Go to Post But he who has deeper insight realizes that concepts and ideas canot be contained in even the largest jar, bucket or box. You cannot touch or see these things, but you can be enhanced with knowledge and experience of them. - sanddrag [more]
Unread 14-06-2015, 01:20
ImMoMo's Avatar
ImMoMo ImMoMo is offline
AKA: Mo
FRC #2559 (Normality Zero)
ImMoMo is an unknown quantity at this point
TalonSRX Fried?
Hello,
While I was prototyping a off-season build, I had two TalonSRX's hooked up to standard 12v motors, I uploaded the code to the roboRIO, tested tank drive, and noticed that one of the motors stopped moving, upon further inspection, I had discover the m- and m+ leads of the Talon had touched..
I used alligator clips for connection testing, but that was really bad idea since they touched....
Anyway, the SRX won't display any lights now, and makes a crackling noise every time I reset the circuit. Is it safe to assume it's fried?
Unread 14-06-2015, 10:24
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: TalonSRX Fried?
It would certainly be unsafe to assume anything else.
While I'm not familiar with the specific internals of the Talon, putting a dead short on the output of a power amplifier is a death sentence for the amplifier unless there's specific protection designed in to do an immediate cutoff. Snap action breakers are specifically designed not to cutoff immediately, otherwise we'd trip them with the current spike as a DC motor is started up. Those breakers can do a fair job of protecting wires in which heat is generated over a long run, but not the amplifier electronics where power is switched in a small package. Even at that, we have fried several feet of supply-side wire when we shorted motor controller inputs.
Unread 14-06-2015, 14:19
pastelpony's Avatar
pastelpony pastelpony is offline
Programmer/Electrical
AKA: Zach M
FRC #3525 (Nuts and Bolts of Fury)
pastelpony will become famous soon enough
Re: TalonSRX Fried?
We did lose a Talon SR to that. I'm not sure how similar the two are, though I wouldn't surprised if it was dead.
Team 3525 Head Programmer (2014- ) - Java (Formerly LabVIEW)
