Go to Post Another team update, another change in the definition of a rope - Hallry [more]
Unread 08-06-2015, 16:15
Re: Arduino Micro with Talon SR
Originally Posted by Rman1923 View Post
Does anyone know how to calibrate the SR so it doesn't go reverse
Originally Posted by emileh3467 View Post
Here are the calibration instructions...
So, using the instructions you posted, how would you propose to "calibrate the SR so it doesn't go reverse" ?
Unread 08-06-2015, 16:19
Does anyone know how to calibrate the SR so it doesn't go reverse, I'm making an electric skateboard and don't plan to parallel park.
You can't "calibrate" it to only go one direction. If you try giving it only forward commands while calibrating it, the procedure will fail and the calibration will not be changed. The Talon SR doesn't have limit switch inputs, so the simple option of permanently activating the "reverse" limit is not available either.
The obvious answer is just to only send it "forward" commands, using pulse widths between 1.5 and 2.0 milliseconds. Never give it anything less than 1.5 milliseconds, and it will never go in reverse.
Unread 08-06-2015, 16:26
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
I'd skip the servo function and instead use servo.writeMicroseconds.
Cleaner control numerically.
1000 is rev, 1500 neutral, 2000 forward.
You're missing what I'm saying. servo.write() takes 0 to 180 degrees as an input and controls a "Servo". servo.writeMicroseconds() explicitly takes the pulse you would like to generate, which for a talon is 1000-2000 w/ 1500 at center. This leaves you a nice +/- 500 integer swing for clean math.
This is my experience as well. I do it this way because I get higher resolution of the command signal. It allows more precise control of the motor or servo.
Now, if you only need +/- 90 steps instead of +/- 500, then using servo.writeMicroseconds has no advantage.
Unread 08-06-2015, 16:59
Joining the 900 Meme Team
FRC #0079
Does the Talon actually respond with that granularity? I recall seeing a post years back about the old Vic 884s that basically said they only had 90-odd actual values and the rest were just duplicates.
Unread 08-06-2015, 17:38
AdamHeard's Avatar
Lead Mentor
I'm looking now and not finding where I read this (so it may be false), but I believe the talons interpret the pwm input as a 10 bit number, so roughly 1:1 mapping over that 1000-2000 range.
Unread 08-06-2015, 18:22
josesantos's Avatar
josesantos josesantos is offline
Mentor; Former Design Chairman
FRC #0687 (Nerd Herd) (VRC #687z) & FRC #5499 (BHS Robotics)
josesantos has a reputation beyond reputejosesantos has a reputation beyond reputejosesantos has a reputation beyond reputejosesantos has a reputation beyond reputejosesantos has a reputation beyond reputejosesantos has a reputation beyond reputejosesantos has a reputation beyond reputejosesantos has a reputation beyond reputejosesantos has a reputation beyond reputejosesantos has a reputation beyond reputejosesantos has a reputation beyond repute
Yeah, user manual says 10-bit (1024 steps)
CAMS Robotics, FIRST Team 687 The Nerd Herd 2010-Present
College Mentor 2013-Present // Design Chairman 2012-2013
Berkeley High Robotics, FIRST Team 5499 2014-Present
College Mentor 2014-Present
Unread 09-06-2015, 17:19
SuperBK's Avatar
SuperBK SuperBK is offline
AKA: BrianK
FRC #1225 (Amperage Robotics)
You can also specify the servo min and max pulse widths in the attach call:
Servo driveServo;
driveServo.attach(3, 1000, 2000); // TALON // widths are in micro-seconds
Then use servo.Write() 0 is reverse, 90 is stop, and 180 is full forward.
I would still calibrate the Talon (or other motor controller) to ensure it goes full speed. Write an arduino sketch that starts at neutral and waits for a character to arrive from the serial port. Then have it switch to servo to full speed forward, wait for another character and then go full reverse. After waiting for another character, go to neutral. Use Serial.Print to tell the user whats going on and prompt for a character. If you use the serial port monitor in the arduino IDE, you will have to click the "Send" button after each key.
One other thing: I put a 330 ohm resistor in series with the white wire driving the PWM input on the Talon so it doesn't try to drive too much current through its input opto-isolator.
Brian K
Team 1225 Robotics Mentor
Unread 09-06-2015, 17:34
AdamHeard's Avatar
Lead Mentor
Servo driveServo;
Why do this versus explicitly writing the 1000 to 2000 range?
Unread 09-06-2015, 18:00
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
If you were using something other than a Talon, you would only have to change the initial attach call; the rest of the code wouldn't need to be modified. For example, a jaguar would be attached with:
driveServo.attach(3, 670, 2330); // Jaguar
Of course, for a motor controller, you'd ideally like the input limits to be a float ranging from -1 to +1.
Rman1923's Avatar
Rman1923 Rman1923 is offline
AKA: Rohan Chatterjee
FRC #1923 (The MidKnight Inventors)
Rman1923 has a reputation beyond reputeRman1923 has a reputation beyond reputeRman1923 has a reputation beyond reputeRman1923 has a reputation beyond reputeRman1923 has a reputation beyond reputeRman1923 has a reputation beyond reputeRman1923 has a reputation beyond reputeRman1923 has a reputation beyond reputeRman1923 has a reputation beyond reputeRman1923 has a reputation beyond reputeRman1923 has a reputation beyond repute
Servo driveServo;
This is pretty cool, I'm going to try this. Do you think if I mod the servo call to attach(1500,2000) it will only go forward? Also, I can just do the digitalwrite() function to control this right?
Thanks!
My posts do not reflect the values and opinions of my team
Build Co-Captain for The MidKnight Inventors
FLL Mentor for The Robot MasterMinds
FTC Student Mentor for MidKnight Magic
2015 Dean's List Finalist
Unread 09-06-2015, 19:23
AdamHeard's Avatar
Lead Mentor
Depending on how fast all this is running (and what else is going on) using floats may be out of the question due to the slower math.
Unread 09-06-2015, 20:56
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
I did say ideally!
I'm fully aware of the need to program for integers in some cases. I even wrote a fully integer semi-swerve drive inverse kinematics a few years ago. My semi-swerve platform was about 1/3 FRC scale, with a 0-180 degree maximum steering angle steered by servos, and 25mm 1000rpm gear motors for drive, and yes, it was controlled with an Arduino. Unfortunately, the only hard drive that the code was on has since died. The key was that I wrote a hypoti(x,y) subroutine that calculated an integer hypotenuse using max(x, y) and the ratio 256 * min(x,y) / max(x,y) (where x and y were preprocessed to be non-negative), and an atan2id(y,x) that returned atan2(y,x) in degrees based on the same ratio, whether abs(x) or abs(y) was larger, and the two input signs. IIRC, the atan2id() routine had two separate cubic fits to cover the span from 0 to 45 degrees, that broke based on whether 2*min(x,y)/max(x,y) was 0 or 1 (that is, at about 28.8 degrees).
Unread 13-06-2015, 01:37
teslalab2's Avatar
teslalab2 teslalab2 is offline
RogueBotix LLC
VRC #8091
teslalab2 will become famous soon enoughteslalab2 will become famous soon enough
Thanks All, I figured it out, you have to connect the red to the VCC (5V or 3.3V depending on the board) black to ground and then the white one to a PWM pin. I used the Servo library and read the vals from a potentiameter and fed them to the talon during calibration. Now if i could get the underglow working...
you don't believe me when I say power is not connected to anything? just trying to save trouble, it really only needs signal and ground. red serves no purpose and is no internally hooked up to anything inside that talon
I need a jaguar development board for reprogramming a jaguars bootloader. if you have one that you want to sell, pm me. thanks
Run you CanJaguars on arduino with ArduRIO, you can also easily control Talons, Victors,Jaguars and Sparks on PWM. https://sourceforge.net/projects/ardurio/
Unread 13-06-2015, 23:30
Rman1923's Avatar
Actually, I had it set up without red, but then the talon didn't work. The PWM powers as well as controls the talon. The talon is not (and can't be) powered by the input voltage. It confused me at first as well lol.
Unread 14-06-2015, 17:16
Unless your Talon differs from every one I have ever seen, you are mistaken. The center pin on the Talon's PWM connector is not connected to anything inside it. The Talons (and Victors, and Jaguars) are indeed powered by the same input voltage that is routed (and regulated) to the motor outputs.
