Go to Post Volunteer...it will make you see a totally different side of FIRST. - Collin Fultz [more]
Unread 06-06-2015, 09:25
philso philso is offline
FRC #2587
Re: pic: LEGO Coaxial Swerve Module
This is cool and so elegantly compact. The one Steve made is cool too.
Originally Posted by bstew View Post
The reason the 12 tooth gear is on a 3m axle is because if I extend it across between the liftarms, it rubs on the tire. The way it is now is the best solution I could come up with.
The 12-tooth gear may end up adequately constrained (for the forces involved) by the gear below it and the one above it, laying horizontally. Those 3x5 L-shaped liftarms are pretty stiff so the gears might not skip.
Did you want to use the chain or 40-tooth gears for turning the modules, for powering the drive wheels or for both? Have you considered using long axles and the knob-gears Calvin referred to? The axles aren't that great at resisting torque but then you get gear lash with a large number of gears.
For "Smart Move", one of the local whizz kids and his partner attempted to build a second robot with swerve/crab drive for the Championship in February, after the Qualfier in November. I think their school ran out of parts and they could not manage to get the software going (no mentors on his FLL team). They did end up winning Third Place in Robot Performance using a robot they started building less than 24 hours before the Championship.
Unread 06-06-2015, 11:54
Calvin Hartley's Avatar
Calvin Hartley Calvin Hartley is offline
FRC #4967 (That ONE Team)
Calvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud of
The tires I am using must be a bit bigger than the the tires in the render because I had problems fitting an axle in. While I wish I had smaller tires, the ones I have will probably have to do. Thanks for your help anyway.
The ones in the render look like tire 89201 with (I am assuming) hub 55982. If you want to acquire some, you can find both easily on Bricklink for cheap. If you haven't used Bricklink before and have questions, feel free to ask.
I tested those parts with a one-stud gap between the wheel axle and the white axle in the image below. There's plenty of gap. Hope this helps.
FRC 4967 That ONE Team 2013-Present, Founder, CAD/Everything Mentor
FRC 2771 Code Red Robotics 2012 and 2013 Drive Team, 2014 Drive Coach, Executive Leadership
FLL Team member 2005-2010, LEGO In Paradise,
FLL Mentor 2009-Present Paradise Teams (nine teams)
FLL Coach 2014-Present - The Lightning Bugs
Gracious Professionalism isn't a set of rules to follow, it's an attitude.
Unread 08-06-2015, 14:18
carpedav000's Avatar
carpedav000 carpedav000 is offline
Studenting is hard, but worth it!
AKA: David Carpenter
no team (Jerry-Rigg school of DuctTapeology)
carpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant future
Would this work with having one module in the center of the robot and a caster on every corner? That way it takes a lot less gears to drive and only one gear to turn.
Unread 08-06-2015, 14:42
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
How would you turn?
Unread 08-06-2015, 14:46
tindleroot tindleroot is offline
Free Scouting Help to All
AKA: Casey LeeVan
FRC #4272 (Maverick Boiler Robotics)
tindleroot has a reputation beyond reputetindleroot has a reputation beyond reputetindleroot has a reputation beyond reputetindleroot has a reputation beyond reputetindleroot has a reputation beyond reputetindleroot has a reputation beyond reputetindleroot has a reputation beyond reputetindleroot has a reputation beyond reputetindleroot has a reputation beyond reputetindleroot has a reputation beyond reputetindleroot has a reputation beyond repute
Having at least two modules is necessary (3 or 4 is probably best) for two reasons:
1. with only one module, swerving it would move the robot as well since there is no other anchor point for the module to rotate.
2. having multiple modules allows the robot to do tricky maneuvers - one module would allow only omnidirectional movement, and sacrifice the helpful maneuvers.
2012-2013: FTC 4601 (student)
2014-2015: FRC 135 (student) - 5 banners in 2 years!
2016-present: FRC 4272 (mentor)
Thanks to all of our alliance partners!
11, 51, 68, 201, 234, 868, 1108, 1241, 1760, 3147, 3301, 3487, 3865, 4269, 4485, 4580, 5188
Unread 09-06-2015, 15:53
samfruth's Avatar
samfruth samfruth is offline
FRC #1710 (Ravonics Revolution)
Team Role: Driver
samfruth will become famous soon enough
I just made a swerve drive using this module and it worked great for me. The only modification I made was with the bottom axel because it kept coming lose from the L brackets. I used a gray piece that was just longer than the original light grey piece and has an end cap on it. Two modules was all I used and for motors I had three of the small motors that come with the EV3.
Thanks for sharing this!
I kind of know programming
Unread 09-06-2015, 21:21
bstew's Avatar
bstew bstew is offline
FRC #3928 (Team Neutrino)
Team Role: CAD
Rookie Year: 2015
bstew is a splendid one to beholdbstew is a splendid one to beholdbstew is a splendid one to beholdbstew is a splendid one to beholdbstew is a splendid one to beholdbstew is a splendid one to beholdbstew is a splendid one to behold
Thanks for all of the replies! Thanks Nato for telling me about similar designs. They will be helpful if I run into problems.
I am progressing with the design of the robot as I await pieces to arrive. I think I will be using a set of 40 tooth gears and an NXT motor for turning the modules. I probably will use chain and the medium EV3 motor for turning the wheels. I will still have two motors left for other actions because I will control it with an EV3. After completing it, I think I will try to do some FLL missions to evaluate its viability for FLL.
Unread 10-06-2015, 22:54
AlexanderTheOK AlexanderTheOK is offline
Guy
AlexanderTheOK is just really niceAlexanderTheOK is just really niceAlexanderTheOK is just really niceAlexanderTheOK is just really nice
Strange that theres no pictures of this outside of the render. I thought i would make it, and gear it for speed.
Heres the simplest one I could make with nxt 2.0 parts. surprisingly sturdy considering the drive motor is attached at literally at only one other point outside the drive shaft. Love the shaft catchy thingy.
Unread 11-06-2015, 16:03
faust1706's Avatar
faust1706 faust1706 is offline
FRC #1706 (Ratchet Rockers)
faust1706 is infamous around these partsfaust1706 is infamous around these parts
Originally Posted by asid61 View Post
How would you turn?
I think conservation of momentum would allow for conversion to angular momentum if going fast enough and have sudden enough changes of direction.
"You're a gentleman," they used to say to him. "You shouldn't have gone murdering people with a hatchet; that's no occupation for a gentleman."
Unread 20-06-2015, 20:08
Guy
Hate to resurrect a thread, but a friend and I decided to have some fun with our access to some NXT 2.0 kits and made a 2 wheel swerve using this design. The stacking he came up with is the most aesthetically pleasing thing I've seen all month. Didn't have time to program it, and I doubt we could have since I believe the nxt 2.00 motors use tachometers instead of encoders.
Still fun to drive though, with one phone controlling steering and the other controlling speed it vaguely resembles swerve movement.
Unread 20-06-2015, 22:25
bstew's Avatar
Team Role: CAD
Rookie Year: 2015
Pretty cool stacking design. I'm glad you could make use of my module design.
My parts finally arrived from LEGO today, so I worked on it some. Currently, I am using a EV3 with a four wheel crab setup. I am working on optimizing it, but I should get a video of it sometime when I'm done. This has been a fun project so far.
Unread 20-06-2015, 23:20
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
I'm pretty sure it is actually an optical encoder regardless of how it is marketed. They are relatively good at position control, not sure about speed control. I think the only thing that would get in the way would be the unpredictability of the passive casters.
Unread 21-06-2015, 13:37
FRC #2587
...I believe the nxt 2.00 motors use tachometers instead of encoders...
The NXT (and EV3) motors all have optical encoders in them, not tachometers.
Unread 21-06-2015, 17:39
Guy
Yup. Looked that up later. I have some pretty good pictures of it though, so not too hard to put back together when i get access to the kits again.
