Go to Post Stacking totes on end; Gives you extra height, alas; Topples with a sneeze. - BethMo [more]
Unread 24-06-2015, 17:02
hectorcastillo's Avatar
hectorcastillo hectorcastillo is offline
Former Driver and Captain for 3481
FRC #0125 (NUTRONs)
hectorcastillo is a name known to allhectorcastillo is a name known to allhectorcastillo is a name known to allhectorcastillo is a name known to allhectorcastillo is a name known to allhectorcastillo is a name known to all
pic: FTC Custom Drive Train
Unread 24-06-2015, 17:05
cbale2000's Avatar
cbale2000 cbale2000 is offline
AKA: Chris Bale
FRC #5712 (Gray Matter)
cbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond repute
Re: pic: FTC Custom Drive Train
You might want to consider offsetting one of the motors on each gearbox up a bit to allow the gearboxes to be removed more easily if needed (might also help with wire access to the motors). We've had issues in the past where we didn't allow enough clearance to do maintenance on our gearboxes and it proved problematic.
Otherwise it's a very nice looking drive, I initially mistook it for an FRC bot. =)
Unread 24-06-2015, 17:39
Gregor's Avatar
Gregor Gregor is offline
#StickToTheStratisQuo
AKA: Gregor Browning
It's hard to tell from the AM page if the motor leads stick out straight back or if they come out the side, but if they stick out straight back your motors may need to be further apart.
FRC 2011-xxxx Volunteer
How I came to be a FIRSTer
<Since 2011
Unread 24-06-2015, 17:47
GarrettF2395's Avatar
GarrettF2395 GarrettF2395 is offline
AKA: Sierra 117
FRC #2395
Team Role: RoboCoach
GarrettF2395 is a glorious beacon of lightGarrettF2395 is a glorious beacon of lightGarrettF2395 is a glorious beacon of lightGarrettF2395 is a glorious beacon of lightGarrettF2395 is a glorious beacon of light
Send a message via Yahoo to GarrettF2395
What an awesome render!
I noticed the 90deg gussets you've got on top, but how are you planning on attaching the bottom 1x1 tubes to the drive modules?
The way it's set up now looks like you plan on welding it.
https://twitter.com/TeamNinjaMunkee
FRC 2395: Team captain 2008-2009, Design mentor 2010-2011, Lead design and strategy mentor 2012-Present
Unread 24-06-2015, 18:06
FRC #0125 (NUTRONs)
Thanks for the feedback! It hasn't occurred to me to offset the motors to make it easier to remove the gearbox and give room for the wires. Thanks. As far as how the bottom tubes are attached, they are riveted onto small plates with tabs that fit into small notches in the larger side plates. These small plates are installed during the assembly of the module.
Here's a closer look:
https://drive.google.com/file/d/0B8z...ew?usp=sharing
365 Decontaminators (FLL) 2011 - 2012
6221 Panther Bots Alpha (FTC) 2012 - 2016
3481 Bronc Botz (FRC) 2012 - Present
125 NUTRONs (FRC) 2017 - Present
Unread 24-06-2015, 18:07
MattRain MattRain is offline
AZ FTC AF, FTC #2844 and FTC #8640
FRC #1492 (Team Caution)
MattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant future
They stick out the side. The encoder cable sticks out the back slightly but can be bent up right away.
2015 FTC WORLD CHAMPIONS
www.valleyx2844.com
Twitters: Valley X & Trojan Robotics & Team Caution
(World Championship Counter: 5)
*All my posts reflect my opinion, not my teams.*
"I WANT CHEETOS!" - Bad Lip Reading 2016 <-- ME
Unread 24-06-2015, 18:15
FTC5110 FTC5110 is offline
FTC #5110 (Wingus & Dingus)
FTC5110 is a splendid one to beholdFTC5110 is a splendid one to beholdFTC5110 is a splendid one to beholdFTC5110 is a splendid one to beholdFTC5110 is a splendid one to beholdFTC5110 is a splendid one to behold
Nice. Do you have a weight estimate?
VRC7682/7682E/FTC5110 Wingus & Dingus - Mentor
2016 FTC World Championship - Finalists Edison Division (thanks 6137 & 4997)
2016 VEX World Championship - Game Animation 1st, Programming Skills 3rd, Technology Division Amaze Award, Semifinals
2015 FTC World Championship - Semifinals Edison Division (thanks Cougars & ERX)
2015 VEX World Championship - Overall World Innovate Award, Arts Division Think Award
2015 New Zealand VEX Nationals - Winning Alliance Captain + Finalist Alliance Captain(E) + Pgm Skills Champ (48pts) + Think Award
2014 New Zealand VEX Nationals - Finalist Alliance Captain + Programming Skills Champion + Judges Award
2013 FTC World Championship - Finalist Rockwell Collins Innovate Award
2013 VEX World Championship - MS Amaze Award
2013 New Zealand VEX Nationals - MS Excellence + Judges Award
2012 Asia Pacific VEX Championship - MS Design + Innovate Awards
Unread 24-06-2015, 18:19
carpedav000's Avatar
carpedav000 carpedav000 is offline
Studenting is hard, but worth it!
AKA: David Carpenter
no team (Jerry-Rigg school of DuctTapeology)
carpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant future
Those white wheels are illegal for FTC. AM designed stealth wheels to take their place
Unread 24-06-2015, 18:40
Jeremy Germita's Avatar
Jeremy Germita Jeremy Germita is online now
Co-Advisor/Lead Engineering Mentor
AKA: wood is good. plastic is fantastic.
FRC #5012 (Gryffingear) / (Antelope Valley FIRST Teams)
Jeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond repute
Looks great! I love how flexible the FTC rules are getting and I'm excited to see how teams are taking advantage of those rules.
Remember that FTC fields are 12' square(thus far), 6-7 feet per second would clear the field in about 2 seconds. That's ridiculously fast for this scale. Scaling that up to FRC field sizes, it's like gearing for 30+fps free speed.
Here is a custom FTC drivetrain I built a couple of years ago. I clocked it at just under 3 feet per second without any mechanisms on the robot, but it ended up being about 2.5 f/s during competition. I found it was on the cusp of controllability on an FTC field. When 72 made v2 of that drivetrain last season, they geared it for 4fps and the NXT loop execution rate was definitely too slow to control the drivetrain without lag. It would travel about 4-6" between motor controller updates.
Just a warning. These may or may not be valid concerns for the 2015-16 game and control system .
Drive Coach Team 5012 Gryffingear / Antelope Valley FIRST teams / EWCP - (2013 - Current)
Student / Driver / Programmer / CAD - FRC Team 399: Eagle Robotics / FTC Team 72: GarageBots - (2009 - 2013)
Los Angeles Region FTC FTA/CSA/Head Ref
[FF] FIRST Pick
2014 FTC Los Angeles Regional Compass Award Winner.
2017 - San Diego Regional / Sacramento Regional / Las Vegas Regional
2016 - Los Angeles Regional Creativity + Winners (1197, 987, 5012) / Las Vegas Regional Team Spirit + SF (5012, 5851, 5049) / Galileo Subdivision
2015 - Inland Empire QF (597, 5012, 4413) / Las Vegas Imagery + Winners (148, 987, 5012) / Newton Subdivision and World Champions (118, 1678, 1671, 5012)
2014 - Inland Empire Rookie All Star + Highest Rookie Seed + SF (2339, 1967, 5012) / Las Vegas Rookie All Star / Galileo Division Imagery
Unread 24-06-2015, 19:15
FRC #0125 (NUTRONs)
As of right now it weighs around 13.25 lbs.
Those are actually 4" VersaWheels from VexPro. Although the color and tread pattern does look similar.
Thanks. When I was deciding on my gear ratios I knew I wanted something fast, but I wasn't exactly sure how fast was fast and how fast was too fast. But I figured that someone here could point me in the right direction so that I can make the right adjustments.
Unread 25-06-2015, 17:19
ehochstein's Avatar
ehochstein ehochstein is offline
Coach, Volunteer & Mentor
AKA: Evan Hochstein
FTC #5943 (ESGM)
ehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant future
First off - I love the look of this chassis. My students put something together something that looks similar to this last year. I'll see if one of them can send me a photo and I'll post it.
How do you plan on attaching the motors to the gearboxes? I would assume the 6 mounting holes on the face, loctited?
Minnesota FIRST Senior Mentor | 2013-?
Stratasys Applications Engineering Technician | 2016-?
2009 Regional Win – 2470 @ 10k Lakes (Thanks 2826 and 1714)
2013 WFFA Recipient – 2470 @ 10K Lakes
2016 Ri3D: 'Snow Problem Reveal
The opinions expressed above are the personal opinions of the author and do not necessarily represent the views and opinions of any organization the author is affiliated with.
Unread 26-06-2015, 01:17
Fusion_Clint's Avatar
Fusion_Clint Fusion_Clint is offline
AKA: Clint Brawley
FRC #0364 (Fusion)
Fusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond repute
I love it, we are going to try incorporating the FRC Texas tubes this summer on the FTC scale.
I have a question, FTC normally requires the robot to pick up something, how to you plan on this drive-train allowing that? I would suggest leaving the "front" somewhat open.
Clint Brawley
USAF 1992-2013
Fusion 364, 2014 Season to present
Unread 26-06-2015, 01:41
FRC #0125 (NUTRONs)
There are holes in the gearbox plate that line up with two of the 6 mounting holes on the motor, and yes, I would probably use a little loctite, but not too much in case I need to remove a motor later.
Unread 26-06-2015, 01:50
FRC #0125 (NUTRONs)
I originally had the front left open without the front tube. I made it so that you can open up the front and back to fit the needs of the game. Removing the top tubes would make it a little less sturdy, but there are plenty holes along the top of the drive modules to mount whatever structure you need to provide stability and not be in the way. I wanted this design to be as dynamic as possible since we don't know what the next game is going to be.
Unread 27-06-2015, 01:46
Nemo's Avatar
Nemo Nemo is offline
Team 967 Mentor
AKA: Dan Niemitalo
FRC #0967 (Iron Lions)
Nemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond repute
Two things:
1) Very cool looking design. I hope you folks end up building something like this.
2) Thanks for bringing my attention to those BaneBots 6mm adapter hubs! That removes a pretty significant barrier to some of the FTC ideas we've tossed around on our teams.
