Go to Post So kudos for asking advice... you've got plenty of good advice so far in this column... but honestly, if Orville and Wilbur Wright had taken good advice they would have packed up and gone back to their bicycle shop. - dtengineering [more]
Unread 07-01-2015, 08:12 PM
Phoenix Spud's Avatar
Phoenix Spud Phoenix Spud is offline
Everyone. Everywhere.
FRC #3132 (Thunder Down Under)
Phoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond repute
How do you use the WPILib?
As part of a university project, I'm looking at the WPILib (language independent) and how teams use it. In particular I'm interested in:
What classes do you use the most?
Do you edit any of the provided classes?
Do you extend any of the provided classes?
What features do you wish WPILib had?
Thanks!
Sarah Heimlich
Outreach Mentor | Business Mentor
FIRST® TEAM 3132
Unread 07-01-2015, 10:07 PM
Dartmouth 2020
AKA: lopsided98
FRC #2084 (Robots by the C)
Re: How do you use the WPILib?
Well, for one, all the classes relating to hardware control (Jaguar, Talon, Double/SingleSolenoid). Also, our code uses are huge amount of Commands and CommandGroups.
We wrote our own analog gyro driver that was an edited version of the Gyro class. It was designed to follow the same pattern as the accelerometer drivers.
We extended the Command class to provide the ability to set parameters through the SmartDashboard easily. Also, we extend the Command, IterativeRobot and Subsystem classes through the normal usage of the API.
I could probably think of a few smaller things if I were working on the robot code right now, but there is no major addition or change that I can think of.
Unread 07-05-2015, 11:30 PM
virtuald's Avatar
virtuald virtuald is offline
RobotPy Guy
AKA: Dustin Spicuzza
SampleRobot, Solenoid, AnalogInput, Jaguar/Talon et al, and Timer.
Well, we rewrote most of them in python...
The python version of WPILib tends to very strictly follow the spirit of the C++/Java API. I believe very strongly that if our team needs to modify WPILib, then we make a patch available on the WPILib bug tracker so that others can benefit from it, in all languages. Other modifications will tend to either extend existing objects, or create new objects based on the existing objects instead.
I tend to prefer creating new objects that hold WPILib objects as member variables instead of extending them.
  • I think command-based programming is too verbose.
  • I would like better testing/simulation support in WPILib
Unread 07-06-2015, 12:46 AM
SoftwareBug2.0's Avatar
AKA: Eric
FRC #1425 (Error Code Xero)
SampleRobot
Solenoid
VictorSP
AnalogInput
CANTalon
DigitalInput
DigitalOutput
Bugfixes only.
SampleRobot: Wrapper turns the various calls into it a call of a single function with what is happening as an argument.
Simplicity and correctness. Despite the fact that we write C++ we wrap WPIlib extensively to avoid using its interface to the extent this is practical.
Unread 07-06-2015, 06:53 AM
calcmogul's Avatar
calcmogul calcmogul is offline
WPILib Developer
AKA: Tyler Veness
FRC #3512 (Spartatroniks)
calcmogul is just really nicecalcmogul is just really nicecalcmogul is just really nicecalcmogul is just really nice
This year, we used the CANTalon in place of Encoder, PIDController, and DigitalInput.
SampleRobot
CANTalon
Solenoid
Timer
We edited the PIDController class to include dt in the I accumulation and error derivative calculations. In other cases, we replace classes. Some of the interfaces we've written already had equivalents in WPILib, but we didn't use the provided ones because we either didn't know about them, like the Preferences class, or we didn't like their implementation, like NetworkTables. There could also be some FUD with respect to the command-based paradigm versus our state machine classes (although we approached it differently than WPILib).
We wrap motor controllers in a GearBox template class when they control motors in the same physical gearbox. It allows us to control them as a single unit and includes an interface for shifting, encoders, and PID control.
With regards to external features, one of my students wants the CANTalon PID interface and PIDController class to match so that one can switch between them easily.
Most of my complaints are about WPILib's implementation, and I'm trying to get them fixed. Const correctness was an issue, but a patch got accepted for that recently. There's also thread safety, which is being C++11'ified (if that's a thing) for maintainability. I wish WPILib handled ownership of objects properly with move semantics. Currently, one can pass pointers into classes like RobotDrive and still need to delete them externally later. (At least that's what the examples do.) It makes more sense for the RobotDrive instance to take ownership of them via smart pointers. I'm told there will be patches for that ready for review soon. The interfaces for classes could be smaller as well. I think some of it is common behavior and could be refactored back into its respective base classes.
Unread 07-06-2015, 07:34 AM
marshall's Avatar
marshall marshall is offline
FRC #0900 (The Zebracorns)
Network Tables.
Network Tables.
Network Tables.
Better Network Tables.
Yes, my tongue was firmly implanted in my cheek for those responses. Though we do use Network Tables and it really does need some work. Last I heard the WPI folks were working on it.
Unread 07-06-2015, 09:39 AM
Data Nerd
FRC #0079
I'll second both of these. One of the big reasons we're evaluating python for future uses is the strong simulation and testing support. (Ok, and the fact that I think Java is too verbose in general).
Unread 07-06-2015, 02:31 PM
Volunteer, WPILib Contributor
no team (Waiting for 2021)
We use LabVIEW currently, but are potentially looking at switching to .NET or Java.
Since LabVIEW works differently then the other 2, the WPILib is different there. However, since I've been working on the .NET port, better simulator support would be very helpful. I've been using Pythons implementation as a base, and it easily works better then either of the 3 officially supported languages. If teams had an easy to use simulator and test bench, I bet we would see much better code from teams.
The other think I would like to see is more code uniformity. I know they are working on that, so it should be better for next season, but for now you can tell it's been written over 5 years, and its time for some cleanup.
Team 4488 - Mentor 2013-2016
Unread 07-06-2015, 09:20 PM
Camilo86's Avatar
Camilo86 Camilo86 is offline
AKA: camilo
FRC #0125 (Nutrons)
Camilo86 is a glorious beacon of lightCamilo86 is a glorious beacon of lightCamilo86 is a glorious beacon of lightCamilo86 is a glorious beacon of lightCamilo86 is a glorious beacon of lightCamilo86 is a glorious beacon of light
Would be nice if there was any support for simulation/testing like robotpy has
Hopper finalist 2015
Dean's List winner 2015
Unread 07-06-2015, 10:42 PM
virtuald's Avatar
RobotPy Guy
Actually, we use NetworkTables extensively too -- I forget it's part of WPILib because we split it out from WPILib for the python implementation.
I'm pretty sure the Java/C++ implementations of NetworkTables have difficult to reproduce deadlock issues in them, which is something I wish they would fix.
Unread 07-07-2015, 10:32 AM
Joey1939's Avatar
Joey1939 Joey1939 is offline
AKA: Joey Holliday
FRC #1939 (Kuhnigits)
Joey1939 has a spectacular aura aboutJoey1939 has a spectacular aura aboutJoey1939 has a spectacular aura about
CANTalon (With direct encoder input and PID control)
RobotDrive (Makes driving easy)
CommandGroup (Create multiple autonomous modes easily)
Command
No
Yes, I extended Joystick to make a custom mapping for our specific joystick. I may extend CANTalon next year to make controlling it easier.
1. A built in way to simulate the code running on a RoboRIO, manipulate inputs, and display outputs. (Side note: I realize that there are other options for this, but all of them require you to use their library. I prefer using the plain WPILib library.)
2. Documentation on how to make SmartDashboard plugins/more plugins
Unread 07-07-2015, 11:58 AM
Toa Circuit's Avatar
Toa Circuit Toa Circuit is offline
Thaddeus Maximus
AKA: Thad Hughes
FRC #4213 (MetalCow Robotics)
Toa Circuit is an unknown quantity at this point
IterativeRobot, Jaguar/Talon/Victor etc. DoubleSolenoid... DigitalInput... Encoder... you know, your basic I/O stuff.
And SmartDashboard.
We don't modify source... but...
YES. Most classes get extended:
1. Joystick gets a custom class with stuff like GetButtonTripped(), GetLX(), GetLMagnitude(), GetLAngle(), etc. specific to the joystick mapping.
2. Jaguar/Talon/Victor have:
- A "invert" flag so we can wire correct colors AND have our higher level code look like what corresponds to what is going on (I.E. invert one side of a tank drivetrain)
- A throttle variable so we can slowly ramp up/down a motor
Having the invert flag built into the SpeedController interface would be nice.
An intelligent SmartDashboard which guaruntees values will exist for the client to modify. I.E. SmartDashboard.guarunteeValue("Gyro KP", 1.5);
I know it isn't really WPILib, but fixing SmartDashboard so it actually retains layouts and values would be great. WPILib is nice and stable, not much to change. It's the other tools that are icky.
2012 Head of Programming and Electrical
2013-14 Overall Team Captain and Programming Head
2012-14 Mentor of FLL Team Power Surge
2014 Dean's List Finalist
2014 CIR Xerox Creativity Award
Webpage
Unread 07-07-2015, 10:21 PM
calcmogul's Avatar
WPILib Developer
AKA: Tyler Veness
SpeedController already has a SetInverted() method that does what you describe.
Unread 07-07-2015, 11:45 PM
It was added this summer.
Unread 07-10-2015, 01:33 AM
Peter Johnson Peter Johnson is offline
WPILib Developer
Peter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud of
I have good news for you (and others who've run into issues with NetworkTables). I'm currently rewriting the NetworkTables implementation core from the ground up as a portable C++ library (with C interfaces) to fix the deadlocks and improve performance. The plan for WPILib is to update both the C++ and Java higher level classes to use this core library (similar to how NetworkCommunication is used) for consistency across languages. It's currently TBD whether LabView will use this library or continue using a LabView-native implementation. And before anyone asks, yes, the new implementation will be extensively unit-tested (I'm expecting to have at least several hundred unit tests).
In addition to the implementation rewrite, we're revising the protocol (in a backwards-compatible way) to fix a number of issues (more consistent synchronization) and make the protocol in general a bit more robust. As part of this, we're also adding a few features, including integrated value persistence (think Preferences++), remote procedure calls, server reboot detection, and client self-identification.
Author of ntcore - WPILib NetworkTables for 2016+
Creator of RobotPy - Python for FRC
2010 FRC World Champions (294, 67, 177)
2007 FTC World Champions (30, 74, 23)
2001 FRC National Champions (71, 294, 125, 365, 279)
