Go to Post ... the real mark of integrity is doing the right thing even when nobody is watching. - DonRotolo [more]
Unread 13-06-2015, 01:37
teslalab2's Avatar
teslalab2 teslalab2 is offline
RogueBotix LLC
VRC #8091
teslalab2 will become famous soon enoughteslalab2 will become famous soon enough
Re: Arduino Micro with Talon SR
Originally Posted by Rman1923 View Post
Thanks All, I figured it out, you have to connect the red to the VCC (5V or 3.3V depending on the board) black to ground and then the white one to a PWM pin. I used the Servo library and read the vals from a potentiameter and fed them to the talon during calibration. Now if i could get the underglow working...
you don't believe me when I say power is not connected to anything? just trying to save trouble, it really only needs signal and ground. red serves no purpose and is no internally hooked up to anything inside that talon
I need a jaguar development board for reprogramming a jaguars bootloader. if you have one that you want to sell, pm me. thanks
Run you CanJaguars on arduino with ArduRIO, you can also easily control Talons, Victors,Jaguars and Sparks on PWM. https://sourceforge.net/projects/ardurio/
