Go to Post What's a pirate's favorite robotics tournament? Aye-arrrrrrrrrr-aye, matey! - John Wanninger [more]
Go Back   Chief Delphi > Other > Math and Science
Unread 16-06-2015, 18:31
bending a new hook on a spring
Hey Chief Delphi, need your opinion.
I've got a tension spring with a worn hook. I was thinking of cutting the hook off at the long end (no problem) and bending a new one (??).
Do ya think the steel will bend OK, or break?
Unread 16-06-2015, 20:19
Re: bending a new hook on a spring
Neither. It's spring steel, so it'll spring back.
Kidding aside, it depends largely on how you bend it. If you were to bend it without heating, I'd put the odds of reduced life pretty high--but it's not as likely to break as you might think. But that bend isn't going to be easy without heat. Heating... well, I think you're as well aware as I am that heating isn't going to leave the desirable properties of the material alone.
And then you have the additional headache: is the reduced length going to cause extra tension in the system that the spring goes into?
Unread 16-06-2015, 20:20
gblake's Avatar
gblake gblake is offline
6th Gear Developer; Mentor
AKA: Blake Ross
no team (6th Gear)
When I have tried in the past, my results were generally poor.
Unread 16-06-2015, 20:23
Mr V's Avatar
Mr V Mr V is offline
FRC #5588 (Reign)
You'll want to heat the end cherry red before forming it into the new hook. On the other hand a good independent hardware store will have a selection of a couple of hundred springs, one of which should do the trick for a dollar or so.
Unread 16-06-2015, 20:24
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
Remember Hooke's Law, especially regarding the length of wire you use to form the hook.
Richard Wallace
since 2003
Unread 16-06-2015, 20:42
Yeah, I'll add an S hook to make the tension correct.
The spring is from my 18-year-old Whirlpool washing machine. So I guess it has a good 20 years left on it right?
Unread 16-06-2015, 21:00
I thought that spring looked familiar. Maybe I can dig one up around here somewhere.
Richard Wallace
since 2003
Unread 16-06-2015, 21:01
You are a saint. Washer model LSC8244EQ.
Unread 17-06-2015, 03:50
msaunders msaunders is offline
AKA: Mike Saunders
msaunders is just really nicemsaunders is just really nicemsaunders is just really nicemsaunders is just really nicemsaunders is just really nice
Perhaps this is the one, if Richard cannot supply one.
http://www.repairclinic.com/PartDeta...d111988&mr= 1
Fortunately I only live a couple miles away from their location so I do not have to pay shipping when I need parts.
-= 862 =- Lightning Robotics, Canton, MI
2015 FiM Bedford District Chairman's Award
2014 FiM Bedford District Winner
2013 12th seed, Curie Division Winner with 1678 and 148
2013 Michigan State Championship Entrepreneurship Award
2013 FiM West Michigan District Winner, Engineering Inspiration Award
2013 FiM Kettering District Winner, Engineering Inspiration Award
Unread 17-06-2015, 10:59
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
The trick will be bending it. The straight portion has not been plastically deformed so it should have all of its ductility left. Putting the same radius bend as the original hook shouldn't break it.
Unread 19-06-2015, 12:16
After some searching I have found two springs. One is stronger than the other (thicker wire). See attached. Is one of them a match for yours?
Richard Wallace
since 2003
Unread 19-06-2015, 12:48
I had to put the machine back in service temporarily for the weekend laundry.
I'll open it up early next week and put the calipers on the wire.
Thanks.
Unread 19-06-2015, 18:51
Michael Hill's Avatar
I don't mean to be daft, but how does a single model of washer get associated with two nearly identical springs where the only difference is 0.2mm in diameter? Is it the same part, just for a later model after fixing something? Are parts in washing machines so fickle they can't be interchanged with each other?
Unread 19-06-2015, 19:20
That's not the way I interpreted it.
The two springs Richard found are unmarked and he wants to know which is the correct one for my washer.
I assumed the other spring is for a washer with a lighter (smaller) or heavier (larger) tub.
Unread 19-06-2015, 20:25
Gotcha. I assumed he looked it up in some database and both were returned as possible.
