Go to Post Any metric you want to apply to Pink, they will pass with flying colors. Pun intended. - Lil' Lavery [more]
Unread 15-07-2015, 18:47
Oblarg Oblarg is online now
AKA: Eli Barnett
Stepper Motors
Do you think there's any chance we'll ever see steppers on the list of FRC-legal motors?
Open control loops are a whole lot easier than closed ones, and I've always felt steppers are a natural solution for a large portion of the FRC problem-space that is currently occupied by PID or bang-bang control loops.
"The breakfast of champions!"
Unread 15-07-2015, 19:26
Scott Kozutsky's Avatar
Scott Kozutsky Scott Kozutsky is offline
FRC #0865
Scott Kozutsky will become famous soon enough
Re: Stepper Motors
This has been discussed before.
Steppers are really hard to use effectively, it would just widen the gap between the better engineering teams and the less experienced.
It uses open loop control so if it loses steps they stay lost and can accumulate. In an FRC environment there are just too many opportunities to loose steps and it would likely end up being a nightmare for all but the best teams.
An encoder versaplanetary stage accomplishes the same result in a more robust way without changing the rules. I've seen clever ways to attach encoders to versaplanetaries so even this isn't really necesary. (a half inch hex encoder would be cool though)
2010-2012 FRC 865 Warp7 Student, Mechanical
2013 FRC 1310 RUNNYMEDE ROBOTICS Student, Mechanical, Design
2014 FRC 865 Warp7 Student, Mechanical, Design
2015 FRC 865 Warp7 Alumni, Mechanical Mentor
Unread 15-07-2015, 19:28
AdamHeard's Avatar
Lead Mentor
Re: Stepper Motors
Combined with the above concerns (on missed counts), stepper motors are pretty awful in terms of power to weight.
Unread 15-07-2015, 19:43
AKA: Eli Barnett
Re: Stepper Motors
I do not think this is really the case. If you choose the wrong stepper for the job, yes, you are going to have problem with skipped steps and accumulated errors. But it is not that hard to pick a stepper with the appropriate torque for a given mechanism.
For many manipulators which require small, precise movements, I think a stepper is far easier to use than a DC motor in a closed control loop. Less complexity, fewer failure points.
Unread 15-07-2015, 19:52
AdamHeard's Avatar
Lead Mentor
Re: Stepper Motors
Please, walk through the selection of a stepper motor and brushed motor for an elevator for this years game. You'll see that you end up with a giant stepper motor (or you'll leave yourself vulnerable to missing counts due to friction/wind blowing/jammed tote/whatever).
Unread 15-07-2015, 20:20
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Re: Stepper Motors
Electrical components become legal when enough of them are donated to FIRST to put an adequate amount of them in each kit of parts. If you want to use an electrical component, find a company willing to donate enough of them.
Unread 15-07-2015, 20:49
jman4747's Avatar
jman4747 jman4747 is online now
Just building robots
AKA: Josh
FRC #4080 (Team Reboot)
Team Role: CAD
jman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond repute
Re: Stepper Motors
I don't think that steppers should be restricted. If someone knowledgeable sees an opportunity to use one effectively than why not let them? It may just be hard to imagine how to use them in FRC simply because we haven't ever seen it.
Alumni, CAD Designer, machinist, and Mentor: FRC Team #4080
Mentor: Rookie FTC Team "EVE" #10458, FRC Team "Drewbotics" #5812
#banthebag
#RIBMEATS
#1620
Unread 15-07-2015, 21:05
AKA: Eli Barnett
Re: Stepper Motors
Clearly, steppers are not suitable for the entire problem space of FRC motion control. You're not going to lift a tote with one.
That doesn't mean that they aren't very well-suited for certain parts of it. Not all of FRC is lifting totes.
Unread 15-07-2015, 21:16
FRC #0865
Re: Stepper Motors
The problem is that teams that can already effectively use them are likely already dominant and this would allow them to be more dominant. Or you get the consensus that it's not useful and end up with more throttle motors, but with their own entire section in the manual.
It also has the very real potential to be misused by less experienced teams and cause massive problems when it doesn't work properly.
IMHO it's a can of worms that does not need to be opened.
Unread 15-07-2015, 21:20
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: Stepper Motors
If I understand correctly, stepper motors require twice as many control signals as a brushed motor. So to save an encoder feedback you add another control circuit - with uncertainty if the torque isn't sufficient to make the step. It sounds like a step backwards, or at best sideways.
Unread 15-07-2015, 22:08
jman4747's Avatar
AKA: Josh
Team Role: CAD
Re: Stepper Motors
Not necessarily. Plenty of people use them for other robots and things like 3d printers or CNC routers as well as in industrial apps so there should be a large group to draw knowledge from. Plus I'd bet there's a good bit of overlap between the above the FIRST community. Thus I would imagine several teams who aren't "dominant" could acquire sufficient knowledge to use the technology effectively.
That might be a desirable trade off you never know. Or a co-processor could generate the singles from instructions sent over via serial or whatever. Options are options and more is more fun.
#banthebag
#RIBMEATS
#1620
Unread 15-07-2015, 23:07
AKA: Eli Barnett
Re: Stepper Motors
Hardware and library support trivializes much of this. You can run a stepper off an arduino pretty easily (online tutorials and libraries abound). If FRC were to offer support for common stepper drivers in their control system library (which would probably be the only way this would happen given FRC rules re: co-processor controlled mechanisms), it'd be even easier.
Unread 15-07-2015, 23:47
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Re: Stepper Motors
I'd rather see the specs on allowable servos to be opened up.
Unread 16-07-2015, 01:33
nathannfm's Avatar
nathannfm nathannfm is offline
AKA: Nathan
FRC #3940
nathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant future
Re: Stepper Motors
Ha, sad, but true, I am sure that is legitimately one of the only deciding factors.
On a related note anyone want a bag of discontinued throttle motors
[2016-20??]: Mentor: FRC Team 3940"CyberTooth"
[2013-2016]: Mentor: FRC Team 365 "MOE"
[2012-2013]: Mentor: FRC Team 3929 "Atomic Dragons"
[2011-2012]: Mentor: FRC Team 365 "MOE"
[2008-2011]: Student: FRC Team 365 "MOE"
[2007-2008]: Student: FTC Team 365 "MOE"
[2005-2007]: Student: FLL Team "The MOEstangs"
Unread 16-07-2015, 02:06
dtengineering's Avatar
AKA: Jason Brett
Re: Stepper Motors
Now brushless motors in general... THAT would be a step forward. But steppers, in specific I don't think would be of much benefit to anyone.
Jason
