Go to Post The top 3 debates you don't want to bring up in a group of nerds: Mac vs PC vs Linux, Best Programming Language, and Best CAD Program. - EricH [more]
Thread Tools Rating: Thread Rating: 4 votes, 4.00 average. Display Modes
Unread 12-07-2015, 18:24
MattRain MattRain is offline
AZ FTC AF, FTC #2844 and FTC #8640
FRC #1492 (Team Caution)
Team Role: RoboCoach
MattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant future
[FTC]: All Motors - Legal for 2015-2016 (Links/Pricing/Specs)
This is the list of motors, with pricing, links, and specs that I could find. These are all of the motors allowed for this year's season. An interesting line up.
Game Manual Part 1 <RE04>
Modern Robotics and Legacy HiTechnic motor and servo controllers
- Allowed motors are TETRIX/AndyMark/MATRIX 12 VDC
o TETRIX W39530
o AM-2964, AM-3102, AM-3103, AM-3104
o MATRIX 14-0014
Legacy MATRIX Motor and Servo controllers (unified module)
- With a 12 VDC MATRIX Battery Pack, allowed motors are MATRIX 12
VDC
o MATRIX 14-0014
- With a 9.6 VDC MATRIX Battery Pack, allowed motors are Legacy
MATRIX 9.7 VDC motors
o MATRIX 50-0001, 50-0012
Modern Robotics and Legacy HiTechnic and servo controllers
- Allowed motors are VEX motors
o VEX EDR 393
Andymark:
Encoder Cables:
am-2992
http://www.andymark.com/product-p/am-2992.htm
am-2965 http://www.andymark.com/product-p/am-2965.htm
NeveRest 20 (am-3102) ($25.00) (Encoder Included) (ENCODER CABLE NOT INCLUDED)
http://www.andymark.com/NeveRest-20-p/am-3102.htm
Physical Specs:
Overall Length: 5.18"
Maximum Diameter: 37mm (1.46 in)
Output Shaft size: 6mm (0.24 in) with 0.5mm deep flat
Weight: 0.762 Pounds
Mounting Holes: M3 tapped holes, qty. 6, on a 31mm bolt circle
Electrical Connection Geometry: 6-pin connector for motor power and encoder contact
Gear Material: Steel
Body Material: Steel with plastic encoder housing
Lubrication: Included with gearbox
Theoretical Performance Specs:
Gearbox Reduction: 20:1
Voltage: 12 volt DC
No Load Free Speed, at gearbox output shaft: 315 RPM
Gearbox Output Power: 14W
Stall Torque: 197 oz-in
Stall Current: 11.5A
Output pulse per revolution of Output Shaft (ppr): 560 Pulses
Performance Specs, mounted to AndyMark dyno: Coming Soon
Max Speed (under load of dyno):
No Load Current (under load of dyno):
Stall Current:
Stall Torque:
Max Output Power:
Time to Failure at Stall:
Motor Case Temperature at Failure:
NeveRest 40 (am-2964) Released last year ($25.00) (Encoder included) (ENCODER CABLE NOT INCLUDED)
http://www.andymark.com/NeveRest-40-p/am-2964.htm
Physical Specs:
Overall Length: 133.5mm (5.26 in)
Weight: 0.75 pound
Performance Specs:
Gearbox Reduction: 40:1
Voltage: 12 volt DC
No Load Free Speed, at gearbox output shaft: 160 rpm
No Load Free Speed, motor only: 6,600 rpm
Stall Torque: 350 oz-in
Stall Current: 11.5 amps
Force Needed to Break Gearbox: 1478 oz-in
Minimum torque needed to back drive: 12.8 oz-in
Output pulse per revolution of Output Shaft (ppr): 1120 (280 rises of Channel A)
Output pulse per revolution of encoder shaft (ppr): 28 (7 rises of Channel A)
Max Speed (under load of dyno): 129 rpm
No Load Current (under load of dyno): 0.4 amps
Stall Torque: 396 oz-in
Max Output Power: 15 Watts
Time to Failure at Stall: 2 minutes, 54 seconds
Motor Case Temperature at Failure: 190 degrees F
NeveRest 60 (am-3103) ($25.00) (Encoder included) (ENCODER CABLE NOT INCLUDED)
http://www.andymark.com/NeveRest-60-p/am-3103.htm
Physical Specs:
Weight: 0.776 pounds
Gearbox Reduction: 60:1
Voltage: 12 volt DC
No Load Free Speed, at gearbox output shaft: 105 RPM
Stall Torque: 593 oz-in
Output pulse per revolution of Output Shaft (ppr): 1680 Pulses
Stall Current:
Stall Torque:
Max Output Power:
NeveRest Motor (am-3104) ($15.00) (Encoder Included) (ENCODER CABLE NOT INCLUDED)
http://www.andymark.com/NeveRest-Motor-p/am-3104.htm
Physical Specs:
•Overall Length: 75mm (2.95 in)
•Maximum Diameter: 38mm (1.49 in)
•Weight: 0.550 Pounds
•Mounting Holes: 3x M2-0.4 x 22mm deep
•Electrical Connection Geometry: 6-pin connector for motor power and encoder contact
•Gear Material: Steel
•Body Material: Steel with plastic encoder housing
•Voltage: 12 volt DC
•No Load Free Speed: 6600 RPM
•Power: 14W
•Stall Torque: 8.75 oz-in
•Stall Current: 11.5 A
•Output pulse per revolution of Output Shaft (ppr): 28
Tetrix:
Tetrix MAX DC Gear Motor (Product ID W39530) $24.95, 6-PACK $208.95 (20% discount at check out) (NO ENCODER)
Single: https://www.tetrixrobotics.com/extra..._DC_Gear_Motor
6-pack, Plus extras: https://www.tetrixrobotics.com/extra...otor_Bulk_Pack
Normal Operation Conditions
- Rated Voltage: 6-13.8 V
- Ambient Temp. -10-+60 C
- Rotate direction: CW
Test condidtions
- Voltage DC 12V
- Ambient Temp 28 C
- Ambient Humidity 22%RH
* The tested sample is set level
Electrical features (After 30 seconds electrify)
- No-load Speed 150+- 10%rpm
- No-load current: 0.34A (0.66A max)
- Load toqure: 3.9kg.cm
- Load current 0.91A (1.37A max)
- Load Speed: 137.5+- 10%rpm
- Stall torque: /
- Stal current: /
Mecanical characteristics
- Axial play of shaft <= 0.5mm
Motor features
- No-load Current: 0.19A
- No-load speed: 1100+_ 10%rpm
Time to Failure at Stall: 6 seconds (<-- Testing other teams and we have done)
PDF of above: https://c10645061.ssl.cf2.rackcdn.co...otor739530.pdf
Matrix:
12v Motor Kit $43.95 (Includes mounting hardware) (Encoder Included)
http://modernroboticsinc.com/12v-motor-kit-50-0014
9.7v Motor Kit $43.95 (Includes mounting hardware) (Encoder Included)
http://modernroboticsinc.com/high-to...-kit-50-0012-2
Vex:
VEX EDR 393: $14.99 (NO ENCODER)
http://www.vexrobotics.com/vex/produ...on/motors.html
2015 FTC WORLD CHAMPIONS
www.valleyx2844.com
Twitters: Valley X & Trojan Robotics & Team Caution
(World Championship Counter: 5)
*All my posts reflect my opinion, not my teams.*
"I WANT CHEETOS!" - Bad Lip Reading 2016 <-- ME
Unread 12-07-2015, 19:25
cadandcookies's Avatar
cadandcookies cadandcookies is offline
Director of Programs, GOFIRST
AKA: Nick Aarestad
FTC #9205 (The Iron Maidens)
cadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond repute
Re: [FTC]: All Motors - Legal for 2015-2016 (Links/Pricing/Specs)
Very excited for the increased options on NeverRest motors. Those were fantastic last year and I know my team will love having more options.
Never assume the motives of others are, to them, less noble than yours are to you. - John Perry Barlow
tumblr | twitter
'Snow Problem CAD Files: 2015 2016
MN FTC Field Manager, FTA, CSA, Emcee
FLL Maybe NXT Year (09-10) -> FRC 2220 (11-14) -> FTC 9205(14-?)/FRC 2667 (15-16)
VEXU UMN (2015-??)
Volunteer since 2011
2013 RCA Winner (North Star Regional) (2220)
2016 Connect Award Winner (North Super Regional and World Championship) (9205)
Unread 01-10-2015, 13:01
NeveRest 20 (am-3102) Price went up from $25 to $28.
NeveRest 60 (am-3103) Price went up from $25 to $28.
NEW Replacement Gearboxes!
NeveRest 20 Gearbox, No Motor (am-3105) http://www.andymark.com/product-p/am-3105.htm
NeveRest 40 Gearbox, No Motor (am-3106) http://www.andymark.com/product-p/am-3106.htm
NeveRest 60 Gearbox, No Motor (am-3107) http://www.andymark.com/product-p/am-3107.htm
(NeveRest) 20:1 Gearbox (8mm Hex) http://www.revrobotics.com/product/rev-41-1064/
(NeveRest) 40:1 Gearbox (8mm Hex) http://www.revrobotics.com/product/rev-41-1065/
(NeveRest) 60:1 Gearbox (8mm Hex) http://www.revrobotics.com/product/rev-41-1066/
Unable to edit the top post.
www.valleyx2844.com
Unread 01-10-2015, 14:40
ehochstein's Avatar
ehochstein ehochstein is offline
Coach, Volunteer & Mentor
AKA: Evan Hochstein
FTC #5943 (ESGM)
ehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant future
I believe this is because these two models of the NeveRest come with PowerPoles attached.
Minnesota FIRST Senior Mentor | 2013-?
Stratasys Applications Engineering Technician | 2016-?
2009 Regional Win – 2470 @ 10k Lakes (Thanks 2826 and 1714)
2013 WFFA Recipient – 2470 @ 10K Lakes
2016 Ri3D: 'Snow Problem Reveal
2017 Ri3D: 'Snow Problem Reveal
The opinions expressed above are the personal opinions of the author and do not necessarily represent the views and opinions of any organization the author is affiliated with.
Unread 02-10-2015, 13:37
M. Mellott's Avatar
M. Mellott M. Mellott is offline
CAD God
AKA: Mike Mellott
FRC #3193 (Falco Tech), FRC #48 (Delphi E.L.I.T.E.), FTC #9980 (FMF)
M. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud of
* Note: BRAND new to the FTC world, so bear with me! *
If I use the VEX 393 Motor, can I use the VEX Motor Controller 29 (p/n 276-2193) in addition to the motor controller unit in the kit, or can I only use the kit MC unit?
BTW, thank you for posting these specs and links--this will be very handy!!
In the continuing battle between innovative engineering and the laws of physics...physics always wins.
Unread 02-10-2015, 14:35
AKA: Nick Aarestad
The yellow box was recently updated:
Originally Posted by FTC Game Manual
Modern Robotics and Legacy HiTechnic Motor Controllers
 Allowed motors are TETRIX/AndyMark/MATRIX 12 VDC
o TETRIX W39530
o MATRIX 50-0014, 50-0012
 With a 12 VDC MATRIX Battery Pack, allowed motors are MATRIX 12
VDC
 With a 9.6 VDC MATRIX Battery Pack, allowed motors are Legacy
o MATRIX 14-0001, MATRIX 14-0009
Modern Robotics and Legacy HiTechnic Servo controllers
 VEX EDR 393 DC Motor (with a single VEX Motor Controller 29 per 393
motor) – only when connected to a Servo Controller (observing Servo
Controller power limits, maximum of two 393 DC motors per Servo
Controller).
 Each VEX EDR 393 DC motor with Motor Controller 29 is counted as a
single DC motor (and not a servo).
tumblr | twitter
VEXU UMN (2015-??)
Unread 04-10-2015, 10:30
DavisDad's Avatar
DavisDad DavisDad is offline
MechE
AKA: Craig Rochester
FTC #8470 (Team Technado)
DavisDad will become famous soon enoughDavisDad will become famous soon enough
Modern Robotics Inc. (Matrix Robotics) hasn't published specs for the Matrix 12V gear-motor. I like this motor a lot with the planetary gears, which are typically more efficient and durable than the spur gears used by AndyMark and Tetrix. I did some preliminary testing and posted results here: http://www.chiefdelphi.com/forums/sh...61&postcount=7 with a drawing of dimensions.
