Go to Post ...last year's watchdog had a litter of watchpuppies. - EricVanWyk [more]
Unread 22-06-2015, 00:57
akoscielski3's Avatar
akoscielski3 akoscielski3 is offline
Mentor (1114), Alumni (772)
AKA: Aaron Koscielski
FRC #1114 (Simbotics)
akoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond repute
Re: Adding friction material to timing belts
Originally Posted by Mike Marandola View Post
What's the application? Speeds? Is it a continuous belt?
I would suggest looking into brushable urethane. 1114 used it on their rollers in 2014....
Just so nobody gets the wrong idea about the paint on urathane I wouldn't mind commenting on this. Yes we did use this for our intake rollers in 2014 (also 2012 and 2011), and it served us well. Although we replaced the rollers more then you might think. I believe we changed them every day almost, so it might not be as reliable or durable as you think.
Hall of Fame Team 1114 Simbotics
2013-Present
Host of Simbot Solidworks Series
Team 772 Sabre Bytes
2010-2013
Dean's List Finalist 2013 Waterloo Regional
Unread 22-06-2015, 01:29
Mike Marandola Mike Marandola is offline
Lead Bumper Mentor
AKA: Mike Marandola
FRC #0316 (Lunatecs)
Mike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond repute
Was it the urethane material itself or the bond between the urethane and PVC that was failing? And if it's the latter, could you detail how you prepped the roller surface before applying the urethane?
2015 - Pioneer Valley District Finalists/Upper Darby District Finalists/MAR District Championship #1 Seed and Winners with 225 and 203
2014 - Lenape Seneca District Winners/Chestnut Hill District Winners
2013 - Lenape Seneca District Winners/Chestnut Hill District Finalists
2011 - Philadelphia Regional Finalists
2009 - Finger Lakes Regional Finalists
Unread 22-06-2015, 08:41
I believe it was the bonding into the PVC rollers that would start to peel off once it got a cut out hike in it. I want apart of the people who made them all the time, but I believe they cleaned each one with rubbing alcohol before applying.
2013-Present
2010-2013
