Go to Post We were all rookies once, and we really have two ways to go about things: either take a page from the powerhouses and emulate their style, or complain about not having anything and risk falling into oblivion. - George A. [more]
Unread 04-07-2015, 11:40
s_forbes's Avatar
s_forbes s_forbes is offline
anonymous internet person
FRC #0842 (Falcon Robotics)
Interesting compact high ratio transmission design
Those of you into Rubik's Cubes may know about this guy; Oskar is a puzzle designer that makes crazy cool stuff on Youtube. Here's his channel.
A few weeks ago he posted this simple three piece transmission, with a reduction of 27:1. It works on a similar concept to harmonic gearboxes. This seems like a design that might work for some mechanisms on the robots we build, particularly for something that needs a very large reduction and doesn't see a lot of torque. A similar design could probably be printed and interfaced to a motor quite easily, giving a cheap and quick gearbox for those teams with 3d printers.
If that's not enough, here's a variation on that concept that goes up to 11,373,076:1.
Unread 04-07-2015, 13:24
GeeTwo's Avatar
GeeTwo GeeTwo is online now
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: Interesting compact high ratio transmission design
It reminds me more of a two-stage cycloidal gearbox, though without the pegs and oversize holes in order to minimize the wobble - the wobble is just left there.
This could probably be driven by a belt or chain that was actively tensioned or some sort of CV joint. Either way, I would attempt to minimize the mass of that wobbling inner gear.
The 11M:1 gearbox is interesting, as well. The output torque is obviously limited by the strength of the material, implying that the efficiency is going to be exceptionally small. To put that gearing in perspective: to get a single revolution per day from the output, you'd need to drive it at 7898 rpm.
Unread 04-07-2015, 14:32
Hugh Meyer's Avatar
Hugh Meyer Hugh Meyer is offline
FRC #1741 (Red Alert Robotics)
Hugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud of
His last line is the best! "This is a solution looking for a problem." Interesting design.
-Hugh
Unread 04-07-2015, 14:50
carpedav000's Avatar
carpedav000 carpedav000 is offline
Studenting is hard, but worth it!
AKA: David Carpenter
no team (Jerry-Rigg school of DuctTapeology)
carpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant future
-Hugh
Definately see some drivetrain use here. To prevent being pushed backwards/forwards, have something clamp down on the yellow part to lock up the whole thing.
Unread 04-07-2015, 15:30
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Neat! I couldn't see this being used for FRC though, maybe for big arms that require large reductions. The issue would be finding internal gears with a tooth difference of 1 (unless you offset the internal gears and used a spur as an output).
Unread 05-07-2015, 08:02
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
This looks similar to the Pittsburgh Torque Multiplier Lugnut Remover.
Richard Wallace
since 2003
Unread 05-07-2015, 09:31
wgardner's Avatar
wgardner wgardner is offline
wgardner is a splendid one to beholdwgardner is a splendid one to beholdwgardner is a splendid one to beholdwgardner is a splendid one to beholdwgardner is a splendid one to beholdwgardner is a splendid one to beholdwgardner is a splendid one to behold
It's like the 3D printed gearbox shown at this link, but with more teeth.
CHEER4FTC website and facebook online FTC resources.
Providing support for FTC Teams in the Charlottesville, VA area and beyond.
Unread 05-07-2015, 10:07
Clem1640's Avatar
Clem1640 Clem1640 is offline
Head Mentor
AKA: Clem McKown
FRC #1640 (Sab-BOT-age)
Clem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond repute
This is a harmonic drive, also known as strain wave gearing. It provides very high reductions can provide very high torque and does not suffer from backlash.
This technology is used and available commercially.
http://harmonicdrive.net/
It is distinctly different from Cycloidal gearing, but the two do share some attributes. Primarily, both advance the output by one tooth of an annular gear for every full rotation of the input shaft.
Clem McKown
Head Mentor - FRC 1640 & FTC 7314
Chairman - Downingtown Area Robotics
Unread 05-07-2015, 10:44
Foster Foster is offline
Engineering Program Management
VRC #8081 (STEMRobotics)
Foster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond repute
Originally Posted by Richard Wallace View Post
Thanks for the link and the blast from the past. I just spent 20 mins following all the threads back. It does look like it would be good for arm movements.
The printed one seems like it would have lots and lots of chatter. There is one post that talks about having a finer pitch so it's a lot smoother movement.
Ahh the things you learn here on a lazy Sunday morning
Foster - VEX Delaware - 17 teams -- Chief Roboteer STEMRobotics.org
2010 - Mentor of the Year - VEX Clean Sweep World Championship
2006-2016, a decade of doing VEX, time really flies while having fun
Downingtown Area Robotics Web site and VEXMen Team Site come see what we can do for you.
Unread 05-07-2015, 15:40
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
No, harmonic/strain wave has all three gears concentric in the same plane, with a flexible intermediate gear, forming a single stage of reduction. This unit has none of those features:
  • all of the pieces are nominally rigid
  • the drive gear unit is not concentric with the two annular gears
  • it is two stage - the inpututput gear ratio is the product of two stages (or it can be more physically viewed as the difference between the two ratios (for a<b, 1/a - 1/b = 1/ab, or if you swap a and b, you get -1/ab).
This drive can also be used to generate a rotation in the same direction as the input, or the opposite direction, by switching which of the two annular gears is fixed and which is rotating.
Last edited by GeeTwo : 05-07-2015 at 21:19. Reason: extended subtraction to negative case
