Go to Post you don't need a fancy workshop to build a good robot, just determined people. - pacoliketaco [more]
Unread 27-06-2015, 18:29
wmarshall11 wmarshall11 is offline
FRC #2399
wmarshall11 is a splendid one to beholdwmarshall11 is a splendid one to beholdwmarshall11 is a splendid one to beholdwmarshall11 is a splendid one to beholdwmarshall11 is a splendid one to beholdwmarshall11 is a splendid one to beholdwmarshall11 is a splendid one to beholdwmarshall11 is a splendid one to behold
pic: Octocanum Module
1x CIM, 1x MiniCIM
Unread 27-06-2015, 18:33
zinthorne's Avatar
zinthorne zinthorne is offline
AKA: Avery
FRC #3663 (CPR)
Team Role: Driver
zinthorne will become famous soon enough
Re: pic: Octocanum Module
Why 2 cims per module? Do you need that much power? The mecanems lose a lot of traction.
Also, are you planning on running 4 of these sets? That is 36 pounds spend on a drivetrain which is a decent amount. Where are you planning on mounting the piston?
Unread 27-06-2015, 18:43
cad321 cad321 is offline
Jack of all trades, Master of none
AKA: Brian Wagg
FRC #2386 (Trojans)
cad321 is just really nicecad321 is just really nicecad321 is just really nicecad321 is just really nice
How do you plan to actuate it? 2 pistons? 4? And as zinthorne asked, how do you plan to mount the pistons from the chassis to the modules?
Unread 27-06-2015, 19:25
FRC #2399
It's actually a CIM and MiniCIM, and I'll edit the description to reflect that. I've added that information to the initial post, but can't seem to edit the phot description
This was mostly done as an exercise in how aggressively an octocanum module could be built, and I grafted on the MiniCIM both to see if it could be done and so that a drive using this could hold its own against some of the more powerful tank drives I've encountered.
No doubt. That's the reality of CIM + MiniCIM + 4x2 Colson + 4" Mecanum. They're not light parts.
The most convenient point from which to rotate the module is the uppermost standoff, so the piston should be mounted there.
The specced safety factor is for a single 2" bore piston per side spanning between modules, a la 1086's Legendairy Drive.
Programming Project Manager and Lead Web Developer 2012 - 2014
Mount Olive Robotics Team, FRC 11
Mentor 2015 -
The Fighting Unicorns, FRC 2399
Unread 28-06-2015, 00:40
Electronica1's Avatar
Electronica1 Electronica1 is online now
Former Design and CAD Captain
AKA: Alexander Kaplan
FRC #1086 (Blue Cheese)
Electronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond repute
You could try to make that colson wheel smaller to save some weight. My team is running an 8 motor octocanum that is about 34 lbs including the entire frame by using 2 inch colson wheels.
Unread 28-06-2015, 18:23
zinthorne's Avatar
AKA: Avery
FRC #3663 (CPR)
Team Role: Driver
If he went with a 2 inch colson, he may not be able to fit his gear size onto the shaft without it hitting the ground.
Unread 28-06-2015, 18:59
Chak Chak is offline
AKA: Thomas
FRC #4159 (Cardinalbotics)
Team Role: CAD
Chak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant future
But at the same time the gear size would have to be smaller to keep the same speeds, because the wheel is now smaller.
Then again, 2 inch hex bore colsons don't exist anyways.
Switching to 2.5 inch colsons could save a few pounds.
Unread 28-06-2015, 22:03
FRC #2399
Going from one 4x2 to two 2.5x1.25 Colsons would save 0.4lbs per module on wheels. Probably a little over a half pound per module with resulting gearing changes.
Mentor 2015 -
Unread 28-06-2015, 22:15
wilsonmw04's Avatar
wilsonmw04 wilsonmw04 is online now
Coach
why articulate the motors? It would seem simpler to just move the wheels and leave the motors stationary.
Unread 28-06-2015, 22:24
Plus, the module itself gets smaller.
Unread 29-06-2015, 07:56
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
To do that, you'd have to drive the articulated wheel from the pivot wheel. This would mean either adding belt/chain or an intermediate gear that would engage both the gear on both wheels. To keep the speed ratio spread, you might need three such gears.
Since the force to articulate the wheels has to be sufficient to lift the robot, the extra amount necessary to move the motors is insignificant.
Unread 29-06-2015, 08:18
Professional Stat Padder
I really like how compact this is. I would be wary of running 8 motors in a drivetrain. It's altogether too easy to draw too much current, especially in traction mode, and trip breakers. Teams that ran 6-8 motors this year didn't have that problem because there was no defense and no pushing, but I know a few teams personally we worked with who had that problem in 2014 and even 2013.
(2015-Present)
Unread 29-06-2015, 08:34
Nathan Streeter's Avatar
FIRST Fan(atic)
FRC #1519 (Mechanical MAYHEM)
Very innovative design; I don't think I've ever seen something similar!
The design seems generally very good. Obviously you have a pretty high weight per module, but it's not bad at all considering you have a mecanum, 2" wide colson, all your gearing, and a CIM and MiniCIM. You could easily drop MiniCIMs on the front or something like that to save an easy ~5 pounds on the robot. I'd say to keep the 2" colson... if you're bothering to have a high-torque traction mode, I'd say don't skimp on it. Now, a fair question could be, "how much do you really need the traction mode?" I think many teams (my own included) tend to want to add all the 'bells and whistles' without really doing the strategic game analysis.
My one comment about the integrity of the design is about the idler axle. I've never used a single bearing on an axle like that... does anyone else have some experience with an idler shaft with gears on each side supported by only one bearing? You could always put a .875" press fit on the back side so you could put a turned down shaft through through the module if you need more support. Seems like 3/8" aluminum would be more than enough for that.
EDIT: I'm guessing you're fully aware, but your mecanum mode is geared pretty high. It may end up working well for you (particularly in some games), but I'd honestly only gear a >110lb robot that high in 2011 and 2014 of the games since 2005 (although I think fair cases could be made for 2006 and 2008). I realize a fair bit of this is a 'strategy/design style' though. :-)
Student: 2006-2010 (#1519)
Mentor: 2011-Present (#1519)
Unread 29-06-2015, 11:19
AKA: Brian Wagg
FRC #2386 (Trojans)
I only just noticed this after you pointed it out. I too am interested on what people think about this. On one hand there are so many constraints on the shaft from the meshing gears that it may be alright. On the other hand though, the amount of play in a single bearing (put a shaft through 1 bearing and try to wiggle it up and down) is quite significant.
Unread 29-06-2015, 13:50
fargus111111111's Avatar
fargus111111111 fargus111111111 is offline
AKA: Tim W
FRC #0343 (Metal in Motion)
fargus111111111 is on a distinguished road
As far as the idler is concerned, I think it would work but would be quite loud due to almost constant minor imperfections in the meshing.
