Go to Post mama always said better safe than sorry - Brandon Holley [more]
Go Back   Chief Delphi > Other > Math and Science
Unread 17-06-2015, 03:50
msaunders msaunders is offline
AKA: Mike Saunders
msaunders is just really nicemsaunders is just really nicemsaunders is just really nicemsaunders is just really nicemsaunders is just really nice
Re: bending a new hook on a spring
Perhaps this is the one, if Richard cannot supply one.
http://www.repairclinic.com/PartDeta...d111988&mr= 1
Fortunately I only live a couple miles away from their location so I do not have to pay shipping when I need parts.
-= 862 =- Lightning Robotics, Canton, MI
2015 FiM Bedford District Chairman's Award
2014 FiM Bedford District Winner
2013 12th seed, Curie Division Winner with 1678 and 148
2013 Michigan State Championship Entrepreneurship Award
2013 FiM West Michigan District Winner, Engineering Inspiration Award
2013 FiM Kettering District Winner, Engineering Inspiration Award
Unread 17-06-2015, 10:59
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
The trick will be bending it. The straight portion has not been plastically deformed so it should have all of its ductility left. Putting the same radius bend as the original hook shouldn't break it.
Unread 19-06-2015, 12:16
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
After some searching I have found two springs. One is stronger than the other (thicker wire). See attached. Is one of them a match for yours?
Richard Wallace
since 2003
Unread 19-06-2015, 12:48
I had to put the machine back in service temporarily for the weekend laundry.
I'll open it up early next week and put the calipers on the wire.
Thanks.
Unread 19-06-2015, 18:51
Michael Hill's Avatar
I don't mean to be daft, but how does a single model of washer get associated with two nearly identical springs where the only difference is 0.2mm in diameter? Is it the same part, just for a later model after fixing something? Are parts in washing machines so fickle they can't be interchanged with each other?
Unread 19-06-2015, 19:20
That's not the way I interpreted it.
The two springs Richard found are unmarked and he wants to know which is the correct one for my washer.
I assumed the other spring is for a washer with a lighter (smaller) or heavier (larger) tub.
Unread 19-06-2015, 20:25
Gotcha. I assumed he looked it up in some database and both were returned as possible.
Unread 19-06-2015, 20:54
This is correct. However, the question is a very good one.
The washers that used these springs have not been produced for several years now. The older washer design had several variations, using at least a dozen different motors of varying speed and power ratings. Because the range of weights of those motors, different suspension spring forces were required.
More recent washer designs (since ~2010) use smaller, more efficient motors, and their suspension systems are completely different. They also hold more laundry, and consume less water and energy, compared to the older designs.
Originally Posted by gblake View Post
On the other hand, that ductility might mean that the metal you bend won't stay bent.
Having used these springs in several experimental situations, and bent their straight segments into various configurations, I can confirm that this is also correct.
Richard Wallace
since 2003
Unread 19-06-2015, 20:31
gblake's Avatar
gblake gblake is offline
6th Gear Developer; Mentor
AKA: Blake Ross
no team (6th Gear)
