Go to Post and Bob's your uncle. - Joe Johnson [more]
Unread 21-04-2015, 17:57
cad321 cad321 is offline
Jack of all trades, Master of none
AKA: Brian Wagg
FRC #2386 (Trojans)
cad321 is just really nicecad321 is just really nicecad321 is just really nicecad321 is just really nice
Throttle control motor gears?
Ive been looking at using some of our denso throttle control motors for an offseason project and am having troubles finding gears to mesh with the pre-installed gear. Does anyone know where to get these gears? The specs are provided on the first choice sight this year here
Unread 21-04-2015, 18:10
topgun's Avatar
topgun topgun is offline
FRC #2846 (FireBears)
topgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant future
Re: Throttle control motor gears?
Usual suspect:
http://sdp-si.com
Could also check Amazon, eBay, Boston Gear, Rush Gears, etc.
The key thing is the .75 module pitch (means it's metric) and the pressure angle (20 Degrees). Any gear you mate with it needs to have those same specs.
-T
Unread 21-04-2015, 23:04
InFlight's Avatar
InFlight InFlight is offline
3574 - The King's of Bling
AKA: Jim
FRC #3574 (High Tekerz)
InFlight is an unknown quantity at this point
Buying sets of odd module metric gears will be difficult due to availability, and will be more expenive than standard 20DP / 14.5 angle gearing offered by Vex and Andymark.
I would suggest removing the stock pinion and replacing it with a standard gear would be the best long term approach. You can order spur gear stock and cut it to length. Center drill (in a lathe) to fit the shaft. I'd suggest the addition of a small tapped side hole for a set screw rather than trying to achieve a press fit onto the shaft.
Thank you 2016 Alliance Partners - 948, 1510, 2046, 2521, 2980, 2990, 4911, 4683
Unread 21-04-2015, 23:29
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
If you can fine another gear just like it, you can simply integrate it into your gearbox by making the correct shaft for it.
Most years there is no need for the throttle motors, as many mechanisms can simply be powered with pneumatics (6 cims, 4 minicims/bags, 4 Banebots motors, plus some others is a lot of motors) . As a project all on its own, making a gearbox for it would be interesting. I believe there was a similar attempt to use it on here recently.
Unread 22-04-2015, 00:10
AKA: Brian Wagg
FRC #2386 (Trojans)
yes there was another thread recently with a similar ambition as mine. I too am looking into possibly trying to make a gearbox for these motors. If I can make one that is reasonably easy to make, it would allow teams with a lower budget to have a wider range of options with motors/gearing.
Unread 22-04-2015, 21:17
matthewdenny's Avatar
matthewdenny matthewdenny is offline
FRC #6054 (Dukes)
matthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant future
I am not familiar with these motors. What advantage would they have as opposed to some of the more commonly utilized motors. Do they have a characteristic that sets them apart and makes them worth this trouble?
Unread 22-04-2015, 21:22
AKA: Brian Wagg
FRC #2386 (Trojans)
The biggest advantage to me is their availability. Almost every year we get at least one of these in the KOP (this year we got 8!) and they just keep piling up in our work space. A gearbox that utilizes these would allow for what is currently thought of as useless (or virtually useless) motor, to become a useful one. I doubt that teams that can afford multiple versaplanetary's would opt for this option, but for teams with less funding/experience, this could be a viable option for low power requirements.
Unread 01-06-2015, 10:44
bigbeezy's Avatar
bigbeezy bigbeezy is offline
AKA: Bryan
FRC #2338 (Gear it Forward)
bigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to behold
Send a message via AIM to bigbeezy
I would like to get rid of 19 of these motors. They are just taking up space. Never been used! FREE! PM me if interested.
Team 1592 Bionic Tigers -- Driver 2005-2008
Winner - Florida Regional 2005
Finalist - Newton Division 2007
Winner - Colorado Regional 2008
Florida State University - BS Mechanical Engineering
Team 2338 Gear it Forward -- Mentor/Drive Coach 2013-Present
Winner - Wisconsin Regional 2013
Chairman's Award - Midwest Regional 2015
Winner - Archimedes Sub-Division 2015
Chairman's Award - Midwest Regional 2016
Unread 28-06-2015, 00:37
seamushroom seamushroom is offline
AKA: Seamus
FRC #2491 (No Mythic)
Team Role: CAD
seamushroom is an unknown quantity at this point
I'll take them!
Unread 28-06-2015, 00:41
asid61's Avatar
AKA: Anand Rajamani
FRC #0115 (MVRT)
We have I think 17 years worth. I wonder how many that is? I don't think we've ever thrown one away.
Unread 28-06-2015, 07:12
Michael Hill's Avatar
sdp-si sells gears that will work. When you go to the catalog, be sure to select "Metric" instead of "Inch". Choose a spur gear with 0.75 module (metric equivalent of diametral pitch) and with 20 degree pressure angle.
Unread 28-06-2015, 07:56
Scott Kozutsky's Avatar
Scott Kozutsky Scott Kozutsky is offline
FRC #0865
Scott Kozutsky will become famous soon enough
Not quite, diametral pitch is # of teeth/diameter (in inches) whereas module is diameter (in milimeters)/# of teeth.
2010-2012 FRC 865 Warp7 Student, Mechanical
2013 FRC 1310 RUNNYMEDE ROBOTICS Student, Mechanical, Design
2014 FRC 865 Warp7 Student, Mechanical, Design
2015 FRC 865 Warp7 Alumni, Mechanical Mentor
Unread 28-06-2015, 08:08
By "equivalent", I meant it conveys the same information, which it does.
Unread 28-06-2015, 13:38
FRC #0865
That's true. I just clarified because it could have been a bit misleading to someone new.
