Go to Post Maybe we should put one of those advisory signs: "Don't try this at home ... or at Robotics competitions" - Franchesca [more]
Unread 20-06-2015, 08:46
CoachC's Avatar
CoachC CoachC is offline
AKA: Jim Cetnarowski
FRC #5247 (Red Devil Robotics)
Rookie Year: 2015
CoachC is an unknown quantity at this point
Wireless control setup for after season use
Im looking for advice on the best way to set up our 2015 bot for wireless control. Using a 30 foot ethernet cord is not practical for intended off season activity. Thanks in advance for your help.
Unread 20-06-2015, 09:06
Re: Wireless control setup for after season use
What I generally do is to make the DLink into an access point that laptops can join wirelessly. This can be done using the radio's config page or the radio configuration tool described here.
If your laptop supports 5Ghz, use that setting. Some don't, and you'll need to use 2.4 GHz, which can be problematic in certain spaces.
The laptops then need to join the wifi network created by your robot.
If you don't get a connection, you may want to check IP addresses. There are a number of ways to set it up, but I'd recommend using DHCP on the laptop and DHCP on the roboRIO.
Greg McKaskle
Unread 20-06-2015, 09:07
Have you seen this: Programming your radio for home use ?
At competition the DLink is locked up security-wise, and to be used at home needs to be reset using the button on the back.
Unread 20-06-2015, 10:03
CoachC's Avatar
Rookie Year: 2015
Thank you both very much. I appreciate your help. Have a great day
Unread 20-06-2015, 11:40
CoachC's Avatar
Rookie Year: 2015
Success!!! Thanks again
