Go to Post Ah, to be a teenager and know everything again. - Alan Anderson [more]
Unread 12-07-2015, 22:30
hectorcastillo's Avatar
hectorcastillo hectorcastillo is offline
Former Driver and Captain for 3481
FRC #0125 (NUTRONs)
hectorcastillo is a name known to allhectorcastillo is a name known to allhectorcastillo is a name known to allhectorcastillo is a name known to allhectorcastillo is a name known to allhectorcastillo is a name known to all
pic: Four Speed Three CIM Gearbox
Unread 12-07-2015, 22:31
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Re: pic: Four Speed Three CIM Gearbox
What advantage(s) do you expect from having a four-speed, 3CIM gearbox over a two-speed 3CIM gearbox? A four-speed 2CIM gearbox? Heck, even a single-speed 3CIM gearbox?
Basically, why? This seems like overkill.
Unread 12-07-2015, 22:35
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
It looks quite well done for the project. It's not useful for competition, but it looks good anyway.
Nice render too.
For the top shaft of the gearbox, instead of using a hex bearing, I would round down the end of the shaft and use a round bearing.
If you only have 2 standoffs going to the mounting plate, I would change it to 3-4.
EDIT: +1 on the PTO idea.
Unread 12-07-2015, 22:50
Gregor's Avatar
Gregor Gregor is offline
#StickToTheStratisQuo
AKA: Gregor Browning
Did you read the description?
FRC 2011-xxxx Volunteer
How I came to be a FIRSTer
<Since 2011
Unread 12-07-2015, 23:07
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
To me, the big "why" is why have four speeds over about a total 3:1 high-to-low ratio? If you're going to bother with four speeds, spread them out a bit wider!
At a minimum, I would put the shifts a factor of 2:1 apart, resulting in an 8:1 overall ratio from high to low. At a "standard" 2.56:1 ratio between shifts, the total range would be 16.77:1. At 3:1 per shift, it would be a massive 27:1, which could be a real game changer in some highly defensive games or games with steep ramps. Especially if you want to reserve some CIMs for manipulators!
Last edited by GeeTwo : 12-07-2015 at 23:17. Reason: Added 2.56 sentence, Especially sort-of-sentence.
Unread 12-07-2015, 23:19
FRC #0125 (NUTRONs)
When I was playing around with the JVN calculator I was trying to get them as wide as possible. The limiting factor, though, was that the two speeds that we wanted for the end game were 17fps and 12.72fps, which put limit on how much i could work the speeds while still keeping it realistic. I guess I was just focusing on the speeds needed for this game and not the wide array that there could have been.
365 Decontaminators (FLL) 2011 - 2012
6221 Panther Bots Alpha (FTC) 2012 - 2016
3481 Bronc Botz (FRC) 2012 - Present
125 NUTRONs (FRC) 2017 - Present
Unread 13-07-2015, 18:15
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Under what scenario would that be useful? Once you can break traction you see no benefit to moving slower, unless somehow you needed to very precisely position your robot with fine movements.
2001-2004: Team 100
2006-Present: Team 254
Unread 13-07-2015, 22:17
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
Who says that your robot always has the same weight? I seem to recall that there was a game in which robots extended a ramp to lift their alliance partners. I also "blue skied" a robot for Ultimate Ascent which would have literally grappled its alliance partners and made a 90 point outside climb (code name Fezzik, for fans of The Princess Bride). If you wanted that same robot to also fly around the field scoring frisbees for the first hundred seconds of the match, having a multi-speed PTO transmission with a total span of 20+:1 would have been epic.
Unread 13-07-2015, 23:19
magnets's Avatar
magnets magnets is offline
I always love these hypothetical crazy gearboxes and ratios people come up with. Practical, maybe not, but definitely awesome.
Assuming your robot was geared for 18 feet per second in high gear, and 0.67 feet in low gear (a 27:1 spread), you'd need to have a 1800 lb robot (or group of robots) to take advantage of the gear ratio and never trip the breaker in a pushing match. If the robot weighed any less, you could get away with a smaller spread and never worry about tripping a breaker.
That sounds like my kind of game!!
Unread 14-07-2015, 01:27
thatprogrammer's Avatar
thatprogrammer thatprogrammer is offline
AKA: Ahad Bawany
no team (None)
thatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond repute
2002 meant your robot could be several hundred pounds due to how heavy the movable goals were. 71 could drag over 900 pounds that year!
Unread 12-07-2015, 23:11
FRC #0125 (NUTRONs)
Thanks, yeah I know it's really overkill. So basically to answer the question of why I decided four speed, my team is working on the summer design project thing that was put out a couple weeks ago. The end game involves chasing down a mini bot on the field, so the end game team wanted to be able to travel at the mini bot's speed (~13fps) to line up with it and a faster speed to catch up to it. We also wanted to be able to move around a little slower with more control for adjusting shots and in case anyone wants to push us. I know we could've gone with a two speed and controlled the speed with code, but that's what the team decided to go with. Also, it gave me a nice challenge which is always fun.
Ever considered taking that third and fourth position and turning it into a PTO? That wouldn't be very important in a game like 2015 whatsoever, nor a game like 2014. But, for example, in 2013, 254 used a PTO to power their awesome climber.
Our 2013 drive train gearbox used a PTO to power our climbing mechanism as well. There was something wrong with the throw of the shifter that made it not work, but it was still pretty cool. I don't think there's an opportunity in the game that we're designing for to use a PTO, but I did think about it while designing this.
Unread 12-07-2015, 23:15
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Description wasn't posted when I posted my comment.
Unread 15-07-2015, 15:16
The other Gabe's Avatar
The other Gabe The other Gabe is offline
Too many events, not enough time
AKA: I'm a volunteer now!
no team (2046 Bear Metal Alumn)
The other Gabe has much to be proud ofThe other Gabe has much to be proud ofThe other Gabe has much to be proud ofThe other Gabe has much to be proud ofThe other Gabe has much to be proud ofThe other Gabe has much to be proud ofThe other Gabe has much to be proud ofThe other Gabe has much to be proud ofThe other Gabe has much to be proud of
in 2014, a 3 CIM gearbox helped my team be the most dominant team in the PNW for the first 3 weeks (ish). no one could catch up to us, and our rams on defense rekt teams with loose ball carry. we didnt have a 4 speed though... it was just all fast, all the time
Do the best you can with what you are given
FRC 2046 2012-2015
Field Scout lead 2014-2015
Unread 15-07-2015, 18:32
Chris is me's Avatar
AKA: Pinecone
I think you went quite overboard on the weight reduction on the outer plate. A pocketed 1/8" plate with no flanges, especially with the reduction being supported off of the end of the plate past the standoffs like that, will have some issues with flex and rigidity. With gearbox designs posted to CD in general there's often an overemphasis on lightening the plates as much as one possibly can, when it's really not that substantial of a weight savings over a more conservative lightening pattern or even unlightened plate.
Unread 15-07-2015, 20:49
FRC #0125 (NUTRONs)
Thanks for the feedback. Would you suggest that I cut back on the lightening holes, add some flanges, and/or thicken the plate?
