar
marshall marshall is offline
FRC #0900 (The Zebracorns)
...and go.
As a team that does absolutely terrible things to gearboxes and output shafts with overhung loags, we would totally buy these and likely in large quantities.
  #36   Spotlight this post!
Unread 09-06-2015, 14:04
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
The same thing I've answered on surveys the past couple years: cycloidal gearboxes. Would be the biggest game changer in FRC design since COTS planetaries became common.
Also, more support for keyed round shaft. The constant shortage of hex bearings and not having a hex broach can be quite a pain. We do just fine with keyed shaft, but more and more new products come with hex output shafts.
  #37   Spotlight this post!
Unread 09-06-2015, 14:37
thatprogrammer's Avatar
thatprogrammer thatprogrammer is offline
AKA: Ahad Bawany
no team (None)
thatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond repute
1. A thunderhex with a standarized hub size, as well as bearings with proper mounting plates.
2. A gearbox with a modular case of some sort.
3. A special versaframe optimized for belt or chain in tube drive systems.
  #38   Spotlight this post!
Unread 09-06-2015, 14:44
Munchskull's Avatar
Munchskull Munchskull is offline
CAD Designer/ Electrical Consaltant
AKA: Anthony Cardinali
FRC #0997 (Spartan Robotics)
Team Role: CAD
Munchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to behold
I know that my team actually did develop a product that we would he loved to market how ever we got stuck in case manufacturering. Now that we have cnc we can finally look in to reviving the project.
It was something we called a supertester. An electrical testing device we designed. I know we sold one kit in the past to 971.
“In theory, theory and practice are the same. In practice, they are not.” ― Anonymous
Anthony Cardinali
4th year of FRC
Class of 2017
