Go to Post With three robots, I was expecting better scores but I guess more robots means more penalties, not more points. - sanddrag [more]
Unread 15-07-2015, 21:16
Scott Kozutsky's Avatar
Scott Kozutsky Scott Kozutsky is offline
FRC #0865
Scott Kozutsky will become famous soon enough
Re: Stepper Motors
Originally Posted by jman4747 View Post
I don't think that steppers should be restricted. If someone knowledgeable sees an opportunity to use one effectively than why not let them? It may just be hard to imagine how to use them in FRC simply because we haven't ever seen it.
The problem is that teams that can already effectively use them are likely already dominant and this would allow them to be more dominant. Or you get the consensus that it's not useful and end up with more throttle motors, but with their own entire section in the manual.
It also has the very real potential to be misused by less experienced teams and cause massive problems when it doesn't work properly.
IMHO it's a can of worms that does not need to be opened.
2010-2012 FRC 865 Warp7 Student, Mechanical
2013 FRC 1310 RUNNYMEDE ROBOTICS Student, Mechanical, Design
2014 FRC 865 Warp7 Student, Mechanical, Design
2015 FRC 865 Warp7 Alumni, Mechanical Mentor
Unread 15-07-2015, 22:08
jman4747's Avatar
jman4747 jman4747 is online now
Just building robots
AKA: Josh
FRC #4080 (Team Reboot)
Team Role: CAD
jman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond repute
Re: Stepper Motors
Not necessarily. Plenty of people use them for other robots and things like 3d printers or CNC routers as well as in industrial apps so there should be a large group to draw knowledge from. Plus I'd bet there's a good bit of overlap between the above the FIRST community. Thus I would imagine several teams who aren't "dominant" could acquire sufficient knowledge to use the technology effectively.
Originally Posted by GeeTwo View Post
If I understand correctly, stepper motors require twice as many control signals as a brushed motor. So to save an encoder feedback you add another control circuit - with uncertainty if the torque isn't sufficient to make the step. It sounds like a step backwards, or at best sideways.
That might be a desirable trade off you never know. Or a co-processor could generate the singles from instructions sent over via serial or whatever. Options are options and more is more fun.
Alumni, CAD Designer, machinist, and Mentor: FRC Team #4080
Mentor: Rookie FTC Team "EVE" #10458, FRC Team "Drewbotics" #5812
#banthebag
#RIBMEATS
#1620
