Go to Post To be blunt: how many motorized carts do you see parked on the side of Einstein? - Koko Ed [more]
Unread 15-07-2015, 21:20
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: Stepper Motors
If I understand correctly, stepper motors require twice as many control signals as a brushed motor. So to save an encoder feedback you add another control circuit - with uncertainty if the torque isn't sufficient to make the step. It sounds like a step backwards, or at best sideways.
Unread 15-07-2015, 23:07
Oblarg Oblarg is offline
AKA: Eli Barnett
Re: Stepper Motors
Hardware and library support trivializes much of this. You can run a stepper off an arduino pretty easily (online tutorials and libraries abound). If FRC were to offer support for common stepper drivers in their control system library (which would probably be the only way this would happen given FRC rules re: co-processor controlled mechanisms), it'd be even easier.
"The breakfast of champions!"
Unread 15-07-2015, 23:47
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Re: Stepper Motors
I'd rather see the specs on allowable servos to be opened up.
