Go to Post A better way would be better..... - WizardOfAz [more]
Unread 17-06-2015, 21:23
Jtbillick Jtbillick is offline
FRC #4780
Jtbillick is an unknown quantity at this point
Andymark motor help
Hey, my team is trying to add an intake system to our robot and we ran into a problem. We have 2 andymark motors wired to victors. The victors are wired to the 40 amp section on the PDP. When we turn the robot on, the motors immediately start running, even when the robot is disabled. We tried switching the motor controllers, but it still had the same problem. Does anyone know how we can fix this? Thanks
Unread 17-06-2015, 21:28
orangemoore orangemoore is online now
AKA: Roger Moore
FRC #3135 (Robotic Colonels)
orangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond repute
Re: Andymark motor help
Can you upload a picture of the wiring?
Stronghold
Student 2013-2016
3135 -- Robotic Colonels
3507 -- Robotheosis (FTC)
Unread 17-06-2015, 21:38
DonRotolo's Avatar
Back to humble
FRC #0832
Possible causes:
1. The Victors are shorted (and damaged)
2. The Victors are wired incorrectly (may cause #1)
If you disconnect the PWM cables and the motors run, the fault is in the Victors for certain.
As ornagemoore requested, please upload a good photo of how the victors are wired
Unread 18-06-2015, 14:22
FRC #4780
Okay so my team switched the victors for spikes. Here's a picture of how the spike is wired: Click image for larger version
The motor is connected to the side that has m+ and m-. The other side is connected to the 40 amp PDP.
Unread 18-06-2015, 15:53
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Did using the spike resolve the issue?
If not, the picture should include the other end of the wiring as well; most of the errors than can be made with the wiring would be "off screen" on that pic.
Unread 18-06-2015, 18:44
Victors and Spikes are not functional replacements for each other. What is the other end of the three-wire control cable connected to? If you tried to control a Spike relay using a PWM signal, it wouldn't work well at all. I suspect it would end up with the LED being solid red and the motor running in reverse (at full speed, of course).
Note that a Spike isn't intended to switch more than 20 amps, and putting it on a 40A circuit is not a best practice.
