Go to Post No amount of sleep beforehand will make up or prepare you for the lack of sleep you will receive during build season. - Dan Petrovic [more]
Unread 08-07-2015, 18:48
skatefriday skatefriday is offline
skatefriday is an unknown quantity at this point
Re: [FTC]: FTC Game Manual for 2015-2016?
Originally Posted by skatefriday View Post
So say we want to supply 25mA to an arduino (a typical draw), do
we hook it up to one of the digital out ports? The documentation also
says Digital current limit: 220 ohm resistor.
Using I = V/R, I = 5/220 = .0227A, or roughly 23mA.
Am I reading this correctly then that we should not draw more
than 23mA out of any single digital port?
I hadn't noticed this before but you can pull 500mA out of
each usb port on the power distro module. That solves that
problem.
Unread 08-07-2015, 19:01
MattRain MattRain is online now
AZ FTC AF, FTC #2844 and FTC #8640
FRC #1492 (Team Caution)
Team Role: RoboCoach
MattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant future
I've always hated the robots that are nothing but a 40 pound
slab of metal and a drivetrain.
And that's why you take a 40 pound slab of metal robot drivetrain, and place something useful/helpful/working on top. Makes for a good robot.
Our robots this past year were 50+ pounds.
2015 FTC WORLD CHAMPIONS
www.valleyx2844.com
Twitters: Valley X & Trojan Robotics & Team Caution
(World Championship Counter: 5)
*All my posts reflect my opinion, not my teams.*
"I WANT CHEETOS!" - Bad Lip Reading 2016 <-- ME
Unread 08-07-2015, 19:28
Sasha Sasha is offline
AKA: Alexander Kirillov
FTC #4137 (IslandBots)
Sasha is just really niceSasha is just really niceSasha is just really niceSasha is just really niceSasha is just really nice
So say we want to supply 25mA to an arduino (a typical draw), do we hook it up to one of the digital out ports? The documentation also says Digital current limit: 220 ohm resistor.
As far as I understand, Arduino (or any other MC) is not allowed. The rules allow sensors and lights, but no other electronics. I do not believe that you can argue that Arduino is a sensor.
FTC 4137 "Islandbots"
islandbots.org
Unread 08-07-2015, 19:57
Microcontrollers have been allowed for the last 4 years at least.
I'd find it hard to believe that they are outlawing them this year.
Unread 08-07-2015, 20:30
I believe rule RE06 is quite explicit:
Additional Robot electronics are subject to the following constraints:
a. Light sources (including LEDs) are allowed; these may not be focused or directed in any way (for example: laser s and mirrors are not allowed).
b. Sensors
c. Video recording devices (GoPro or similar) are allowed providing they are used only for non-functional post match entertainment and the wireless capability is turned off
d. Other electronics are not allowed.
Arduino is certainly not a sensor (nor is it a light source or video recording device , so it is not allowed - at least, according to my reading of the rules. Once the official FTC forums open, we can ask for a confirmation there.
islandbots.org
Unread 08-07-2015, 20:37
Actually I disagree. An accelerometer is effectively a specialized
microcontroller. Are we going to assert that it's not a sensor?
The term "sensor" is exceedingly broad and given the way they
wrote the rules this year I think they mean it to be interpreted in
a broad manner.
I presume this will be one of the first questions asked when the official
forums open up.
Unread 09-07-2015, 02:31
PHFTC PHFTC is offline
FTC #8045
PHFTC is an unknown quantity at this point
I believe most sensors these days have some sort of micro processor on board, so an arduino/launchpad etc doesn't seem that out of the question.
I certainly hope that the uprocesser isn't intentionally banned - that would only seem like an effort to move kids who really want to do more to the FRC world...
I suppose the old superpro is a legacy sensor right?
Unread 09-07-2015, 19:56
New motors are coming out on Andymarks website. NeveRest 20 and 60
NeveRest 20 (am-3102) ($25.00)
Physical Specs:
Overall Length: 5.18"
Maximum Diameter: 37mm (1.46 in)
Output Shaft size: 6mm (0.24 in) with 0.5mm deep flat
Weight: 0.762 Pounds
Mounting Holes: M3 tapped holes, qty. 6, on a 31mm bolt circle
Electrical Connection Geometry: 6-pin connector for motor power and encoder contact
Gear Material: Steel
Body Material: Steel with plastic encoder housing
Lubrication: Included with gearbox
Theoretical Performance Specs:
Gearbox Reduction: 20:1
Voltage: 12 volt DC
No Load Free Speed, at gearbox output shaft: 315 RPM
Gearbox Output Power: 14W
Stall Torque: 197 oz-in
Stall Current: 11.5A
Output pulse per revolution of Output Shaft (ppr): 560 Pulses
Performance Specs, mounted to AndyMark dyno: Coming Soon
Max Speed (under load of dyno):
No Load Current (under load of dyno):
Stall Current:
Stall Torque:
Max Output Power:
Time to Failure at Stall:
Motor Case Temperature at Failure:
NeveRest 40 (am-2964) Released last year ($25.00)
Physical Specs:
Overall Length: 133.5mm (5.26 in)
Weight: 0.75 pound
Performance Specs:
Gearbox Reduction: 40:1
Voltage: 12 volt DC
No Load Free Speed, at gearbox output shaft: 160 rpm
No Load Free Speed, motor only: 6,600 rpm
Stall Torque: 350 oz-in
Stall Current: 11.5 amps
Force Needed to Break Gearbox: 1478 oz-in
Minimum torque needed to back drive: 12.8 oz-in
Output pulse per revolution of Output Shaft (ppr): 1120 (280 rises of Channel A)
Output pulse per revolution of encoder shaft (ppr): 28 (7 rises of Channel A)
Max Speed (under load of dyno): 129 rpm
No Load Current (under load of dyno): 0.4 amps
Stall Torque: 396 oz-in
Max Output Power: 15 Watts
Time to Failure at Stall: 2 minutes, 54 seconds
Motor Case Temperature at Failure: 190 degrees F
NeveRest 60 (am-3103) ($25.00)
Physical Specs:
Weight: 0.776 pounds
Gearbox Reduction: 60:1
Voltage: 12 volt DC
No Load Free Speed, at gearbox output shaft: 105 RPM
Stall Torque: 593 oz-in
Output pulse per revolution of Output Shaft (ppr): 1680 Pulses
Stall Current:
Stall Torque:
Max Output Power:
NeveRest Motor (am-3104) ($15.00)
Specifications:
Physical Specs:
•Overall Length: 75mm (2.95 in)
•Maximum Diameter: 38mm (1.49 in)
•Weight: 0.550 Pounds
•Mounting Holes: 3x M2-0.4 x 22mm deep
•Electrical Connection Geometry: 6-pin connector for motor power and encoder contact
•Gear Material: Steel
•Body Material: Steel with plastic encoder housing
•Voltage: 12 volt DC
•No Load Free Speed: 6600 RPM
•Power: 14W
•Stall Torque: 8.75 oz-in
•Stall Current: 11.5 A
•Output pulse per revolution of Output Shaft (ppr): 28
(SOURCE: www.andymark.com)
www.valleyx2844.com
Unread 09-07-2015, 20:19
CougarRobot CougarRobot is offline
FTC #4251 (Cougar Robotics)
CougarRobot is a splendid one to beholdCougarRobot is a splendid one to beholdCougarRobot is a splendid one to beholdCougarRobot is a splendid one to beholdCougarRobot is a splendid one to beholdCougarRobot is a splendid one to behold
Originally Posted by wgardner View Post
I like this gem from 5.3.1: "One example of a guiding principle is that if a Team would not want an opponent to use a particular design feature against them, it is likely that it will not be allowed in competition."
Let's see how they're going to enforce that one.
I really dislike when opponents use design features against us that score points. Particularly if they score more points than we score.
Unread 09-07-2015, 20:40
Right but don't forget that you want your opponents to score
points, just one less point than you do. Those ranking points
matter.
Unread 10-07-2015, 14:50
Andymark has released all of the new motors. It looks like a nice line of motors. NeveRest Line.
One of the motors in the line comes without a gearbox. I wonder if they will release other gearbox that you can purchase to repair motors/gearboxes.
It was nice at Worlds for them to replace the NeveRest 40's if you broke them at any part of the season.
www.valleyx2844.com
