Go to Post Cant get hair and nails done and still run a robot. - wendymom [more]
View Poll Results: What Drive Style do you use?
Tank Drive 32 52.46%
Arcade Drive 17 27.87%
Other 12 19.67%
Voters: 61. You may not vote on this poll
Unread 14-06-2015, 10:37
GeeTwo's Avatar
GeeTwo GeeTwo is online now
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: Tank Drive VS Arcade Drive on a Skid-Steer Platform
Originally Posted by AustinSchuh View Post
Cheezy Drive is split arcade on steroids.
adjusted_wheel = SensitivityRemap(wheel);
Vl = throttle + adjusted_wheel * abs(throttle) + inertia compensation terms;
Vr = throttle - adjusted_wheel * abs(throttle) - inertia compensation terms;
Not knowing the details of SensitivityRemap(wheel), or even what "wheel" is in this context, I can't be certain, but it sounds similar the 3-axis joystick control I did for a tiny swerve drive robot a few years back. The X/Y joystick controlled translational motion. The Z "twist" axis controlled rotation -- not in terms of angular speed (RPM), but in terms of curvature. That is, the radius of curvature was inversely proportional to the amount of twist on the joystick. I did not use any inertia compensation terms.
This setup also had an override for spinning, as Thad decribes. When both X and Y were in the dead band, Z was interpreted in terms of desired angular speed.
