Go to Post Engineering is a balance between best performance, best cost, and best use of time. - GeorgeTheEng [more]
Unread 18-03-2003, 10:52
SuperJake's Avatar
SuperJake SuperJake is offline
No Problem!
AKA: Jake Classic
FRC #0061 (The Shifters)
SuperJake has much to be proud ofSuperJake has much to be proud ofSuperJake has much to be proud ofSuperJake has much to be proud ofSuperJake has much to be proud ofSuperJake has much to be proud ofSuperJake has much to be proud ofSuperJake has much to be proud ofSuperJake has much to be proud of
Send a message via AIM to SuperJake
Originally posted by JosephM
Can you make the one you showed off at Annapolis in mpg form?
That one is GeroniMOE Revealed. The MPEG form of that is HUGE!! That's why it is encoded in DivX. If you need the DivX codec, go to www.DivX.com/DivX. You'll want to download the freeware on the left side, without the ads. When installing, if you are on a PC, you don't need to install the official player 'cause Win Media player will use the DivX codec. If you're on a MAC.... I'm not exactly sure, but you might want to install the player if you can't get it to work. If you still want the MPEG form of GeroniMOE Revealed - send me a PM and we'll talk about it.
Never send a person to do a robot's job.
Robots excel at Dull, Dirty, and Dangerous jobs.
Team 365 Proudly Presents GeroniMOE! SuperJake Robot Showcase 40 07-04-2003 18:45
pic: GeroniMOE 365 CD47-Bot Robot Showcase 27 28-02-2003 16:38
Results from Drexel, thanks from 365. archiver 2001 1 24-06-2002 02:44
Thanks from 365! archiver 2001 3 24-06-2002 02:30
videos needed archiver 1999 3 23-06-2002 22:09
