Go to Post I was thinking (dangerous I know) - EricH [more]
Unread 06-16-2015, 06:45 PM
chrisfl chrisfl is online now
FRC #1991 (Dragons)
chrisfl is a name known to allchrisfl is a name known to allchrisfl is a name known to allchrisfl is a name known to allchrisfl is a name known to allchrisfl is a name known to all
pic: Concept Swerve design
Unread 06-16-2015, 06:50 PM
evanperryg's Avatar
evanperryg evanperryg is online now
IT'S THE BUMP N' DUMP
AKA: Evan Grove
FRC #4536 (The Minutebots)
evanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond repute
Re: pic: Concept Swerve design
Great start. Your lightening pattern is pretty aggressive, I'd suggest making the supports a little thicker. To do the pulley on the module itself, I think you could just have a CNC'd pulley as the cylinder. Otherwise, some sort of 3D printed pulley would work. You could have a key in the pulley that fits into a slot on the cylinder, or you could possibly have it press-fitted.
FRCDesigns Contributor | "There is only one corner of the universe you can be certain of improving, and that's your own self." -Aldous Huxley
2012-2016 | FRC Team 2338: Gear it Forward
2013
Wisconsin Regional Winner 2014 Midwest Regional Finalist 2015 Midwest Regional Chairman's Award, Finalist, Archimedes Division Champion, IRI Semifinalist 2016 Midwest Regional Chairman's Award, Finalist, Archimedes Division Gracious Professionalism Award, R2OC Winner
2015 | FTC Team 10266: Mach Speed
2015
Highland Park Qualifier Winner, Motivate Award
2017-???? | FRC Team 4536: The Minutebots
Thanks to the alliances and friends I've made along the way: 33 74 107 111 167 171 234 548 1023 1089 1323 1625 1675 1732 1756 2064 2077 2122 2202 2358 2451 2512 2826 3936 3996 4039 4085 4241 5006 5401 5568 5847 5934
Unread 06-17-2015, 08:23 AM
Professional Stat Padder
Originally Posted by chrisfl View Post
This is a really interesting setup in that it looks like the frame that you are intending to mount the module to was built for a WCD.
I'd love to hear about how this design came about.
Other than that, I'd have to agree with Evan that your lightening pattern looks shaky at best. Swerve drives have all sorts of crazy forces through them, so I would be very careful about making your mounting plate strong enough.
(2015-Present)
Unread 06-17-2015, 11:19 AM
FRC #1991 (Dragons)
Thank you for the comments. I will definitely thicken the lightening pattern. I purposely designed the swerve module to fit with a WCD because I am also trying to design a simple/robust frame design that can easily be manufactured to work with 6 wheel tank, 8 wheel tank, swerve, mecanum, omni, and H drive. It is currently designed to accommodate wheels up to 6in in diameter. I am also trying to add drop-down omnis is for drifting and getting out of T-bones(inspired by 118 2014 robot). The frame would have the holes for all of these configurations and we can easily pick one to quickly make. I hope to pitch to Vexpro or Andymark because it seems like an ultimate "drive in a day" chassis that has so many options. I will probably post more when I finish with some of the configurations
Unread 06-17-2015, 12:04 PM
cad321 cad321 is offline
Jack of all trades, Master of none
AKA: Brian Wagg
FRC #2386 (Trojans)
cad321 is just really nicecad321 is just really nicecad321 is just really nicecad321 is just really nice
Is this necessary? With an omni directional drive, you should be able to just strafe away from your opponent. This just sounds like added complexity and weight.
Unread 06-17-2015, 12:11 PM
FRC #1991 (Dragons)
That's if we go with a tank drive. I just thought it would be something cool to have if we want. Also whenever I drive mecanum, I just used the wheels to drift into tight places or get out of pins
Unread 06-17-2015, 03:29 PM
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Looks pretty good. I'm wondering about that thrust bearing at the top. Is it only going throug one plate, or is there another one that we can't see? With the wide shoulder your bearing has it might be okay, but keep an eye on it, and maybe add mounting holes for an upper plate just in case something goes wrong.
As other have said, your lightening pattern is too aggressive.
I would also add another bolt to mount it on the siderail, as the lower-right bolt is only secure by the bottom of the 2x1 there, which is only secured by a gusset plate or bellypan, so it will move around.
Unread 06-18-2015, 04:06 PM
FRC #1991 (Dragons)
The module is only going through one plate that is 3/16 in thick
