Go to Post Does IR work underwater? Or more importantly, through an air-water interface? ... sigh ... - Rich Kressly [more]
Unread 19-06-2015, 21:45
Ginger Power's Avatar
Ginger Power Ginger Power is offline
The GreenHorns Team Lead
AKA: Ryan Swanson
FRC #4607 (C.I.S.)
Ginger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond repute
4607 has its own computer!
Our 2015 driver (going to be a junior) has started his own line of computers and computer accessories! He's named his first product, the L4607, after our team check it out!
Unread 22-06-2015, 16:24
seg9585's Avatar
seg9585 seg9585 is offline
AKA: Eric
FRC #4276 (Surf City Vikings)
seg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond repute
Re: 4607 has its own computer!
Just curious -- when assembling this build, what trade off led to the design decision not to include an optical disk drive? Many small laptops removed them to make the profile of the computer smaller, but these builds usually just sit under a desk.
Seeing that a significant amount of software is still distributed on disk, it seems an optical drive would still be value added. People who buy ready-built desktop computers (rather than build their own) are typically novices who don't want to open up their computers and install new components. Seeing that you're bundling Windows 8, the novice computer user is your target consumer. Optical drives are very cheap so I can't imagine cost was a factor.
My FIRST legacy:
Team 204 Student 2001, 2002 (Voorhees, NJ)
Team 1493 College Mentor 2006 - 2008 (Troy, NY)
Team 2150 Intern/Professional Mentor 2007, 2009 (Palos Verdes)
Team 4123 Lead Engineering Mentor 2012 (Bellflower, CA)
Team 4276 Engineering Mentor 2012-2016 (Huntington Beach, CA)
Unread 22-06-2015, 17:37
ultimate360's Avatar
ultimate360 ultimate360 is offline
Product developer
AKA: Logan Steffen
FRC #4607 (CIS Robotics)
Team Role: Electrical
ultimate360 will become famous soon enough
We thought about that for a while, and just decided to leave it out. The reason we came to that decision is because most modern software is available online, and for the software that is on disk you can simply use the activation/product key from the disk package or an online source, and then download the ISO file for the disk itself which is typically easy to obtain from a google search. Once you have the ISO file of the disk, Windows allows you to right-click, and then select "mount" which makes windows treat the file as if it's in a optical drive and it will appear and load as normal. But that is for if you really need to use the disk and can't find a downloadable installer.
We realize the optical drive may be a useful feature, and we know they are inexpensive, but it's one less thing that would have to sit in the computer and rarely be necessary. It's not very often anymore that disks are really used with a PC unless you like to run DVDs on your PC. That's our reason behind it, and we also offer directions for the novice user to know how to either use the ISO file alternative to the disk, or even install their own optical drive with ease and we offer this info in the quick start guide in the product box.
The other thing that's nice and is the most commonly used, is that in most cases you can simply ignore the disk and get the online downloadable version of the software instead, which the majority of software developers offer. In short, we saw the optical drive as not being a really necessary component for a 2015 PC with the internet becoming a great place to locate software and drivers on the websites of their creators.
Unread 22-06-2015, 17:45
connor.worley's Avatar
connor.worley connor.worley is offline
connor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond repute
Would a discount be possible for FRC teams...?
Team 973 (2016-???)
Team 5499 (2015-2016)
Team 254 (2014-2015)
Team 1538 (2011-2014)
2014 Driver (25W 17L 1T)
日本語でOK
Unread 22-06-2015, 18:43
Originally Posted by ultimate360 View Post
1) most modern software is available online... download the ISO file for the disk
2) sit in the computer and rarely be necessary
3) It's not very often anymore that disks are really used with a PC
4) unless you like to run DVDs on your PC
1) assumes all your potential customers have convenient access to very hi speed unlimited data plans
2) I guess I'm an old-timer. I use optical disks all the time: a) to create videos and photo albums to mail to non-computer-literate friends and family to play on their DVD player; b) to create various boot disks for system troubleshooting; c) to install older software; d) to install newer software on machines in locations without internet access
3) is this based on your personal usage pattern, or did you do some market research?
4) it looks like the L4607 is tricked up for video editing. It stands to reason that a non-trivial portion of your potential customer base is going to want to burn video DVDs.
Just food for thought.
Unread 22-06-2015, 18:47
evanperryg's Avatar
evanperryg evanperryg is offline
IT'S THE BUMP N' DUMP
AKA: Evan Grove
FRC #4536 (The Minutebots)
evanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond repute
I like how we're all acting like this is a robot in need of analysis. Cool project, great outreach opportunity!!
FRCDesigns Contributor | "There is only one corner of the universe you can be certain of improving, and that's your own self." -Aldous Huxley
2012-2016 | FRC Team 2338: Gear it Forward
2013
Wisconsin Regional Winner 2014 Midwest Regional Finalist 2015 Midwest Regional Chairman's Award, Finalist, Archimedes Division Champion, IRI Semifinalist 2016 Midwest Regional Chairman's Award, Finalist, Archimedes Division Gracious Professionalism Award, R2OC Winner
2015 | FTC Team 10266: Mach Speed
2015
Highland Park Qualifier Winner, Motivate Award
2017-???? | FRC Team 4536: The Minutebots
Thanks to the alliances and friends I've made along the way: 33 74 107 111 167 171 234 548 1023 1089 1323 1625 1675 1732 1756 2064 2077 2122 2202 2358 2451 2512 2826 3936 3996 4039 4085 4241 5006 5401 5568 5847 5934
Unread 22-06-2015, 19:22
thatprogrammer's Avatar
thatprogrammer thatprogrammer is offline
AKA: Ahad Bawany
no team (None)
thatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond repute
Many new cases don't include slots to have these drives, and many many experts I've talked to *people who run tech companies* have said that most clients no longer need or ask for dvd drives in builds.
Unread 22-06-2015, 19:28
I don't see L4607 being purchased in large quantities by tech companies or their clients. Target audience is probably largely unaffiliated users.
Unread 22-06-2015, 19:52
Product developer
AKA: Logan Steffen
Well, I appreciate the feedback I'm getting here. Seeing that some of you really believe in having a optical drive in your system (really depends on what you use it for), I will be adding a customization option on the website where you can choose to add a drive or not, and choose to add more ram, different processor, ect... But the model on Amazon will remain in there and it will be the base model of the L4607. I appreciate this feedback, I will add the customization options for your satisfaction.
As for a FRC discount, i'm sure that can be arranged
Unread 22-06-2015, 20:44
AlexanderTheOK AlexanderTheOK is offline
Guy
AlexanderTheOK is just really niceAlexanderTheOK is just really niceAlexanderTheOK is just really niceAlexanderTheOK is just really nice
Yeah I hate to beat a dead horse, but I have one in my laptop and I wouldn't give it up for a day even with my 60mbps down. The few of my friends with computers that don't have optical disk drives all bought external usb disk drives.
Unread 22-06-2015, 21:25
Product developer
AKA: Logan Steffen
Thanks for the feedback, it's things like this that build a company. I will state that my source for the info regarding that disk drives are not used as much anymore is from local experience with clients. Very few people wanted a disk drive, and many folks had dead drives that they didn't want repaired from systems that they had me repair for them. I've been at this for about 4 years now and that's where I have collected my stats.
Unread 23-06-2015, 08:13
Aren Siekmeier's Avatar
on walkabout
I had one in my laptop, but just removed it because I never use it and the driver kept spinning it up for no reason. Marginally reduces weight too
But I do have some boot discs that I might need to use at some point, so I'll be popping the drive back in for that. Easier than making a bootable USB. Not sure if my mobo is new enough for that anyway.
Unread 23-06-2015, 08:31
marshall's Avatar
marshall marshall is offline
FRC #0900 (The Zebracorns)
Can confirm. Optical disks make you an old-timer.
That and your rookie year.
Unread 23-06-2015, 11:31
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
They are hardly alone in eliminating optical drives from tower computers. There are plenty of other models that have done the same.
Nor is this the only computer on the market. They aren't trying to appeal to everyone.
Unread 23-06-2015, 14:04
seg9585's Avatar
AKA: Eric
As the original requester, this thread is making me feel old now, ugh. Waiting for a "senior" mentor to come in and request a floppy drive just so I feel a bit younger. Long live the days of VCDs and Divx, and those amazing Black Friday sales of 50-packs of CD-R's for $15 after mail-in rebate.
Another comment though if I may: I'm surprised to see a modern build optimized for video editing with no eSATA ports. Ever since the death of Firewire I've used eSATA extensively.
My FIRST legacy:
