Go to Post GP and the Scout Law are high ideals that only the best will achieve and live everyday. - Al Skierkiewicz [more]
Unread 11-06-2015, 12:31
IKE's Avatar
IKE IKE is offline
Not so Custom User Title
AKA: Isaac Rife
no team (N/A)
Re: Gearbox for mechanism or appendage
500:1 is probably a bit slow if the plan is to mate it to a CIM motor. At free speed, it would go down to 9 RPM or about 7 seconds per revolution. At peak power, it would be about 13 seconds per revolution. An arm sweeping 120 degrees would be between 2.5 and 4 seconds which would seem pretty slow.
The 125:1 & 250:1 arms have me pretty intrigued.
Are you measuring efficiency as "Actual speed / theoretical free speed"?
Richard Wallace and some others might be able to help you with a more accurate efficiency method that you could do.
A string and spool winch with a weight and stopwatch could probably be pretty effective way of measuring efficiency at several torque levels.
